Firestar II to Firefly
Goto page Previous  1, 2, 3  Next
Thom Riddle
PostPosted: Fri Aug 17, 2007 3:52 am    Post subject: Re: Firestar II to Firefly Reply with quote
Possums,
I like the Horner style wing tips! I had that STC mod on the Piper Cherokee I had several years ago and it made a big improvement over the standard Hershey Bar wing tips. Since I've got to fix one wing tip on the FS 1 anyway, I just might do both of them this way.
Thanks for the TIP. (pun intended)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Steve Boetto
PostPosted: Fri Aug 17, 2007 4:36 am    Post subject: Firestar II to Firefly Reply with quote
Hey Possum, I like the wingtip, do you think it is effective?
Steve
ez(at)embarqmail.com
PostPosted: Fri Aug 17, 2007 4:43 am    Post subject: Firestar II to Firefly Reply with quote
http://www.matronics.com/photoshare/etzim62(at)earthlink.net.02.11.2006/
On Aug 17, 2007, at 7:22 AM, possums wrote:
At 09:23 PM 8/15/2007, you wrote:
> Cage from a Firestar KXP that got trashed from being outside not tied
> down during a pop-up afternoon thunderstorm (wings and tail feathers
> busted up, cage fine)
Same thing here .... crashed in the lake - Firestar KXP but: I
rebuilt the cage,
rebuilt the wings, bought a new engine, (I really like my new 503 -
732+ hrs) ..got the
same nose cone, stick - .....But I figure it's taking up the same
space/time continuum
So I don't need to buy a "carbon credit".
My Great Grandfather left me his hammer (he was a carpenter from
Ireland) ....But the "head " was
"eioj" Iron and rusted really bad, so I had to replaced it. And the
handle was broken..so I had to replace it too..
But...I figure it's taking up the same space and it's an antique -
except for the parts.
> Build 22' wings (ala Slinghot/Firefly), 7 ribs, bunch of bracing (ala
> Slingshot) really stout drag strut..
Me too - except 8 ribs and 26' 9" wings ...tip to tip. bunch of
bracing (ala
Slingshot) really stout drag strut..like you said. + angle bracing
per Hauck.
You should change your wing tips?.It would save you about 18 inches.
AND THIS IS JUST MY OPINION - It will cost you at LOT to go to 22'
wings.
Work on the tips and add a little wing, it's nice to stall at 30 -
mph with VGs.
They work, and that's the truth!
http://www.mindspring.com/~possums/
> .single lift strut like all the
> Kolbs except the Firefly...
Me too - the doubles only "slows you down" 8 mph
unless you're doing loops - you don't need them.
> Add 9" chord ailerons like a Slingshot uses...fab the flaperon
> mechanism
> like the Firefly/SS/Firestar2 and get rid of the original Firestar
> aileron mechanism...
> Fab a support to mount a 10 Challenger tank
> Build a set of tail feathers but cut the boom tube down to Slingshot
> length.
> Rig it with the lower angle of attack (and decalage of course) of the
> Slingshot and add Slingshot-like gear legs to get the deck angle
> right
> to get a 3 point landing out of it with the lower wing AOA.
> Weld up a flip-over canopy frame (ala Slingshot).
> Mount the 503 sitting under the workbench...
> You basically have a single seat Slingshot. It will only have
> 52HP but
> also should be about 100 pounds lighter than a 582 Slingshot.
> Will have same wing area, flaperons, and tail dimensions and tail
> rigging of a Slingshot (just little lower wing loading from being
> lighter). With the lighter weight and the 52 HP of the 503 it will
> actually have a better power/weight ratio than a 582 Slingshot...that
> combined with the lower wing loading should mean better takeoff and
> climb than a 582 Slingshot (which is awesome...)
> Sound fun? Wink
> Jeremy Casey
<1 Wing tip.jpg>
<3 Drawing 2.jpg>
<Wingbow front.jpg>
PostPosted: Fri Aug 17, 2007 5:09 am    Post subject: Firestar II to Firefly Reply with quote
A few more perspectives showing my modified wing planform.
http://picasaweb.google.com/imhisson2/NewAlbum42707610PM
Gene
02.11.2006/P2100044.jpg
02.11.2006/P2100045.jpg
herbgh
PostPosted: Fri Aug 17, 2007 7:35 am    Post subject: Firestar II to Firefly Reply with quote
Eugene
Wouldn't you know it...lawn boy lawn mower...Smile Herb
On Fri, 17 Aug 2007 08:42:58 -0400 Eugene Zimmerman <ez(at)embarqmail.com>
writes:
herbgh
PostPosted: Fri Aug 17, 2007 7:44 am    Post subject: Firestar II to Firefly Reply with quote
Thinking about wing tips.. I read that the whittman tip was low drag?
Similar to the current Kolb design.. Herb
do not archive.
writes:
tied
feathers
> rebuilt the cage,
> 732+ hrs) ..got the
the
(ala
> bracing (ala
> per Hauck.
inches.
22'
> wings.
> mph with VGs.
>> mechanism
Firestar
Slingshot
>> length.
the
>> right
>> 52HP but
tail
being
will
Slingshot...that
and
>> Sound fun? Wink
>> Jeremy Casey
> <1 Wing tip.jpg>
> <3 Drawing 2.jpg>
> <Wingbow front.jpg>
PostPosted: Fri Aug 17, 2007 8:10 am    Post subject: Firestar II to Firefly Reply with quote
30 years and still tickn.
Who says 2-strokes are not reliable?
On Aug 17, 2007, at 11:32 AM, herbgh(at)juno.com wrote:
Eugene
herbgh
PostPosted: Fri Aug 17, 2007 8:27 am    Post subject: Firestar II to Firefly Reply with quote
Eugene
no doubt you have egt and cht and tach strapped to the handle
somewhere?? Smile
Herb
On Fri, 17 Aug 2007 12:07:31 -0400 Eugene Zimmerman <ez(at)embarqmail.com>
writes:
> Eugene
> do not archive
jb92563
PostPosted: Fri Aug 17, 2007 8:31 am    Post subject: Re: Firestar II to Firefly Reply with quote
I like your wing tip counter weights.
You should put fins on them and paint them up like AIM-9's
Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
possums(at)bellsouth.net
PostPosted: Fri Aug 17, 2007 3:09 pm    Post subject: Firestar II to Firefly Reply with quote
YES - I did that "at first", but they broke off and you have to buy the
whole rocket - just to get the fins $20 and I superglued them on last time
and they still broke off after 50 hrs.
But the little counter weights have lead in the ends.
So even tho they look like rockets they are still counter weights.
1planeguy(at)kilocharlie.
PostPosted: Sat Aug 18, 2007 8:16 am    Post subject: Firestar II to Firefly Reply with quote
Me too - except 8 ribs and 26' 9" wings ...tip to tip. bunch of bracing (ala
Slingshot) really stout drag strut..like you said. + angle bracing per Hauck.
AND THIS IS JUST MY OPINION - It will cost you at LOT to go to 22' wings.
Work on the tips and add a little wing, it's nice to stall at 30 -mph with VGs.
<snip>
Have flown my share of big wing homebuilts…wanted a “toy” that would handle as such…yea stall will go up but the beating from thermals will go down thanks to the higher wing loading too…everything is a tradeoff. Flew a clip-wing Challenger single place and compared to the 2 place long wing I flew at the time the clip-wing single was a hoot to fly and the 2 place long wing was a pig. When I run across this cage the first thing through my head was mini-Slingshot … Also the wings were toast already so I was starting from scratch anyway…
Jeremy
P.S. I posted a lengthy explanation of some VG experience the other day…fully understand the benefits of VG’s and the “Superfly” will have them too…Wink
P.P.S. The RANS S7 with VG’s indicated 26 at “stall” solo…but AS indicators are pretty inaccurate that slow…although the GPS says it’s real close…then again just a puff of wind at those low numbers will affect the GPS too….
PostPosted: Sat Aug 18, 2007 12:25 pm    Post subject: Firestar II to Firefly Reply with quote
Jeremy:
Some day I would like to do a side by side comparison with one of these super slow flying aircraft and my non-VG equipped mkIII. Might give me some idea of what I am missing, flying around in a hawg that weighs way too much.
I offerred the right reverend Pike the opportunity to rub it in, the VG thing that is, doing a side by side, but he said that would not be fair. Still waiting. I don't mind getting whupped. Promise not to whine too loud if I do.
[quote] P.P.S. The RANS S7 with VG’s indicated 26 at “stall” solo…but AS indicators are pretty inaccurate that slow…although the GPS says it’s real close…then again just a puff of wind at those low numbers will affect the GPS too
Richard Pike
PostPosted: Sat Aug 18, 2007 12:55 pm    Post subject: Firestar II to Firefly Reply with quote
I still don't think it would be fair, but just to even the odds, maybe we could talk Travis into riding with me while we do it...
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Sat Aug 18, 2007 1:17 pm    Post subject: Firestar II to Firefly Reply with quote
John, I agree with the preacher. It would not be fair.
But I'd love to give it a try with my modified Firestar.
I have never had an aircraft best me yet in a slow-flight challenge
except the slow Jelly Fish and I can match even some of them.
Gene
On Aug 18, 2007, at 4:24 PM, John Hauck wrote:
Jeremy:
http://www.matronics.com/Navigator?Kolb-List_-
forums.matronics.com_-
Richard Pike
PostPosted: Sat Aug 18, 2007 1:54 pm    Post subject: Firestar II to Firefly Reply with quote
Will you be there Gene?
Of course, I would want Travis on the ground if I was matched against your
Firestar...
Richard Pike
Richard Pike
Kingsport, TN 3TN0
PostPosted: Sat Aug 18, 2007 6:56 pm    Post subject: Firestar II to Firefly Reply with quote
Richard,
"Fleeting are the delights of a delusion."
Me and my Firestar are both phatt
What do I get if I win? Smile
Gene
against your Firestar...
Richard Pike
Richard Pike
PostPosted: Sat Aug 18, 2007 7:16 pm    Post subject: Firestar II to Firefly Reply with quote
All the honors and privileges of an Aviation Superstar.
Too bad there aren't any...
Richard Pike
Richard Pike
Kingsport, TN 3TN0
slyck(at)frontiernet.net
PostPosted: Sun Aug 19, 2007 6:50 am    Post subject: Firestar II to Firefly Reply with quote
Hi guys, I was up last night at sundown, very still air, cool
enough for a light jacket.
I climbed out at 40 indicated, half flaps, let it get up to 45 before
easing them off.
Naturally I don't want to stall with the trucks below on I-90 but the
angle of climb
was just dandy and felt solid.
I don't run that close in rough air but in that calm stuff you can
run much closer
to the theoretical. Fun too.
BB
jcooley380(at)hughes.net
PostPosted: Sun Aug 19, 2007 9:39 am    Post subject: Firestar II to Firefly Reply with quote
Hey Jeremy,
Didn’t you buy a Kolbra without an engine in the past year or so. I was looking at it also and seems that I remember that you bought it. If so, what happened to it that’s already got you started on another project?
Later,
John Cooley
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jeremy Casey
Sent: Saturday, August 18, 2007 11:16 AM
Subject: RE: Firestar II to Firefly
<snip>
Jeremy
Date: 8/17/2007 5:43 PM
8/19/2007 7:27 AM
PostPosted: Sun Aug 19, 2007 1:58 pm    Post subject: Firestar II to Firefly Reply with quote
Jeremy:
<snip>
Are we “flying” for pinks??? Wink When is the Kolb Homecoming? If work works out ok I just might fly up…then your on. Question…are we limiting to power off or is power on ok too? Power on I could get out and walk along beside it… (tractor engine…low thrust line will help it “hang” on prop…one of the few advantages to that engine getting the best view of the air out front…)
Jeremy
Page 2 of 3
