NYTerminat(at)aol.com Guest
				 Posted: Sat Jul 21, 2007 8:27 pm    Post subject: Haaspower 801 |
				Ben,
  Glad to hear that all is working out with the 801 and  your engine. Are you considering a smaller version, say a V-6? I understand the  lack of speed, I built a 701 and am having a lot of fun but I am looking to go  faster. I will be starting a Glastar in the fall and am also considering  alternative engines. Keep us informed as you build the hours on  yours.
  Bob Spudis
  CH-701/912S/118hrs
  In a message dated 7/21/2007 8:43:28 A.M. Eastern Daylight Time,  n801bh(at)netzero.com writes:
 I LOVE my 801, wish it flew a little faster but thats the trade off of    being able to take off and land in a couple of hundred feet, I am coming up on    200 hours and I have probably 500+ takeoff and landings. Thanks to Zenith for    designing a very strong plane, I have tried to break the thing in half by    running full power all the way up to 18,000 feet and it shows absolutley no    signs of failure, buckling, distorting and any of those other pesky quirks    that go along with some dummy douling the HP requirments for an 801. There are    only few "don't" I have uncovered. One is, Never hold the stick back with full    flaps and let the motor pull it into the air, the plane will rotate and    climb well before I see 20 mph on the airspeed indicator, the flaperons do not    have proper authority at those low speeds and the plane will torque roll    around its axis. I did this once and NEVER again. The motor is working great,    in fact alot better then I even envisioned, it is just too powerful for    the 801. if I had to do it over again it would have a hopped up 0-400 lyc    clone. Zenith reccomends a firewall forward weight of 440 lbs and I am at 437,    so it is within the design range but the plane could benefit from reduced    powerplant weight and a less HP. It has never been lower then 6400    MSL so maybe at sea level it will be spectacular in STOL traits    down  where the air is thick. I have been contacted by dozens of    RV-10 , Lanciar, Bearcat and other experimental owners wanting the powerplant    and it is a perfect fit for those. I will not sell anything till I achieve 300    hours and I am convinced it is a safe and proven firewall forward    package. After all those thinks can and will kill people and I don't want    that to trouble me as I go through life. As for all    you homebuilders. keep at it, the feeling of flying a creation you    crafted by hand is "priceless".
 do not    archive
 Ben Haas
 N801BH
 www.haaspowerair.com
 -- NYTerminat(at)aol.com wrote:
    Ben,
    How is your 801 doing? How many hours do you have now? Is there any    others flying with your package? What is the total engine weight?
    Bob Spudis
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
