oaksnspokes(at)earthlink. Guest
Posted: Mon Jul 23, 2007 8:52 am Post subject: 601XL fuel sender |
All,
I am looking for some input on the subject of fuel senders. I recently
finished a 601XL and about 20 hours into its life the left fuel tank is
reading zero, regardless of the amount of fuel in the tank. I switched
the sender wires at the Dynon and can read the right tank on both
"gauges". I traced the left wire all the way back to where it exits the
fuselage and that all looks good. Before I start drilling out rivets in
the sender cover, I thought I would throw this out to this group and see
if anyone has any helpful ideas.
I was not overly impressed with the senders when I put them in. They
were the factory provided units, I think they are VDOs. If I end up
replacing the sender, I would like to "upgrade" if possible (I have the
2x15 gal. tanks). I have seen senders of a similar design in the
Aircraft Spruce catalog for about $12. These had what looked like a
rectangular solid float, rather than the hollow cylindrical float that I
have now.
Two questions:
1> Does anyone have any useful insights that could help
with my current (apparent) sender problem?
2> Does anyone have any recommendations for a superior sender,
if it comes to that?
Thanks.
Alan Smith
Zodiac 601XL - N601FW
Olympia, WA
zenith601xl(at)gmail.com Guest
Posted: Mon Jul 23, 2007 9:18 am Post subject: 601XL fuel sender |
Even if they work properly, due to the dihedral in the wing; if the sender is outboard the gauge will read empty while still about half full, and full until half empty if the sender is inboard. There is no easy way to avoid this. I too don't like the VW units supplied with the kit and am considering not cutting holes to install any senders. Visually checking each tank before each flight and measuring running time with a clock. Basic but effective. Fuel flow and level indications on a glass panel will be a back up.
Dennis Shoup
On 7/23/07, oaksnspokes <oaksnspokes(at)earthlink.net (oaksnspokes(at)earthlink.net)> wrote:[quote] --> Zenith-List message posted by: "oaksnspokes" <oaksnspokes(at)earthlink.net (oaksnspokes(at)earthlink.net)>
All,
have now.
Two questions:
if it comes to that? [quote][b]
Gig Giacona
Posted: Mon Jul 23, 2007 10:27 am Post subject: Re: 601XL fuel sender |
Doesn't FAR Sec. 91.205 (B) 9 require a fuel guage for each tank? The way a read it it does.
Sec. 91.205
Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements.
(a) General. Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the
instruments and equipment specified in those paragraphs (or FAA-approved equivalents) for that type of operation, and those instruments and items of equipment are in operable condition.
(b) Visual-flight rules (day). For VFR flight during the day, the following instruments and equipment are required:
(9) Fuel gauge indicating the quantity of fuel in each tank.
601XL Under Construction
tonyplane(at)bellsouth.ne Guest
Posted: Mon Jul 23, 2007 11:45 am Post subject: 601XL fuel sender |
Alan,
For what it is worth.
If I recall, the resistance of the VDO gauge is 30 to 70 ohms. You could check you wiring to see if there is any resistance (I believe the 30 ohms was either empty or full and 70 ohms also either empty of full, with in-between neither full nor empty).
You could have a stuck float if you installed it too close to the side of the tank. I have one of my four tanks (an aux tank) that when empty, the float does make slight contact the side of the tank. Fortunately, when fuel is installed, the tank "bulge", relieves this problem. If the float is stuck, use the 'ol thump the tank when full).
Tony Graziano
601XL/Jab3300A; N493TG; 265 hrs.
601XL fuel sender From: oaksnspokes (oaksnspokes(at)earthlink.net ([email]oaksnspokes(at)earthlink.net?subject=Re:%20601XL%20fuel%20sender&replyto=001b01c7cd49$9c0c0a90$6501a8c0(at)OaksNSpokes[/email])) Date: [b]Mon Jul 23 - 9:52 AM[/b] [quote] | Quote: | All,
have now.
Two questions:
Thanks.
Alan Smith
Olympia, WA | [b]
ashontz
Posted: Mon Jul 23, 2007 12:23 pm Post subject: Re: 601XL fuel sender |
How does the ground wire look? Are you grounding to the hull or using a seperate groundwire?
If you're using a groundwire, is the ground actually complete the circuit to the gauge is a gasket or ProSeal causing a break in the connection?
ashontz
Posted: Mon Jul 23, 2007 12:29 pm Post subject: Re: 601XL fuel sender |
This is a good point. I wonder if two floats (one outboard and one inboard in each tank) wired (in parallel I believe) would give a more accurate reading.
[quote="zenith601xl(at)gmail.com"]Even if they work properly, due to the dihedral in the wing; if the sender is outboard the gauge will read empty while still about half full, and full until half empty if the sender is inboard. There is no easy way to avoid this. I too don't like the VW units supplied with the kit and am considering not cutting holes to install any senders. Visually checking each tank before each flight and measuring running time with a clock. Basic but effective. Fuel flow and level indications on a glass panel will be a back up.
Dennis Shoup
On 7/23/07, oaksnspokes <oaksnspokes> wrote:[quote] --> Zenith-List message posted by: "oaksnspokes" <oaksnspokes>
All,
have now.
Two questions:
s.c.richards(at)homecall. Guest
Posted: Mon Jul 23, 2007 1:02 pm Post subject: 601XL fuel sender |
Gig Giacona
Posted: Mon Jul 23, 2007 1:52 pm Post subject: Re: 601XL fuel sender |
| s.c.richards(at)homecall. wrote: | | --- |
S.C., We can't see your message in the forum. E-mail Matt.
DO NOT ARCHIVE
Posted: Mon Jul 23, 2007 7:07 pm Post subject: 601XL fuel sender |
I just checked the specs for the P/N 226 002 VDO sender and:
The resistance is 10 ohms when the tank is empty (float at bottom) and 180 ohms when full (float at top). If you get a reading of about 10 or slightly more ohms then I would suspect the float is stuck.
Tony Graziano
| Quote: | Subject: Re: 601XL fuel sender From: T. Graziano (tonyplane(at)bellsouth.net ([email]tonyplane(at)bellsouth.net?subject=Re:%20601XL%20fuel%20sender&replyto=002701c7cd61(at)pavilion[/email])) Date: [b]Mon Jul 23 - 12:45 PM[/b] | Quote: | | Quote: | Alan,
Tony Graziano
601XL fuel sender
From: oaksnspokes (oaksnspokes(at)earthlink.net ([email]oaksnspokes(at)earthlink.net?subject=Re:%20601XL%20fuel%20sender&replyto=002701c7cd61(at)pavilion[/email]))
Date: Mon Jul 23 - 9:52 AM
All,
have now.
Two questions:
Thanks.
Alan Smith
Olympia, WA
| [quote][b]
AlanSmith
Posted: Tue Jul 24, 2007 11:52 am Post subject: Re: 601XL fuel sender |
I’ll check the resistance on the sender wire, that’s a good tip. I would like to avoid drilling out my sender access covers, and messing up our new paint, but expect it to come to that eventually.
The failure must be something other than a physically stuck float, because it failed when we had about 6 gallons in the tank. I suppose the float could be sitting on the bottom of the tank, with a hole in it... I have attempted to look into the tank with a mirror, but have not been able to get the right angle and the right light.
When the sender was working, it worked well. We were getting reasonable readings in ½ gallon increments. The float hits the top of travel at about 13 gallons, so it can’t see 14 and 15. When the gauge reads 0 gallons, we still have about 2/3 of a gallon, but that’s close enough to zero for me.
Thanks for all the input.
_________________ Alan Smith
Zodiac 601 N601FW
oaksnspokes@earthlink.net |
MaxNr(at)aol.com Guest
Posted: Tue Jul 24, 2007 1:52 pm Post subject: 601XL fuel sender |
A Capacitance fuel sending unit eliminates problems with one end of the tank higher than the other. Calibration is done with a screwdriver. Any water in the fuel will cause a false high reading. Its true that you don't need ANY fuel gauge in an air plane registered other than Standard. In fact, certified aircraft are allowed operation with fuel gauges inop if they have and comply with a Minimum Equipment List. (MEL.) Compliance routinely means a logbook entry & topping off or measuring with a dip stick. The Dynon line can use either resistance or capacitance fuel senders.
Bob XL/Lyc
Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [quote][b]
Posted: Wed Jul 25, 2007 1:24 am Post subject: 601XL fuel sender |
Alan
If you did read my previous reply it was incorrect I had the
sence wrong.
I fitted DATCON gauges with universal senders to Rays The resistances were
33 ohms Full 240 Ohms Empty. You can compair with your working side.
So if the wire to sender is open circuit to ground you may have lost the
tank ground. I assume you fitted one as the tanks are insulated with cork
and should be grounded to airframe to prevent static differences.
Also if you are relying on this to ground the sender is the sender grounded
to the tank and not insulated by the gaskets The universal sender I fitted
was designed to be grounded by a staple through the gasket to the tank which
I thought would be unreliable so I fitted a ground wire.
Clive Richards
RAYS 601HD G CBDG 140 Hrs
Gig Giacona
Posted: Wed Jul 25, 2007 5:36 am Post subject: Re: 601XL fuel sender |
Is there a Capacitance sender that could be installed into the top location of the 601XL tank?
I've got to reopen the wings of mine because I changing the type of fuel line installed and now I think the the Capacitance might be a better way to go.
Anyone thought out the pros and cons of the options?
Posted: Wed Jul 25, 2007 9:15 am Post subject: 601XL fuel sender |
Gig
We have a capacitance type fitted in the side of the header
tank which works ok after we fitted a 12.5 volt regulator to supply it. It
will not see the top 2 inches. I fitted Datcon resistive type in the end of
the wing tanks with difficulty as we did not want to open the wings & the
capacitor type would not fit in this location. (Thought we did not need
gauges as we had header tank but found out they were mandatory in UK).Will
indicate from about the first 5 to 40 litres. the indication is reasonably
steady when you are flying straight & level. A fellow builder on the
airfield fitted capacitance type in his HDS wing tanks & says he only gets a
reliable reading on the ground, I assume he fitted the bendable type in the
top and the fuel sloshes up & down the measuring section. Note you can only
bend a short length at the top not the working part. The straight type may
be ok but due to slope of tank you are limited to ammount you can measure.
Both types are in Aircraft Spruce catalogue.
Clive Richards
Ray Lasnier 601 HD G CBDG
Posted: Wed Jul 25, 2007 9:25 am Post subject: 601XL fuel sender |
The downside to capacitive probes is that they give different readings for
different fuel composition. So avgas will differ significantly from mogas.
And given the funky things that happen with the blends of mogas you could
even get changes in calibration between fill-ups. IMHO I would only use a
capacitive probe if I was going to use avgas exclusively.
Mechanically the capacitive probes are (literally) flexible in their
installation. The actual sensor is just a hollow tube with an electrically
isolated wire inside. The two form the "plates" of the capacitor. If your
gauge or probe can be calibrated then you can cut and bend a probe to fit
your tank.
Here is one source: http://centroidproducts.com/
-- Craig
AlanSmith
Posted: Thu Jul 26, 2007 1:08 pm Post subject: Re: 601XL fuel sender |
I have not gotten a chance to put a VOM on the wire yet, but I did fill the take to about 13 gal. and fly for an hour or so. Somewhere along the way my wife noticed that the gauge started reading something believable (12.5). After I while it dropped to 4, than up to 8, then 5....
It can't simply be getting stuck, because there is no reason for it to have ever hit zero. It can't have a hole in the float, because it never would gave risen up from zero.
It must be some kind of failure in the sender, or faulty wiring on my part.
The up-side of these senders is that they fit. No need for any dome covers on the wings.
Thanks for the input.
Alan
Zodiac 601 N601FW
Gig Giacona
Posted: Fri Jul 27, 2007 11:39 am Post subject: Re: 601XL fuel sender |
I missed it. What kind of sender are you using?
| AlanSmith wrote: | I have not gotten a chance to put a VOM on the wire yet, but I did fill the take to about 13 gal. and fly for an hour or so. Somewhere along the way my wife noticed that the gauge started reading something believable (12.5). After I while it dropped to 4, than up to 8, then 5....
Alan |
