leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Jul 29, 2007 5:52 am Post subject: vert/horiz tail light |
I was about to order a Whelen tail light assembly, but they come in a variety of configurations. One of the choices is vertical or horizontal. Does vertical mean it is to be mounted a vertical surface like the trailing edge of the tail? Or does vertical mean the light build would be pointing up? The one I need would be for the trailing edge. Thanks.
Dan
_________________ Scratch building XL with Corvair Engine |
bryanmmartin
Posted: Sun Jul 29, 2007 7:01 am Post subject: vert/horiz tail light |
On page 24 of their 2007 aviation catalog, they explain that the H or V indicates the position of the mounting screws relative to the light shield. So a vertical mounting would go on the trailing edge of a vertical surface and the horizontal mounting would go on the trailing edge of a horizontal surface.http://www.whelen.com/pb/pb.php?tier1=Aviation
On Jul 29, 2007, at 9:52 AM, leinad wrote:
| Quote: | --> Zenith-List message posted by: "leinad" <leinad(at)hughes.net (leinad(at)hughes.net)>
Dan
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
leinad
Posted: Sun Jul 29, 2007 7:44 am Post subject: Re: vert/horiz tail light |
Brian,
Thank you!
Dan Dempsey (do not archive)
| Quote: | On page 24 of their 2007 aviation catalog, they explain� that the H or V indicates the position of the mounting screws relative to the light shield. So a vertical mounting would go on the trailing edge of a vertical surface and the horizontal mounting would go on the trailing edge of a horizontal surface.http://www.whelen.com/pb/pb.php?tier1=Aviation
--> Zenith-List message posted by: "leinad" <leinad>
I was about to order a Whelen tail light assembly, but they come in a variety of configurations.� One of the choices is vertical� or horizontal.� Does vertical mean it is� to be mounted a vertical surface like the trailing edge of the tail?� Or does vertical mean the light build would be pointing up? The one I need would be for the trailing edge. � Thanks.
Dan
Bryan Martin
N61BM, CH 601 XL,
RAM�Subaru, Stratus redrive.
do not archive. |
Ron Lendon
Posted: Sun Jul 29, 2007 6:27 pm Post subject: Re: vert/horiz tail light |
I purchased the 11-04763 AeroFlash nav/st/pos dbl flash units and am in the process of making the mounting surface on the wing tip. With these two fixtures all the lighting left/right/above/below/rear will be covered. Just something to be considered. Cost from ACS was $473.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
