dj45
Posted: Fri Jul 27, 2007 8:37 am Post subject: prop bolts |
Can anyone tell me what the tourque on prop bolts should be? IO360 w/ alum prop.
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
_________________ Do not archive
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
apilot2(at)gmail.com Guest
Posted: Fri Jul 27, 2007 3:55 pm Post subject: prop bolts |
Fixed or constant speed, what brand prop? Seems like my Hartzell came
with instructions on torque, but maybe it was in the Lycoming overhaul
manual as well.
dj45
Posted: Fri Jul 27, 2007 6:21 pm Post subject: Re: prop bolts |
Senscnech(?) prop fixed pitch
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
glcasey
Posted: Sat Jul 28, 2007 4:15 am Post subject: prop bolts |
My instruction manual said 60-65 ft-lb, clean and dry. They put
emphasis on the threads being dry, not lubricated. If the threads
are lubricated the proper torque would be lower, but I don't know how
low. This was for an Aerocomposites prop on an IO-540, but I believe
the hubs and bolts are the same for all Lycomings with constant-speed
props.
Gary Casey
| Quote: | >
> w/ alum prop.
> Thanks
> Dan Stanton
> 90% done 90% to go
> 801, IO360
_________________ Gary Casey |
Float Flyr
Posted: Sat Jul 28, 2007 6:56 am Post subject: prop bolts |
If you accidentally get some oil or grease in the threads you can wash it
out with a bit of MEK.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
esmith6(at)satx.rr.com Guest
Posted: Sat Jul 28, 2007 8:37 am Post subject: prop bolts |
Dan...........Contact Sensenich Prop. Mfg. Co., 14 Citation Ln., Lititz, Pa.
17543......719-569-0435......or email Engineer Dave Burkhart
daveb(at)sensenich.com They will be glad to answer your
questions.................CHEERS!!!!.....and good luck!
Gene Smith
RV-4 14yrs.
dfultz7(at)earthlink.net Guest
Posted: Sat Jul 28, 2007 8:49 am Post subject: prop bolts |
Gene,,The correct phone number is 717-569-0435
Posted: Sat Jul 28, 2007 9:40 am Post subject: prop bolts |
Dale, you are correct, and thanks.........Dan, sorry, hope that little digit
didn't screw your plans up too much...I don't think they are open on
Saturdays any way?.........CHEERS!!!!
Please do not ARCHIVE!
dj45
Posted: Sat Jul 28, 2007 5:49 pm Post subject: Re: prop bolts |
Thank you every one. I think I have a handle on it now.
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
dj45
Posted: Sat Jul 28, 2007 5:52 pm Post subject: Re: prop bolts |
You know, sometimes these planes start to get complacated. Way too many details to keep track of for an old man.
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
AzevedoFlyer(at)aol.com Guest
Posted: Sun Jul 29, 2007 2:48 pm Post subject: prop bolts |
Don,
I0360 and O320 share the same prop.
Assuming yours to be 3/8" bolt diameter, the torque is 24 to 25 lbf.ft.
Bolts must be dry, non lubricated.
Got this piece of info from Sensenich themselves.
Cheers,
Miguel Azevedo
PA22/20
Float Flyr
Posted: Sun Jul 29, 2007 5:29 pm Post subject: prop bolts |
Keep the lockwire nice and tight too.
Noel
Kitfox III-A
jrccea(at)bellsouth.net Guest
Posted: Mon Jul 30, 2007 7:08 am Post subject: prop bolts |
Please double check this. They usuallly do not share the same prop. Among other things, the bolt hole diameter in the O and IO-360's is usually larger.
JimC
azevedoflyer(at)aol.com Guest
Posted: Mon Jul 30, 2007 3:01 pm Post subject: prop bolts |
Jim,
You are absolutely right!
What I checked was 0320-150 hp and 0320-160hp (high compression)! Those two use the same prop.
Maybe I got sidetracked by 160hp and 0360!
I am sorry I fed the list a mistaken info and charged Sensenich for it!
Must be one of those senior moments...
Hope no damage was done.
Miguel Azevedo
PA22/20-150
Posted: Mon Jul 30, 2007 6:31 pm Post subject: prop bolts |
None here. I have more and more of those senior moments myself. Good to know I don't have a monopoly on it.
Jim
