runwayrex(at)juno.com Guest
Posted: Tue Jul 31, 2007 1:16 pm Post subject: Question on Rivets for windshield installation |
I too followed the manual on installation. When I had to drill out each rivet to replace the windshield the first time, I replaced the rivets with screws instead. I'm not sure, but they may have been called rivnuts. A small insert went into the material first and then the countersunk screw with a big countersunk washer under it distributes the load. I've changed the windshield one more time since then and the job was a piece of cake. Same story for the rivets on the doors. I used stainless steel screws for all.
Rex in Michigan
Model 3, 912, 80 HP
Warpdrive
1999 completion
-- "john oakley" <john(at)leptron.com> wrote:
--> Kitfox-List message posted by: "john oakley" <john(at)leptron.com>
John,
My fox is also 92 vintage. I used the aluminum rivets with aluminum mandrill
thinking that the steel would pull too hard and cause cracking.
John Oakley
john(at)leptron.com Guest
Posted: Tue Jul 31, 2007 1:51 pm Post subject: Question on Rivets for windshield installation |
Rex,
You are right the rivnuts are the best way to attach..
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Rexster
Sent: Tuesday, July 31, 2007 3:15 PM
Subject: Question on Rivets for windshield installation
Rex in Michigan
Model 3, 912, 80 HP
Warpdrive
1999 completion
John,
John Oakley
msm_9949(at)yahoo.com Guest
Posted: Tue Jul 31, 2007 2:25 pm Post subject: Question on Rivets for windshield installation |
When the Lexan went on, I used stainless truss head sheet metal screws. One or two have needed re-tightening over time but otherwise no problems. Gotta be alot easier than drilling out pop-rivets come replacement time.
Rexster <runwayrex(at)juno.com> wrote: [quote] I too followed the manual on installation. When I had to drill out each rivet to replace the windshield the first time, I replaced the rivets with screws instead. I'm not sure, but they may have been called rivnuts. A small insert went into the material first and then the countersunk screw with a big countersunk washer under it distributes the load. I've changed the windshield one more time since then and the job was a piece of cake. Same story for the rivets on the doors. I used stainless steel screws for all.
Rex in Michigan
Model 3, 912, 80 HP
Warpdrive
1999 completion
John,
John Oakley
dan(at)azshowersolutions. Guest
Posted: Tue Jul 31, 2007 4:24 pm Post subject: Question on Rivets for windshield installation |
John,
It would be best to stay away from using rivets as you have no control over the compression they apply. I have not installed my windshield yet but I have been through A&P classes that teach using a slightly bigger hole than your fastener with possibly a flex sleeve that will seal. It's good to know that most plastics have a thermal expansion rate at about twice that of alluminum and other alloys. What that means is if your windshield is fastened tight with a rivet your windshield will expand in the sun more than your rivet and result in cracking.
FWIW
Dan B, Mesa AZ
KF-IV , 912 S
john oakley <john(at)leptron.com> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } Rex,
John Oakley
To: <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />kitfox-list(at)matronics.com
Rex in Michigan
Model 3, 912, 80 HP
Warpdrive
1999 completion
John,
John Oakley
