		worrybear(at)verizon.net Guest
				 Posted: Mon Aug 06, 2007 5:40 am    Post subject: Silent Cayuna, Ultrastar |
				As I wrote about three weeks ago, my UL202 went  silent with a no problem off field landing.  I thought it was time for an  update.
  The preliminary checks showed lack of spark,  unfortunately in my quest to make sure everything else was OK I found the  rear cylinder to have a fair amount of scuffing. With 177 hours on the top end  and no knowledge of total time on the engine I don't think a rebuild is the  smart thing to do.
  My questions are, has anyone out there put a rotax  on a Ultrastar? Does anyone have a used engine that would be  appropriate? Or anyone have any interest in a Ultrastar without a  motor?
  Flying for the penniless dreamer Is taking it's  toll on my mental health.
  Dan Walter
  Palmyra, PA.
		Richard Pike
				 Posted: Mon Aug 06, 2007 5:46 am    Post subject: Silent Cayuna, Ultrastar |
				Try Central Snowmobile. They might be able to get you a fresh Cuyuna.
  Or maybe these guys -
  http://www.j-birdengines.com/
  Richard Pike
  MKIII N420P (420ldPoops)
  [quote]   ---
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
		rowedenny(at)windstream.n Guest
				 Posted: Mon Aug 06, 2007 6:08 am    Post subject: Silent Cayuna, Ultrastar |
    [quote]     ---
		herbgh
				 Posted: Mon Aug 06, 2007 8:28 am    Post subject: Silent Cayuna, Ultrastar |
				Dan
     I have seen Ultra Stars flown with Subaru EA 71  engines!!    Flown smartly, I think a 582 would work!!  Herb
  On Mon, 06 Aug 2007 09:40:52 -0400 "DANIEL WALTER" <worrybear(at)verizon.net (worrybear(at)verizon.net)> writes:
  [quote]   As I wrote about three weeks ago, my UL202 went    silent with a no problem off field landing.  I thought it was time for an    update.
    Dan Walter
    Palmyra, PA.
		Ralph B
  Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
				 Posted: Mon Aug 06, 2007 8:58 am    Post subject: Re: Silent Cayuna, Ultrastar |
 Dan Walter
 Palmyra, PA.
 I flew an UltraStar once that had a 377 Rotax on it. I didn't look at how he mounted it though.
 Ralph
  _________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Thu Aug 09, 2007 12:27 pm    Post subject: Re: Silent Cayuna, Ultrastar |
				I'm fixing a UL II-02 that had siezed and a little honing of the cylinder liner may work for the scuffing.
 I just bought an engine honing tool for $20 and plan to run that through the seized cylinder liner after I had removed the aluminum from the siezed piston that stuck to the liner using Muriatic acid.
 New Kimpex piston and rings is $45 plus you can get them oversized is you need to hone a lot more.
 A new cast iron liner is about $100.
 I also have a Cuyuna 430 as a backup and have seen them for sale from $200 used to $1200 new and are very common and easy to find parts for.
 I also plan to open up the fins on the engine to allow more airflow to the PTO cylinder, which seized.  They sell modified "Flow Thru" heads like this already so I figure I would save a bit and modify my own.
 Ray
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
