Europa accident G-HOFC - PFA comment
david.corbett5(at)btinter
PostPosted: Fri Jul 27, 2007 10:16 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Please see below Francis Donaldson’s e-mail to Ted Gladstone, as advised in my e-mail to the forum a few minutes ago.
In the interest of space, I have deleted Alan Simmons’ agreement to the issue of this e-mail.
David
From: Francis Donaldson [mailto:francis.donaldson(at)pfa.org.uk]
Sent: 27 July 2007 10:33
To: Simmons, Alan
Cc: Andy Draper
Subject: RE: Europa statement
Dear Alan
Following our discussion I have decided not to issue a PFA statement about the Europa accident, for the reasons you suggested. However instead I would like your agreement to sending the e-mail below to individuals who e-mail us speculating about the accident sequence. Is this OK ?
Francis Donaldson
Dear Ted
Thanks for the copy e-mail. The reason why the rear wing pin pulled out of the right wing was almost certainly because the construction of the hard point in the root rib was defective, the laminations of the plate were staggered so that the threaded hole was not through the middle of the metal plates as designed. It was near the edge of the first one and penetrating the edge of the underneath ones, ie only the first laminate would have been able to carry significant load. This is why the outer laminate ripped out. I think that release of the rear wing attachment allowed the right wing to swing forward and split the right wing spar, causing the right wing to break up and tearing the pins out retaining the other wing in the process. The massive jerk caused by the wing failure would explain what moved the right tailplane off its pitch pins and allow it to flutter and depart, and the left tailplane could have fluttered and then departed because in moving outboard, the right tailplane had dragged the anti-balance tab operating tee-bar off the pin on the left tailplane’s anti-balance tab.
Had the main wing pins failed, there would not have been the massive damage to the right wing which occurred, as failure of the pin would immediately off-load the wings.
Both crew were found with the cockpit wreckage, there was no question of either falling out of the aircraft in flight.
We are taking what we see as appropriate steps to allow the Europa fleet to carry on flying, with a acceptable level of safety. If we wait for the AAIB report to be published in full, we would have to ground the fleet meanwhile, which could last many months.
The work on the root pin attachment does not involve a huge amount of work or a massive hole in the skin, Andy has managed to devise a keyhole surgery approach. It has been tried on a sample Europa and went OK.
Please note that the above is our present line of thought about the accident sequence but is not yet definitive, that will be the prerogative of the AAIB and their final report. There is further testing to be done to test the theory, which we are helping AAIB to prepare. Please do not broadcast the above on the Europa net or elsewhere as it would not be appropriate to promulgate the present theory in advance of the AAIB report.
Best regards
Francis Donaldson
jodel(at)nildram.co.uk
PostPosted: Sat Jul 28, 2007 8:49 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Francis’s e-mail seems to suggest the opposite sequence of events to that given by the AAIB in S3/2007.
If the tailplane moved as a result of the wing detachment is it known for certain that the TP6 was already detached or did the wing cause that too?
Have we all just modified our aircraft for no reason?????
Simon
To: Simmons, Alan
Cc: Andy Draper
Dear Alan
Francis Donaldson
Dear Ted
Best regards
Francis Donaldson
Finklea
PostPosted: Sat Jul 28, 2007 5:11 pm    Post subject: Re: Europa accident G-HOFC - PFA comment Reply with quote
How many Europa deaths in how many months? 8 in 18 mos... I am concerned!!
lgds(at)post6.tele.dk
PostPosted: Sun Jul 29, 2007 1:39 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Dear "Finklea"Would it be to much to ask you to send comments like that to "The Sun" or similar press representatives - me and the rest of the Europa community have not got time to that sort of "science".
Wish you a happy Sunday.
Regards Gert / OY-GDS
Den 29/07/2007 kl. 3.11 skrev Finklea:
--> Europa-List message posted by: "Finklea" <finklea(at)bellsouth.net (finklea(at)bellsouth.net)>
How many Europa deaths in how many months? 8 in 18 mos... I am concerned!! [b]
josok-e(at)ukolo.fi
PostPosted: Sun Jul 29, 2007 2:04 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
No sign off, so no name to answer:
No, it's even worse. You forget the owners that died even before they finished their planes. Even some neighbors of Europa builders and pilots died. There must be something terribly wrong.
In reality investigations show that running out of gas and forgetting to fly the plane, coming in too slow and stall-spin on final, trying to return form upwind and stall are pilot related and could be fatal.
In any plane.
The last accident is still under investigation.
The nice thing with numbers is that you can do so many things with them. Adding them up is the first thing we learn. Later in our education we usually learn that manipulating numbers has only meaning if we can stick some common factor to them.
Jos Okhuijsen
Visit - www.EuropaOwners.org
gcrowder2
PostPosted: Sun Jul 29, 2007 6:15 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
The RV design is very suspect as well. We had two of them run out of fuel on takeoff,
and one stall spin to final this year already in my area. 5 fatal.  Must be a bad design.
    Glenn
Subject: Re: Europa accident G-HOFC - PFA comment
Date: Sun, 29 Jul 2007 13:00:50 +0300
--> Europa-List message posted by: "josok" <josok-e(at)ukolo.fi>
In any plane.
Jos Okhuijsen
See what you’re getting into…before you go there. Check it out! [quote][b]
carl(at)flyers.freeserve.
PostPosted: Sun Jul 29, 2007 6:47 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Im getting kinda pissed off with some of the mindless (and dangerous) comments that certain individuals seem to make - but then you have the right to make them (just as I have the right to get pissed off).
Designers do not have absolute control over how their designs are built - BUILDERS do !
When your car (or plane) runs out of gas is it the designers fault - NO its yours !!!
When your plane spins into the ground because you are a stupid pilot is it the designers fault - NO its the pilots fault.
Bad design - where's your evidence ?
I hope you don't own a Europa (or an RV) because by the time you have finished telling the world how badly designed they are, they wont be worth bugger all.
Rant over.
PS: My comments ar in no way directed towards Williams tragic demise.
The fact is we dont know what happened so should refrain from speculating till we do (or till the AAIB makes its findings known)
josok-e(at)ukolo.fi
PostPosted: Sun Jul 29, 2007 7:17 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Hi Folks,
Lets take it easy. It's usually me who gets over exited. Of course there is a lot of nuisence in these events, but it's not a reason to start beating each other.
That parts made to specification in small quanteties on short notice are relative expensive might be clear. Full fuel is also expensive, and that is more then a one off event.
[quote]The fact is we dont know what happened so should refrain from speculating till we do (or till the AAIB makes its findings known)
[quote] -----Is the very important thing to remember. Sofar everything, also the remedies of the PFA are based on more or less educated guessing. My bet is elsewhere.
Kind Regards,
Jos Okhuijsen
nielskock(at)get2net.dk
PostPosted: Sun Jul 29, 2007 7:57 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Helt enig, Gert. Nu har han vist også fået tørt på!
Hilsen,
Niels
PostPosted: Sun Jul 29, 2007 8:17 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Takker.Hilsen Gert
Den 29/07/2007 kl. 17.56 skrev Niels Kock:
[quote]Helt enig, Gert. Nu har han vist også fået tørt på!
Hilsen,
Niels
[quote]---
Finklea
PostPosted: Sun Jul 29, 2007 10:53 am    Post subject: Re: Europa accident G-HOFC - PFA comment Reply with quote
Forum members,
Sorry to "offend" you with what was considered a POINTLESS COMMENT. Actually, I should have elaborated more than just saying "I am concerned" My brother was the passenger killed in Ken Hill's N214KS Europa XS that crashed on June 16 in Livermore. He too was a pilot in Viet Nam logging thousands of wartime hours.I have friends looking to build Europas or seaplane kits using the same engines but are also concerned about loss of power issues with this specific engine. I'm sorry if I spoke out of line...
paul.mcallister
PostPosted: Sun Jul 29, 2007 11:13 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Yeah, my Comanche also had the bad habit of quitting on takeoff when it didn't have any fuel in it... must be a common design fault. - Paul
[quote] --
Finklea
PostPosted: Sun Jul 29, 2007 11:36 am    Post subject: Re: Europa accident G-HOFC - PFA comment Reply with quote
Not only did this plane have a full factory tank of fuel, Ken,much to my dismay, also had 1 or 2 aux plastic Evinrude tanks that erupted upon impact leaving nothing but a 1 foot pile of rubble and mostly cremated remains of he and my brother....so this is not a "forgot to fuel" issue!
josok-e(at)ukolo.fi
PostPosted: Sun Jul 29, 2007 11:37 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Hi Finklea,
My condolences with the loss of your brother.
And still, you are out of line, because you can not simply add up accidents.
And you do it again, your second message starts about the engine.There are no known problems with the engine or the airframe. As a matter of fact, both have an excellent safety record. But if there is no fuel going to the engine, because there is none, or the flow is blocked, it will stop. That does not have to mean disaster, because you can land an airplane like the Europa perfectly without a running engine. Your brother was not killed because of a not running engine, he was killed because the pilot tried to return to the runway, something that is a no-no. Statistically it is the very experienced pilot who tries anyhow, killing himself and others. The other tragic accidents that have happened have again different causes, and again nothing to do with engine or airframe. Maybe, maybe the last one is airframe related, but we don't know yet.
Finklea, please if you do not understand these things ask, and do not start throwing accusations around.
Jos Okhuijsen
josok-e(at)ukolo.fi
PostPosted: Sun Jul 29, 2007 1:11 pm    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
Well, i give up. You can't read or don't understand English.
Jos Okhuijsen
topglock(at)cox.net
PostPosted: Sun Jul 29, 2007 2:41 pm    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
My condolences for your loss. I know it's hard to not blame whatever
presents itself, but consider this. All the gas in the world won't help
if it doesn't get to the engine and there are lots of things that can go
wrong, including pilot error, that can cause the gas to not get to the
engine. There are millions of engines, of this type, in service, mine
being one of them. They work as advertised, if maintained properly...
Jeff - Baby Blue
306 hrs
http://forums.matronics.com/viewtopic.php?p=126190#126190
Finklea
PostPosted: Sun Jul 29, 2007 4:52 pm    Post subject: Re: Europa accident G-HOFC - PFA comment Reply with quote
Jos,
What was my accusation? Fact, Rotax has had loss of power issues that have been addressed( and some corrected) in the past. I have a close friend that is a Vice Chairman of the NTSB and he is following this closely and providing some vital information. I am not saying that this aircraft (frame or engine) is mal-designed, only that there may be some issues that for YOUR sake that need attention before others are prompted to make that critical last second low altitude decision, right or wrong. I hope that the cause of the loss of power and subsequent turnback is found before anyone else is put into that situation.
Jos Okhuijsen
Jos,
Why do you feel the need to insult me? I am not attacking you OR your airplane, simply concerned about the results of my research. Remember, I am the one at loss here, not you at least yet. I do understand English and can read! I just hope that I dont have to use those skills to read your obituary someday due to a small engine or airframe fault that went uncorrected because you were too arragant to admit that problems can exist .Do you have a vested interest in Rotax or Europa? Your attitude sure lends itself to such. I too feel that pilot error led to this crash but the turnback WAS precipitated by a mechanical malfunction of some sort. This I am sure!
Jeff, thanks for your unqualified condolences.
I dont feel the need to cast blame here. Ken had flown this plane for 2+ years and as per all accounts was a "10" BUILD and maintained to a T. Yes, stuff happens but there is always a reason for the" stuff" and if that reason can be found and corrected, there is little reason for the same stuff to happen again.
Finklea
rowil(at)clara.net
PostPosted: Mon Jul 30, 2007 10:41 am    Post subject: Europa accident G-HOFC - PFA comment Reply with quote
erupted upon impact
Finklea - I am very sad to hear that an experienced pilot was
persuaded to be aboard an aircraft with such a dangerous-sounding
fuel arrangment.
The likelihood of surviving a low-level stall-spin incident is low at
the best of times; I would not care to stack the odds against myself
by adding a potential bomb to my baggage.
Was the Evinrude tank restrained & plumbed-in in a way that minimised
any possibility of fuel spillage on impact? I've not looked at the
factory-supplied long range tank, but I'm sure it addresses these
concerns. If you choose a different route to provide more fuel on
board, you're conducting an experiment, the result of which, by
definition, is unknown.
What was the gross weight & CG of the aircraft at departure? Two
adults (how heavy?) plus the extra fuel tank(s) might have put it
over-gross or out of balance; maybe there was some baggage aboard
too. Did the Pilot-in-Command conduct a weight and balance
calculation before departure? Did the PiC review the options for
dealing with engine-failure-after-takeoff before depature?
I've just be re-validating my licence in C152s (a factory-built type
with a fairly good safety record); much of the dual time was spent,
not seeing if I could keep the dirty side down or find some distant
waypoint, but on exploring my ability (a) to make sure the aircraft
and its systems were fit for flight before committing to takeoff, and
(b) to make decisions that would contribute to my survival in the
event of unexpected failures. It was not assumed that this simple and
basically safe type would refuse to bite if the pilot took his eye
off the ball, and the same is true of all aircraft types.
regards
Rowland
| Rowland Carson PFA #16532 http://home.clara.net/rowil/aviation/
| 760 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
rampil
PostPosted: Mon Jul 30, 2007 12:37 pm    Post subject: Re: Europa accident G-HOFC - PFA comment Reply with quote
Finklea,
I am sorry indeed about your brother and Ken.
I am always grateful for information which allows me to improve
flight safety! I imagine your friend at the NTSB can not say anything now
we do not already know about that fateful incident.
As has already been mentioned here, the Rotax engine is not
demonstrably better or worse in its safety design than other aviation
engines. Its modern high performance alloys are offset a bit by the dual
carburetor setup which allows a desynchrony failure mode.
A full tank of gas does not help if it is switched off, or if junk clogs the
filter or the carbs, or if the mechanical fuel pump fails, or if the airbox
equalization tubes dislodge, etc, etc, etc.
Please know that this group (for the most part) is grateful for information
and will evaluate what is presented dispassionately.
Condolences,
Ira N224XS
