propblast(at)earthlink.ne Guest
Posted: Sat Aug 04, 2007 9:13 am Post subject: Hydraulic Brakes, Oxy and 'G' suits? |
Be careful if you are using an air compressor. There is no way to
completely purge the system of moisture and over time you will corrode
the metal lines.
The problem is no one knows how much time it takes to corrode lines or
the current interior conditions of our old lines.
There are Dry Air Compressors that are used for SCUBA tanks that will
remove most of the moisture but I don't know if they are small enough to
fit in the plane.
Converting brakes to hydraulics is one thing but modifying the current
vital systems can be a safety issue. Food for thought.
John Cabrera
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
delfin(at)mail.pf Guest
Posted: Sat Aug 04, 2007 12:35 pm Post subject: Hydraulic Brakes, Oxy and 'G' suits? |
mY COMPRESSOR WORKS FINE SINCE 10 YEARS NOW !
Le 4 ao�t 07 � 07:07, John Cabrera a �crit :
[quote]Be careful if you are using an air compressor.� There is no way to completely purge the system of moisture and over time you will corrode the metal lines.
The problem is no one knows how much time it takes to corrode lines or the current interior conditions of our old lines.
There are Dry Air Compressors that are used for SCUBA tanks that will remove most of the moisture but I don't know if they are small enough to fit in the plane.
Converting brakes to hydraulics is one thing but modifying the current vital systems can be a safety issue.� Food for thought.
John Cabrera
