DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Thu Aug 09, 2007 8:55 am Post subject: Fuel Line Tubing |
I'm getting ready to install the fuel lines from the wing tanks to the header tank. My kit came with the rubber tubing that is not supposed to be use so I need a replacement. I saw some clear vinyl tubing at the hardware store and thought it maybe suitable. Any opinions out there? Thanks in advance
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
kitfoxmike
Posted: Thu Aug 09, 2007 9:20 am Post subject: Re: Fuel Line Tubing |
bing alcohol resistant fuel line: blue in color
spruce no.
3/8 x 1/4 05-00500
1/4 x 1/8 05-00560
Fox5flyer Guest
Posted: Thu Aug 09, 2007 10:16 am Post subject: Fuel Line Tubing |
Dan, the hardware store variety is made of vinyl and in a very short time
will harden up and be leak prone. Over a longer period of time it can
actually get brittle to the point where any excess flexing can cause it to
crack. ACS has the Bing lines and also any
motorcycle/snowmachine/waverunner shop should have the correct stuff to use
that will hold up.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"If you don't read the newspaper you are
uninformed, if you do read
the newspaper you are misinformed."
Mark Twain
jimlc
Posted: Thu Aug 09, 2007 1:09 pm Post subject: Fuel Line Tubing |
I have used the clear vinyl tubing to replace my sight tube and it has worked for over a year and also has not discolored as did the original tubing furnished.
Jim Crowder
Series 5
Installing Jabiru 3300
-= - T [quote][b]
kentk
Joined: 03 Jan 2007 Posts: 25 Location: College Station
Posted: Thu Aug 09, 2007 5:55 pm Post subject: Re: Fuel Line Tubing |
I am going to use Tygon tubing to replace the clear plastic with - the shop where I bought it said that it is standard for using with auto fuel.
_________________ Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done |
kitfoxfugit(at)yahoo.com Guest
Posted: Fri Aug 10, 2007 10:15 pm Post subject: Fuel Line Tubing |
Subject: Fuel Line Tubing
wing tanks to the
header tank.
Dan, when I replaced mine a year ago, I used fule line
from a place that sells snowmobiles, ATV's and
motorcycles. It has yellowed a bit in the year, but
not deteriorated despite lots of gas through it. We
have alcohol in our car gas in CA.
John Allen
Kitfox IV Speedster w/ 912UL (at) O70
Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool.
http://autos.yahoo.com/carfinder/
kitfoxpilot(at)msn.com Guest
Posted: Sat Aug 11, 2007 6:58 pm Post subject: Fuel Line Tubing |
I replaced mine with black fuel line I obtained from the local boat dealer,
been working great!
Ray
| Quote: | From: John Allen <kitfoxfugit(at)yahoo.com>
Date: Fri, 10 Aug 2007 23:14:52 -0700 (PDT)
wing tanks to the
header tank.
John Allen
Finder tool.
Booking a flight? Know when to buy with airfare predictions on MSN Travel.
http://travel.msn.com/Articles/aboutfarecast.aspx&ocid=T001MSN25A07001
