601 Belly Cargo Pod...?
PatrickW
PostPosted: Thu Aug 16, 2007 9:46 am    Post subject: 601 Belly Cargo Pod...? Reply with quote
Has anybody has done any kind of belly pod on a 601?
Seen a lot of 601's without the wing lockers. Perhaps owners wanting some additional cargo capacity would find an external location between the main landing gear to be simpler than retrofitting wing lockers?
Anybody done it? Anybody thought of doing it?
Pro's & con's...?
Patrick
XL/Corvair
Rick.Beckman(at)atk.com
PostPosted: Thu Aug 16, 2007 10:34 am    Post subject: 601 Belly Cargo Pod...? Reply with quote
I have not seen or done it, but I have entertained the idea. I
was thinking of a fiberglass tub D-zused to the belly and not too deep.
Weight would be the biggest factor. Two adults and a little luggage with
full tanks is right at the edge of the envelope. It wouldn't leave a lot
for the pod and contents. Just my $ .02.
rstone4(at)hot.rr.com
PostPosted: Thu Aug 16, 2007 6:56 pm    Post subject: 601 Belly Cargo Pod...? Reply with quote
Rick,
The Zodiac601XL is a very good cross country airplane. The only
problem I can see is if you want to take someone with you there is no place
to put the luggage. If you go alone you can place it on the passenger seat
but who wants to go alone. If view of the above your idea is a very good
one and if the luggage pod were streamlined and placed at the center of
gravity I see no reason why it would not work. Of course climb and cruise
performance would be effected but that would mean that it would just take a
little longer to get there. My ZodiacXL has the Jabiru 3300, 120 HP engine
so there is plenty of power even with a luggage pod.
Tracy Stone
Harker Heights, Tx
leo(at)zuehlfield.com
PostPosted: Thu Aug 16, 2007 7:39 pm    Post subject: 601 Belly Cargo Pod...? Reply with quote
Rick, The 601HDS is a better cross country plane. Mine weighs in at
674 lbs, empty. Add me and my wife +340 lbs. = 1014 lbs. Add 20 Gal of
fuel in leading edge tanks, + 120 lbs. = 1144 lbs. That leaves 56 lbs
for baggage. I have two wing lockers, 40 lbs each and baggage shelf 40
lbs. If I wanted to haul 120 lbs of baggage that would cut my fuel to
9.3 lbs or 2 hr. 20 min at 75% power. I have a three hour bladder so I
would load 4 hr. fuel, 15.6 gal. or 94 lbs and increase baggage to 82
lbs. Only cruse at 120 mph with 75% power on my Rotax 912UL.
Leo Gates
N601Z
robert stone wrote:
Rick,
