cffd(at)pgrb.com Guest
Posted: Sun Jul 29, 2007 9:45 am Post subject: 701 Takeoff w flaps |
Has anyone tried partial flaps on the 701 to shorten takeoff roll? Results?
Chuck D.
N701TX
n801bh(at)netzero.com Guest
Posted: Sun Jul 29, 2007 10:22 am Post subject: 701 Takeoff w flaps |
Any amount of flaps will shorten the take off roll in a 701-801. I hardly ever use them on my 801. At the full flap setting the flaperons reduce ALOT of roll control and unless the wind is calm I will not use them, don't ask how I know... On a side note I just returned from OSH and met alot of nice fellow builders. Zenith builders dinner was good and the room was full....
Ben Haas
N801BH
www.haaspowerair.com
-- "Chuck Deiterich" <cffd(at)pgrb.com> wrote:
--> Zenith-List message posted by: "Chuck Deiterich" <cffd(at)pgrb.com>
Chuck&========================= - Thhe Matronics List Features Navigator to brarch & Download, 7-Day Browse, Chat, F======================== great content now also available via ============================================
NYTerminat(at)aol.com Guest
Posted: Sun Jul 29, 2007 1:18 pm Post subject: 701 Takeoff w flaps |
Chuck,
I use 1/2 flaps for takeoff from my grass strip, no flaps elsewhere. It does shorten the takeoff roll, not necessary from pavement.
Bob Spudis
701ZX/912S/120hrs
In a message dated 7/29/2007 1:46:51 P.M. Eastern Daylight Time, cffd(at)pgrb.com writes:
| Quote: | --> Zenith-List message posted by: "Chuck Deiterich" <cffd(at)pgrb.com>
Chuck D.
N701TX
jetboy
Posted: Sun Jul 29, 2007 2:54 pm Post subject: Re: 701 Takeoff w flaps |
Nearly always use 16 deg (full flap on rev-4 and later designs) for T/O and climbout as it gives better cooling and about the same climb rate (at) 50 KTs. Also at the point of liftoff the pitch up response is less pronounced.
Ralph
_________________ Ralph - CH701 / 2200a |
Posted: Mon Jul 30, 2007 6:44 am Post subject: 701 Takeoff w flaps |
Ralph,
I used ZAC's 701 specs when I built my hanger. It turns out they had
changed the landing gear
and so the rudder was a bit too high. I put a 2" block between the nose
strut and nose
wheel fork. The tail now fits and there is a slight nose up attitude on the
ground. I noticed
that the ZAC factory 701 pitched up at lift off too. I hold a bit of back
pressure and my 701
lifts off smoothly with no ptich up.
I will try some flaps, thanks,
Chuck D.
N701TX
Time: 03:55:29 PM PST US
Subject: Re: 701 Takeoff w flaps
climbout
Ralph
stol701(at)yahoo.com Guest
Posted: Mon Jul 30, 2007 7:36 am Post subject: 701 Takeoff w flaps |
Ralph,
Could you send me a picture of the "2" block". I am going to want to raise the nose wheel and put larger main tires on. The plane at this website http://www.qualitysportplanes.com/ has larger mains, I just need to figure out how to do it.
Rob
