Rhino
Posted: Wed Aug 01, 2007 6:27 am Post subject: Re: Sliding window for camera |
With a curved door, sliding is probably not the best option. Hinged would be better.
This is how I would probably do it.
1. Mark the opening you want.
2. Remove the door.
3. Fabricate a 1 inch strip of lexan or plexiglass all around the marked opening, with the strip centered on the marks. You may have to warm the strip somewhat to make it conform to the curves.
4. Attach the strip to the lexan of the door. You can use adhesive, screws or both.
5. Cut through the strip and the door lexan on the marks. This will leave a 1/2 inch reinforcement from the original strip both on the door and on the window you cut out. Also, since you are cutting both together, you insure that the opening matches the door itself, and that the original curve of the door is preserved.
6. Attach a piano hinge to the window through the reinforcement strip.
7. Install a latch of some kind and attach a small piece of lexan/plexi on the outside as a stop for the window so it doesn't open out into the slipstream.
8. Be aware that this method will not be weatherproof.
wingnut
Posted: Wed Aug 01, 2007 9:32 am Post subject: Re: Sliding window for camera |
Thanks Rex. That EAA article is exactly what I was looking for. It covers some of the potential pitfals with cutting lexan and offers a workable solution. I think that this is the way I'll go.
| rexinator(at)gmail.com wrote: | I had found this EAA link (for members only) which discusses a way to
fabricate such a window opening. Since you said "simple" I didn't send
it before.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
