Jerry Sprayberry
Joined: 10 Jan 2006 Posts: 15 Location: Summerville, GA
Posted: Tue Feb 14, 2006 3:27 pm Post subject: Bungees |
I think 500 Hours is the recommended time to replace the bungees. However,
that is part of the safety feature that Ted Smith designed into the
Commander, it helps that little bottle of air overlock the gear in a Hyd.
loss situation. I think I would go with the Annual replacement and
Cloudcraft's procedure of repositioning them a few inches periodically.
Jerry S.
| - The Matronics Commander-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
_________________ Capn Spray |
Jerry Sprayberry
Posted: Tue Feb 14, 2006 3:38 pm Post subject: Bungees |
To all:
The following Link is the Manufacturer of the Bungees.
http://www.sbcindustries.com/
Jerry S.
akucheck(at)gmail.com Guest
Posted: Tue Feb 14, 2006 8:43 pm Post subject: Bungees |
My shop manual says:
"Bungees must be maintained in good condition and replaced every six months.
Rings that have frayed housings or have been in contact with rubber
deteriorating solvents or oils must be replaced."
That said, at six months here in Southern California their condition has
justified replacement; we always do it at annual.
ak
dltafolk(at)sbcglobal.net Guest
Posted: Tue Feb 14, 2006 10:06 pm Post subject: Bungees |
6 months to a year,
I look at where they live...then act accordingly! And I just bought my 500A but ordered new bungees to be ready...from www.sacskyranch.com
Craig 1260B
ak
tfisher(at)commandergroup Guest
Posted: Tue Feb 14, 2006 10:43 pm Post subject: Bungees |
There you have it "6 months" as per the shop manual.
That is what the insurance company would look at when the wheel doesn't
rotate for landing.
I am sort of amazed that we were all over the map with reference to
mandatory time interval of service.
Tom F.
moe(at)rosspistons.com Guest
Posted: Wed Feb 15, 2006 7:12 am Post subject: Bungees |
Jerry,
Thanks much for that.
Do Not Archive.
Moe
N680RR
680F(p)
amg(at)nc.rr.com Guest
Posted: Wed Feb 15, 2006 5:37 pm Post subject: Bungees |
Does the straight 500 have the same requirements for bungees as the
later models?? ( Since the wheels do'nt rotate)
Roland
rotate for landing.
Tom F.
BillLeff1(at)aol.com Guest
Posted: Thu Feb 16, 2006 10:09 pm Post subject: Bungees |
There is no requirement! On Condition is correct but, 24 mo should be max.
It will be different depending on the climate or if the aircraft is kept in a
hangar or tied outside. Do they regularly get oil or hydraulic fluid on them?
Bottom Line: If they don't look good, replace them!!!
It is cheap insurance
Bill Leff
Posted: Thu Feb 16, 2006 10:32 pm Post subject: Bungees |
Which shop manual says that? It would be a great reference.
In the most recent 150 hour program for the 690 series it says "Down Lock
Bungee- Inspect for fraying and deterioration. Squeeze the bungee with thumb
and forefinger, if contact can be made, replace bungee." No calendar time is
specified.
That is the most recent revision dated August 9,2002.
Bill Leff
Posted: Thu Feb 16, 2006 11:00 pm Post subject: Bungees |
The manual I quoted from is my 500A Maintenance manual. Dates are:
Reissued: April 2, 1962
Changed: November 7, 1980
Alan
rcdettmer(at)charter.net Guest
Posted: Fri Feb 17, 2006 6:33 am Post subject: Bungees |
FYI - I have the same notation in my Model 680F Maintenance Manual, revised
April15, 1977. The notation is highlighted under a box that says "caution",
in the section on the "Main Landing Gear".
Randy Dettmer
680F / N6253X
Dettmer Architecture
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
YOURTCFG(at)aol.com Guest
Posted: Fri Feb 17, 2006 9:54 am Post subject: Bungees |
In a message dated 2/16/2006 10:33:32 P.M. Pacific Standard Time,
BillLeff1(at)aol.com writes:
No calendar time is
specified.
Thanks Bill. jb
