601zv(at)ritternet.com Guest
Posted: Wed Jun 20, 2007 4:27 pm Post subject: Vaporlock issues - lessons learned |
As I see it the 601XL plans location for the selector is at a level about
even with the filler cap on my inboard standard tanks and about the 8-gallon
level of the outboard tanks, so it's essetially uphill except with full
fuel. With the selector on the floor it's a a level with about the bottom of
the inboard tanks, and below the outboard tank bottoms.
rge177(at)yahoo.com Guest
Posted: Wed Jun 20, 2007 6:01 pm Post subject: Vaporlock issues - lessons learned |
Gig,
If check valves were installed I believe that you
would be able to run a "Both" tank setup. Wouldn't
the tank, and pump that still have fuel, pressurize
the opposite side up to the check valve? Think about
this analogy. Connect two water hoses from different
supply faucets. The faucets represent both a pump,
and a check valve. Connect the other ends of the
hoses to a "Y" adapter. When you turn both faucets
on, you will of course have running water. Turn one
faucet off, and the other faucet will maintain water
pressure and flow. The straw and glass analogy is
valid if there are no check valves, and I agree with
you that you certainly want a fuel shut off option. I
have seen a picture somewhere where someone installed
separate shut off valves for each tank. Although this
would take a few more seconds to deal with in an
emergency, it would work ok, and probably be a lot
less expensive than some of the valves that we are
currently using. I guess you could also just use one
simple shut off valve after the "Y" connection of the
lines.
Ron
Time: 01:06:02 PM PST US
Subject: Re: Vaporlock issues - lessons
learned
This has been discussed and I will say the same thing
I said then.
Get a glass of water and two drinking straws. Put both
straws in your
mouth. Put
one straw in the water and the other outside the
glass.
Now suck.
The outcome is exactly what will happen if one fuel
tank is empty.
learned
I said then.
straws in your
mouth. Put
glass.
Now suck.
tank is empty.
[quote="crvsecretary"]Gentlemen:
Charles makes a number of very good points here...but
I have a
question or two:
- I'm looking to put a facet pump right at the base
of each tank so
the whole
run is pressurized fuel to reduce vapor lock. Charles
says to be sure
the correct
pump is turned on....is there any danger to the facet
pumps by running
one 'deadheaded' right into the fuel selector...that
way both pumps can
be wired
to ONE switch to eliminate pilot error.
- there was a prolific lister here some time ago
that was
exceptionally knowledgeable
on vapor lock issues. He suggested eliminating the
fuel selector
completely
and running a check valve at the outlet of each pump.
That way BOTH
pumps could supply fuel during takeoff and landing and
ONE pump can
run during
cruise. When one pump is running, the check valve(s)
will eliminate
crossfeeding
from one tank to another.
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
http://games.yahoo.com/games/front
purplemoon99(at)bellsouth Guest
Posted: Wed Jun 20, 2007 7:05 pm Post subject: Vaporlock issues - lessons learned |
Ken, I was thinking about the "intermittent" facet fuel pump. As I said
earlier I dont have a mac. pump all I have is 2 facet inline and 2 separate
switches..Do you or anyone else have any in put or recommendations joe
N101HD 601XL
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Wed Jun 20, 2007 9:36 pm Post subject: Vaporlock issues - lessons learned |
Paul and Doug
1st, Doug's question about fuel flowing from a low spot in the system to a
pump. Some pumps will move enough air to prime themselves, at least to some
well defined elevation of the pump above the liquid level. Others will not.
I think it is usually a tradeoff between pumping efficiency and
convenience. A self-priming pump will be less efficient, i.e., require more
power to deliver the fluid at design flow rate. A pump that does not self
prime can be designed for greater fluid dynamic efficiency, so requires
less power at design flow rate, but is less convenient to start up. I
can't answer whether or not the mechanical fuel pump built into the Jabiru
is self priming.
2nd, Paul's question about the accumulation of water in a low spot in the
line. As long as the fuel line diameter is sufficiently small so that the
fuel is moving with a reasonable velocity, then this should not be a
problem. The fuel line is 0.25" i.d., if we assume a cruise fuel
consumption of 5 gph, I calculate a mean flow velocity is 0.55 ft/s. I
would imagine that a half ft/s would be enough to entrain any water from a
low spot up to the valve and then on into the gascolator. A bit of water in
the fuel stream might make the engine hiccup, but it shouldn't be a major
problem.
The bigger problem occurs if you park your airplane in a cold place in the
winter. If enough water accumulates at a low point to block the fuel line,
it would freeze at temperatures below 32 F, and you could not start the
engine. And the only solution is to warm up the airplane so that the ice
dam melts. That's an inconvenience, but not a really big deal, since you're
still on the ground.
Terry
At 04:30 PM 6/20/2007 -0700, you wrote:
| Quote: | At 03:56 PM 6/20/2007, you wrote:
>I am really hoping someone can explain how the fuel would flow uphill to
>the valve without relying on the system being primed first. This is
>something I've been wondering about.
>Doug
Perhaps the same way a syphon hose is used to get gas from an auto gas
tank - by having the fuel pump suck on the line . . .
I am not sure the head of fuel in the tank is lower than the fuel
switch. The discussion recently pointed out that there is an uphill bend
in the fuel line to get to the tank valve mounted near the instrument
panel. Considering the wing dihedral it is easy to suspect the fuel will
actually be above the valve.
It is the intermediate low point in the fuel line that interests me. I
wonder if water will accumulate at that point and also whether it even matters.
Paul
XL fuselage
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Just starting a 601 kit
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
steveadams
Posted: Thu Jun 21, 2007 4:35 am Post subject: Re: Vaporlock issues - lessons learned |
Regarding water collecting in a low point in the line. The plans for the CH640 specifically say to ensure that the line from the tank outlet to the selector switch runs slightly "uphill" the whole distance without any low point for water/junk to collect. That way it will either run back into the tank or down to the gascolator where it can be drained off. Once the line is filled with fuel it makes little difference in these installations whether the selector is above or below the tank outlet. The things that determine the overall pressure (or suction) in the line is the fuel line diameter, how many and how tight the bends in the line are, and the difference in height between the tank outlet and the fuel pump. Whether it is 6 inches higher or lower in the middle (fuel selector) will have no significant effect. I've never had any hint of vapor lock, even after having had the plane sit in the sun on the ramp for hours in 95+ temps. As far as water freezing in the line, you could also get a partial blockage that would not be detected on the ground, but starve the engine of fuel at full power, leading to loss of power during the initial climb.
Steve Adams
CH640
lgingell
Joined: 10 Jan 2006 Posts: 50 Location: Lake California Airpark 68CA
Posted: Thu Jun 21, 2007 8:13 am Post subject: Re: Vaporlock issues - lessons learned |
I have a XL/Standard 12Gal wing tanks/Andair selector.
I probably already said this in the searchable archives (as did others), but here goes...
Fuel goes from the wings to the Andair selector, which is mounted just above the spar. So fuel is going uphill unless the tanks are full. Fuel then goes downhill to the ZAC supplied ACS gascolator, onto the fuel flow sensor, and a Facet fuel pump at the base (on) the firewall mounted per instructions at 45 degrees up. Then up through the firewall to the engine mounted mechanical Jabiru pump.
I use 100LL all the time. I often wondered about the fuel suck (after reading many posts from 'Frank Hinde' - search the archives..). Anyway, I got vapour lock one time. The airplane was sitting parked afternoon/overnight on a hot day in Oregon. Up to 100F. I couldn't prime the fuel system with the firewall fuel pump as I had vapour lock. Yikes. it took *blowing* in the fuel vents to release this. Try that flying!
Anyway, I don't believe this same condition would likely happen while flying, but I though I should add something soon.
A few flights later, my firewall Facet pump failed. (Now try starting the engine!)
So, I did ADD another Facet pump at the left wing root, and seperate switch on the panel for emergency. This would have solved both issues above (vapour lock and failed pump - which failed open).
When I fly, I prime the system with my firewall elec pump (occasionaly with the other wing root Facet instead - just to test it), for 5 seconds. Turn off. Then start the engine.
I don't use it for takeoff or landing. I read of at least one person (Jabriu list) that had a problem where their elec pump (a Facet) caused the engine to quit after takeoff because it overwhelmed the mechanical pump.
I'd rather turn it on in an emergency (and I'd rather not have one of those!).
Also, turning both Facets on in my system will overpower the mechnical pump and fuel sips by and drips out.
..lance
http://lancegingell.com
Zodiac XL/Jabiru 3300, 185hours
_________________ Zodiac XL/Jab 3300
http://lancegingell.com |
ashontz
Posted: Wed Jul 18, 2007 8:10 am Post subject: Re: Vaporlock issues - lessons learned |
I'd like to see this setup on paper. Sounds good.
Also, got me thinking about the setup pn my pickup truck, and probably a lot of cars, and that is, there's a feed and a return line to the carb bowl, so basically the fuel just makes a continuous loop from the tank to the carb and overflow back to the tank with the pump positioned at the base of the tank. Not sure what the purpose is but I've never had vapor lock in that old truck (1985).
Charles makes a number of very good points here...but I have a question or two:
- I'm looking to put a facet pump right at the base of each tank so the whole run is pressurized fuel to reduce vapor lock. Charles says to be sure the correct pump is turned on....is there any danger to the facet pumps by running one 'deadheaded' right into the fuel selector...that way both pumps can be wired to ONE switch to eliminate pilot error.
- there was a prolific lister here some time ago that was exceptionally knowledgeable on vapor lock issues. He suggested eliminating the fuel selector completely and running a check valve at the outlet of each pump. That way BOTH pumps could supply fuel during takeoff and landing and ONE pump can run during cruise. When one pump is running, the check valve(s) will eliminate crossfeeding from one tank to another. In addition, by using a 2-gang rotary switch wired Left-Right-Left+Right there is no way the plane can suffer from NO pumps on due to pilot error. My only problem with this setup is that the one fuel pump switch presents a single point of failure.......
Any thoughts??
Tracy Smith
N458XL (reserved)
In a message dated 6/19/2007 12:42:37 PM Eastern Standard Time, charles.long(at)gm.com writes:
| Quote: | --> Zenith-List message posted by: charles.long(at)gm.com
? A friend of mine who also flies a Zodie Rocket had an issue on
takeoff the other day. His engine began to stumble right after liftoff on a
90 degree day. He immediately cut power and landed. Fortunately he had
plenty of runway. After assessing the situation, he found that he had
inadvertently turned on the electric fuel pump at the base of the wrong
tank. Two lessons to be learned here: ALWAYS USE THE ELECTRIC FUEL PUMP FOR
BACKUP ON TAKEOFF AND LANDING. SECONDLY, IF USING SEPARATE ELECTRIC PUMPS
FOR EACH TANK, CONFIRM YOU ARE USING THE RIGHT ONE. This incident was with
the Rotax 912s using auto fuel. It has been reported that auto fuel has a
higher vapor lock potential so the electric fuel pumps tend to be even more
critical for avoiding vapor lock issues. If the pump is at the base of the
tank, the problem is virtually eliminated since pressurized fuel won't
vapor lock.
Before we bad mouth the 912s, I would argue that vapor lock is not an
engine-specific problem. I also had a vapor lock problem with my Jab
involving a restrictive fuel filter. The electric pump application
immediately corrected the vapor lock condition as reported below:
To: Zenith-List Digest List <zenith>
cc: micheintz(at)gmail.com
Subject: Fuel Filter Placement - Lessons Learned
I experienced an engine stoppage during one of my first flights. It
occurred at altitude using cruise power with the Aux pump off. The engine
immediately restarted after turning the Aux pump on (windmilling propellor,
so engine starter was not required). I repeated the stoppage a second time
by shutting the pump off and confirmed that the Aux pump was required to
keep the engine running. My airplane configuration is as follows:
601HDS built from Kit
Jabiru 3300A purchased with FWD from ZAC
? Finger screens in the tank
Dual Aux Facet pumps in wing root mounted close to the tank
Selector valve on the floor just forward of the wing spar
Single line feeding the Gascolator just aft of the firewall
? Jabiru Engine fuel pump in series with Aux pumps
Bosch Metal Can auto fuel filter downstream of the Jab pump
Fuel pressure sensor downstream of the Bosch filter
Outside air temp - 80 F
? Jabiru recommends installing the fuel filter upstream rather than
downstream of their fuel pump. I did not follow this practice as I was
concerned about installing a filter on the suction side of the pump.
The fuel system was designed to run at low pressures (<2 psi). The
Bosch filter may have caused a high enough pressure drop to induce Vapor
Lock. Fuel flow was tested before the first flight using the Aux pumps and
flow was confirmed to be over 20 gph. The test was repeated after this
incident and continued to be over 20 gph. The flow was never tested using
the Jabiru pump alone. The Jabiru pump was disassembled and showed no
indications of a problem or contamination.
The Bosch filter was discarded and per the recommendations of those
on the Matronics list, a Flow Ezy stainless mesh filter (A S & S, p/n
05-28905) was installed upstream of the Jab pump. The Flow Ezy filter,
though rather expensive (close to $100), provides high flow/low pressure
drop. This appears to have cured the problem as I have had no additional
issues after 6 hours additional flight time. This includes several full
power climbs with Aux pumps off.
Looking back on this, I should have used the high flow, stainless
filter from the get-go. Fortunately, the plane was designed with fuel pump
redundancy and the Aux pumps were used during Takeoff and Landing.
I hesitate to air my dirty laundry here, but hopefully it will help
some other builders to avoid the same mistake. CFL
Clear Skies!
Chuck Long, CFI
Zodie Rocket
N601LE, 110 hr TT
See what's free at AOL.com.
bryanmmartin
Posted: Wed Jul 18, 2007 2:44 pm Post subject: Vaporlock issues - lessons learned |
Your truck is probably fuel injected. With fuel injection, the fuel pump
pressurizes a fuel rail and the pressure is held at at a constant
setting by a regulator. The regulator bleeds off excess pressure back to
the tank through the return line. Older carbureted vehicles did not have
a return line to the tank because they used a lower pressure pump and
the float valve in the carburetor simply shut off the flow from the pump
when the bowl was full.
Make sure you include in your design a simple way to shut off all the
pumps in case of a forced landing.
ashontz wrote:
Any thoughts??
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
ashontz
Posted: Wed Jul 18, 2007 6:56 pm Post subject: Re: Vaporlock issues - lessons learned |
Actually, it's carburated. Odd. Good point about crash landings and being able to turn everything off. I didn't intend to you this system, just a thought. I'm not sure what their thinking was with a pressurized fuel system with a carburated engine.
[quote="bryanmmartin"]Your truck is probably fuel injected. With fuel injection, the fuel pump
ashontz wrote:
| crvsecretary wrote: | Gentlemen:
Any thoughts??
Bryan Martin
Zenith 601XL N61BM
Do Not Archive |
Trainnut01(at)aol.com Guest
Posted: Thu Jul 19, 2007 2:34 am Post subject: Vaporlock issues - lessons learned |
Bryan
Back in the 70"s there were some carbureted cars that did have a tank return line specifically to prevent vapor lock. These cars had mechanical fuel pumps on the engine, and inline fuel filters between the pump and the carb. That fuel filter had a third, smaller, barb on it that connected to a fuel tank return line.
I worked in both Buick and Oldsmobile shops during that time and I remember the Oldsmobiles having this setup but I'm not sure about the Buicks. (I Suffer from CRS)
Carroll Jernigan
MaxNr(at)aol.com Guest
Posted: Thu Jul 19, 2007 11:00 am Post subject: Vaporlock issues - lessons learned |
From what I find, if you burn 100LL, your fuel system could be a rip-off of any certified low wing single. When you burn auto-gas, its higher vapor pressure can cause vapor lock. Your truck burns fuel blended for your area and season. Put a winter blend in a plane and climb to altitude and it starts to "boil off" vapor. 100LL has a low vapor pressure. You need to preheat an engine using 100LL in cold weather just to get it started, however your truck starts right up. The typical certified "pressure system" with a single boost pump ahead of the firewall actually sucks fuel from whatever distance from the selected tank. The several sources for auto fuel STC's (Maule, EAA and Peterson Aviation usually require modifications to combat vapor lock. Peterson (http://autofuelstc.com) has a page for homebuilder guidance. Also more info about fuel than you can digest. He suggest boost pumps in or near the tanks to push fuel and vapor through the lines. Of course there is more to it than this. This could be a possible scenario: Flying at altitude on a hot day with autogas in the tanks. You empty one tank and (using your check list to eliminate human error) you select the other tank. One pump is turned off and the other pump is turned on. The bad news is that the pump on the full tank has failed. Empty tank with a good pump and full tank with a bad pump. Your engine driven pump may or may not provide enough suction to overcome any vapor and still feed the engine. If possible, descend or land as soon as practicable. It would be nice to have a LOW FUEL PRES warning light for each pump in addition to the single fuel pressure gauge at the carb. You may not notice the load meter not indicating the draw from the pump. Back when I was "flying for the man" I flew some types that had an interconnect between tanks. You opened a solenoid operated valve and gravity leveled the tanks in a few minutes. Could be done on a 601easily by T ing into the line at each tank and putting a simple valve at the lowest point in the cockpit. But that complicates things. AC 43.13-1B Ch 8, Sec 2 says little about fuel system design. I like a text that went out of print in 1967. Aerospace Propulsion Powerplants by Cargnino has a detailed but dated coverage on fuel systems. (Amazon $1.48 used)
Bob 601XL / Lyc O 235 C2C w/ 6.75 to 1 comp ratio- could run on rotgut whiskey
Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [quote][b]
bryanmmartin
Posted: Thu Jul 19, 2007 12:33 pm Post subject: Vaporlock issues - lessons learned |
I stand corrected. I don't recall encountering one with this setup.
Trainnut01(at)aol.com wrote:
| Quote: | Bryan
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
