		| Author | Message |
		| wdaniell(at)etb.net.co Guest
				|  Posted: Thu Aug 09, 2007 7:01 am    Post subject: Mod 72 |   |
				| Displaying my ignorance again
 The mod calls for etching primer
 What is etching primer and what does it do?
 And what is ACF whateveritis that prevents corrosion?  Roger told me that it
 is like WD40 so is WD40 a substitute?
 Will
		| Back to top |  |
		| jimpuglise(at)comcast.net Guest
				|  Posted: Thu Aug 09, 2007 8:14 am    Post subject: Mod 72 |   |
				| Will-
 I had the same question but found both at Aircraft Spruce.  I have in front of me "Tempo Aviation Self Etch Primer" and "ACF-50" Anti Corrosion Formula, both from Spruce.  As I recall, the are less than $10 per spray can.
 Jim Puglise - A-283
 uch mu  [quote][b]
		| Back to top |  |
		| rampil
				|  Posted: Thu Aug 09, 2007 12:23 pm    Post subject: Re: Mod 72 |   |
				| WD40 is not a substitute for the hi-tech ACF anticorrosive
 Ira N224XS
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Thu Aug 09, 2007 3:18 pm    Post subject: Mod 72 |   |
				| WD40 is definitely not a substitute. It degrades over a few months then
causes abrasion or corrosion or both, (as I understand, it degrades to
 silica in some circumstances, particularly in electrical environments).
 ACF50 or LPS1 2 or 3 are like the old Finnegan's Waxoil and leave a
 protective self healing film.
 Graham
 William Daniell wrote:
  	  | Quote: |  	  |
 Will
 Graham Singleton
 Tel: +441629820187
 Mob: +447739582005
		| Back to top |  |
				|  Posted: Thu Aug 09, 2007 3:38 pm    Post subject: Mod 72 |   |
				| Ok is there a commonly available substitute for both remembering that
bringing hazmat from the US to Colombia is a little costly?
 Will
		| Back to top |  |
				|  Posted: Thu Aug 09, 2007 3:49 pm    Post subject: Mod 72 |   |
				| Waxoil? it's an old motor trade product.
Graham
  	  | Quote: |  	  |
 Will
		| Back to top |  |
		| M.Grass(at)comcast.net Guest
				|  Posted: Thu Aug 09, 2007 7:22 pm    Post subject: Mod 72 |   |
				| All,
 I wonder if Poly Fiber's Tubeseal can be used as well as a substitute for
 the ACF50. It says on the container
 " containing a very fine preservative oil, mil spec. l-21260, which has a
 characteristic of climbing the tube wall and spreading over the entire
 surface to provide lasting protection. Prevents rust and corrosion inside
 aircraft tubing structures."
 Another set of questions:
 The instruction of Mod 72 states:
 " Thoroughly coat the insert with etch primer, including the bore, and allow
 to dry completely."
 I am not sure about :
 A- How do you uniformly coat the inside of the inserts (and probably the
 inside of the tubes too) ?
 B- Don't you scrape the primer off again when you drive the insets into the
 tubes and therefore make the coating useless?
 Wonder how others have done this.
 Michael Grass
 A266 Trigear, 914, Woodcomp3000
 Detroit
		| Back to top |  |
