Speedy11(at)aol.com Guest
Posted: Tue Aug 14, 2007 8:11 am Post subject: Emag Wiring |
Mike,
Since you invited comment, I will.
I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist.
I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker."
I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations.
I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working?
Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator.
Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too.
Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads?
Stan Sutterfield
www.rv-8a.net
| Quote: | Erich,
I had the pleasure of attending Bob's seminar this past weekend and I asked him
about this very same issue.
First the caveat. I am not an engineer and don't claim to know a whole lot about
electrical theory or application. What I am is curious and I do have an E and
a P/mag.
After reading everything I can get my hands on and studying the Z figures Z-13
and Z-33 for the Maintenance hand prop option I can detect only subtle differences.
Emag powers the mags directly from the main bus, so when you turn on the master
there is power at the mags. The switches on the panel for the emags are for P-lead
kill switches. To do maintenance (timing) all you have to do is turn on
the master and leave the panel switch off. But to check the alternator part of
the P-Mag you have to put a separate switch in line with the power supply to
the mag. When you do a run up check, you turn this switch off and if all is well
the motor keeps on humming.
Bob's design has the power go to a switch first. The positions on the switch are
down is off, middle is for internal power, up is for ships power. In the Z-33
schematic you then have to add a switch (and possibly a light) to be able to
cut the P-lead so you can do maintenance (Timing). So to do the internal alternator
check all you have to do is flick the switch to the middle position and
if all is well you can't tell the difference.
So what's the big difference. Both systems use 3 switches. Both systems do the
same thing just in slightly different ways.
Personally I can see an advantage in the Emag system where each mag has it's own
P-lead ground kill switch. Starting sequence should be pretty easy. Master on,
both switches in the up position, mash the start button.
But I am a confirmed Nuckoll's advocate and I want to see what he has to say about
this. He is still here in Alaska and touring around visiting the sights. He
has assured me that when he gets back he will dig into this and provide help.
I have sent an email to Emagair asking the same questions. Open dialog on this
question can only help us and Emagair greatly.
I have not personally heard from the guys at Emagair nor have I read anything directly
from them concerning this issue. Until I do I will keep an open mind.
Perhaps this issue is a non-event and some of the problems stem from us folks in
the field still trying to make these new mags act like the old style. For instance
how can you perform a mag drop check if there isn't one. Perhaps the answer
is who cares. I don't know but I am sure interested in how this turns out.
Please comment at will. Any dialog is appreciated.
Mike Ice |
peter(at)sportingaero.com Guest
Posted: Tue Aug 14, 2007 10:37 am Post subject: Emag Wiring |
Stan,
I have been running an E-mag for 3 years and have also swapped in a
P-mag at times. My view is the best way to wire a P-mag is to route the
power via a switched breaker, that minimizes the number of connections.
If ship's power is shut off to a P-mag whose generator is not working,
then the P-mag will act like an E-mag and will not work. If you turn off
the p-lead switch to the other mag, the engine will quit. There is no
magic here, 2 P-mags are completely independent of each other. Checking
both generators is relatively easy, during the run up use the p-lead
switch to stop one P-mag from generating sparks, note the rpm drop
(there will be one); now turn off the switched breaker (thereby shutting
off ship's power to the P-mag), if the engine continues to run at the
same rpm then all is well. If the engine falters or runs roughly all is
not well and the generator is suspect. Turn the switched breaker back on
and repeat on the other P-mag. I've never had a problem with the
generator and would recommend anyone considering an E/P-mag to buy a
P-mag. With 2 P-mags fitted the failure of one generator is no big deal
as the battery will keep the ignition running if the ship's alternator
were to fail.
The P-mag generator does not produce current all of the time (so
E-magair tell me), only when the bus voltage falls below a pre-set
level. The P-mag will use the highest voltage source available. I don't
consider that a warning light showing P-mag generator failure will be
worthwhile when a ground check will provide the same information and it
is not a critical failure that requires immediate attention.
To answer your specific questions,
No, there is no indication. Each P-mag doesn't know (and doesn't care)
the other is there.
Best not to remove ship's power from both P-mags at once, switch off
power in turn when the p-lead switch is turned off. If the P-mag
internal alternator is failed and ship's power is removed the engine
will quit if the other mag's p-lead is switched off.
There will be, and yes, your right, but you have to do each in turn.
I hope this helps, regards, Peter
aurbo(at)ak.net Guest
Posted: Tue Aug 14, 2007 7:31 pm Post subject: Emag Wiring |
Stan,
I agree with you that the guys at Emag want to keep their mags wired the way they designed them. It makes sense to me to follow their recommendations. I was just wondering out loud about the differences in the way Bob Nuckolls suggests and the Emag system.
One thing I like about the AeroElectric ideas is the concept of reducing "parts count". More parts equals more possible trouble. But in this instance either system uses at least 2 switches for each P-mag, so it is a wash.
I understand the need for the switch to shut off the power to the P-mag so you can check the internal alternator but why hide them? If you hide them will you need a warning light to tell you they are in one position or another? I have been thinking I might use a toggle switch with an LED light in the end of it.
I sent you a personal email about float planes in Alaska, yes I do live in Anchorage, when your son gets up here tell him we have a good EAA Chapter www.eaa42.org .
Mike Ice
Posted: Tue Aug 14, 2007 7:48 pm Post subject: Emag Wiring |
Peter,
Forgive me but I am trying to understand your sequence of events for checking the p-mag. Perhaps it is semantics but let me get this straight at least to me.
1. turn off the p-lead (so the mag is grounded or ungrounded? Emag says to use the P leads as kill switches)
2. Then turn off the switched breaker ( so now there is no ground and no power? I imagine the engine might run rough unless the other P-mag is doing the duty of both, I suspect it could)
Emag says if the engine starts to quit, don't reapply power to the mag. They say to let the engine stop and let the ignition fully power down.
Again, I am not doubting you I am just trying to clear up some confusing (perhaps only to me) issues.
Thanks for your help in this issue.
Mike
lamphere(at)vabb.com Guest
Posted: Wed Aug 15, 2007 3:08 am Post subject: Emag Wiring |
Mike,
Unless I have misunderstood the literature that came with my PMag and Emag, the "P-Lead" is used as a control signal to the ignition controller circuitry to shut off spark when it is grounded. It is NOT the main ground to the unit. The power and main ground are separate leads.
Dave
Posted: Wed Aug 15, 2007 4:08 am Post subject: Emag Wiring |
Indeed, it does help. Thanks for your experienced advice.
Stan
| Quote: | | I hope this helps, regards, Peter |
Posted: Wed Aug 15, 2007 4:42 am Post subject: Emag Wiring |
Uh oh. I may have deleted your email regarding the float planes thinking it was spam. Please resend it to speedy11(at)aol.com (speedy11(at)aol.com). Thanks.
I'm hiding the switches (along with others) for security and safety. Unless one knows where multiple switches are, one cannot start the aircraft. Once I've set the switches to one position or the other, they will not change until I change them. If they are in the off position, the engine will not start. If in the on position, it will. So, whether or not the engine will start is my indication of switch position - even if hidden. At the end of a flight, adherence to the checklist is required to ensure they are off.
Yes, I have more than the normal number of 'failure points,' but as Bob relates, switches fail more often from lack of use than from overuse or internal failure. If my switches fail before start, the engine will not start. Once the switch is on, failure is unlikely and the engine will continue to run. So, the additional failure points argument doesn't bother me.
The dialogue is great and I learn more with each discussion.
Stan Sutterfield
| Quote: | I understand the need for the switch to shut off the power to the P-mag so you
I sent you a personal email about float planes in Alaska, yes I do live in Anchorage, when your son gets up here tell him we have a good EAA Chapter www.eaa42.org |
Posted: Wed Aug 15, 2007 6:05 am Post subject: Emag Wiring |
Dave,
Thanks for the post. On the diagram I have there is no lead labeled Main ground, there is one labeled to ground on engine case. Is this one your calling the main ground? If so then I agree with you that the power and main ground are separate leads.
In the instructions that I have for the e/p mags there is a diagram that shows the wiring sequence. On that diagram it shows a wire from the connector plug #4 that is labeled P-lead (Kill Switch). The other end of this wire shows that it is a ground with the same symbol used with the wire that goes to connector plug #1.
Perhaps yours is different?
Once again I am not putting down e/p mags. I just think (maybe wrongly) that there is some come confusion as to how to wire these mags. And perhaps I am the only one that is confused, wouldn't be the first time.
Mike
Posted: Wed Aug 15, 2007 8:44 am Post subject: Emag Wiring |
Ok, here we go... page 20 in my documentation has pin 1 connected to engine case. Since the case is connected to the ground bus via a nice 4-8 gage flexible braided wire, it sure seems to me it's a main ground.
Yes, pin 4 is the P-lead (kill switch) - this is to be connected to the ignition switch pin (L or R) where you would normally connect a mag.
Notice that pin 5 is connected to +13.8vdc. This is what I would call main DC power.
It really is very simple...
Dave
Posted: Wed Aug 15, 2007 9:23 am Post subject: Emag Wiring |
Mike,
I could probably have written a little more clearly. The object is to
get one P-mag running on its internal generator (by removing busbar
power), then cycle the other mag/P-mag to find out if the engine still
runs (I wrote it the other way around). If the engine runs, the
generator is good, if it does not generator is bad.
So, probably the best sequence is
1. Carry out normal mag drop check to deduce "normal" mag drop.
Bear in mind there will always be an rpm drop when only a P/E-mag is
running, but that drop won't be as large as when only a magneto is
running.
2. Shut off busbar power to one P-mag
3. Switch off/ground other mag/P-mag (so it is not producing
sparks)
4. Observe engine behaviour. Rpm drop as in 1 above = everything
working fine, other results require investigation.
5. Restore switches to normal positions if generator is working
fine
6. Repeat procedure from 2 above for other P-mag, if fitted.
I don't check the P-mag generator every flight.
Hope this is a little more clear.
Peter
frank.hinde(at)hp.com Guest
Posted: Wed Aug 15, 2007 9:40 am Post subject: Emag Wiring |
Yes the confusion is....The P lead is NOT the ground but when you do
ground the Plead it kills the engine. You UN-Ground the P lead to allow
the engine to run.
The E/Pmag still needs a power supply and any power supply consists of a
+12V feed and a ground.
Thats why there are two grounds shown...terminal 1 is the power ground
that has to be permanently connected to provide power to the unit.
Frank
RV 7a Pmag/Emag
From: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David
& Elaine Lamphere
Sent: Wednesday, August 15, 2007 9:43 AM
Subject: Re: Emag Wiring
main DC power.
Dave
Posted: Wed Aug 15, 2007 11:49 am Post subject: Emag Wiring |
Frank,
Yes, I think that is part of the problem for me. I keep trying to relate these mags to the old style and it just doesn't work. But trying to erase many years of old and replacing it with new. Maybe it is age related.
Thanks for your comments.
Mike
Peter,
Thanks for the list. Clear as a bell now.
I think I would do as you suggest and not check the P-mag internal alternator every flight either.
How many hours do you have on your P-mags? Any troubles?
Mike
Dave,
Thanks for the clarification. Words often times confuse the issue. Now we are on the same page. I agree with your statements. Thank you.
My troubles stem from trying to mix two wiring systems together and they don't mix well. So I believe it is best (for me) to follow the Emag wizards and their reccomendations to the letter.
One again thanks for helping to clear the fog.
Mike
Posted: Wed Aug 15, 2007 2:31 pm Post subject: Emag Wiring |
I now have around 140 hours total on 3 individual units. I bought the 10th E-mag built as the “factory” (a large shed in Tom’s backyard) was 20 minutes from where I worked. I didn’t have any issues with the 110 series unit. About 16 months ago that unit was replaced foc with a 113 series E-mag, at about the same time I bought a P-mag with the intention of replacing the other mag. The 113 series has always had an intermittent problem on start up where it doesn’t always start up, ie is dead when mag checked and required the power to be cycled to bring it on line (this was before the current issues with powering down while the engine was turning). That was believed to be a firmware problem. When a firmware version update was available I swapped out the E-mag for the P-mag (which has not had any problems) and sent the E-mag back for updating. I have recently re-installed the E-mag (no real reason for the delay in re-installing, just never got around to it), with a similar, but slightly different problem, now evident. I now live a long way from the factory so we’re trying to figure out how best to fix the problem, I’m flying again with the P-mag. Once again the P-mag is trouble free.
Support from the E-magair folks has been outstanding.
Since fitting the E-mag I have gained about 40rpm static, starting is improved (very rarely more than 3 blades) and performance at altitude is definitely better as is the ability to lean more aggressively. I was well aware that I was fitting an experimental ignition system when I installed the first E-mag – that is why I retained one mag, but its never been an issue in flight. I now think the P-mag is an inherently better solution to the ignition problem and would recommend one (or two) to anyone. I’m aware that some others have experienced problems, but E-magair seem committed to fully supporting their products. I am a happy customer.
Peter
O-320 with fixed pitch prop on an RV-6A
Posted: Wed Aug 15, 2007 8:45 pm Post subject: Emag Wiring |
Peter,
Many thanks for your write up on the e/p mags. I have bought one of each and will begin wiring them very soon.
Mike
