Tim_Lewis(at)msm.umr.edu Guest
Posted: Thu Aug 16, 2007 4:27 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
I'm thinking of buying either a 60 Amp alternator made by either Plane
Power ($375 including internal regulator and OV from Van's) or B&C
($595 + $228 for regulator & OV = $823) for my RV-10. The Plane Power
price and simplicity are quite appealing. I've heard good things about
Plane Power, and have heard of only a single failure in the field. B&C
also has a very good reputation. So I'm seeking experiences, both good
and bad, from people who have put a few hours on a Plane Power (or B&C)
alternator.
Tim Lewis
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 900 hrs
RV-10 #40059 under construction
GenGrumpy(at)aol.com Guest
Posted: Thu Aug 16, 2007 4:52 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
I can speak for Van's standard alternator in the kit - it stinks.
I've had noise in it since day one, can't eliminate it with filters, it got worse a couple of flights ago, so now I should have a B&C on the door step tomorrow.
My secondary alternator is also a B&C, and it has worked beautifully (with NO noise whatsoever).
I talked at length with B&C about theirs, their longevity and, with help from my panel builder, I'm switching.
Anyone want a 60amp standard Van's alternator cheap??
grumpy
N184JM
In a message dated 8/16/2007 7:29:33 PM Central Standard Time, Tim_Lewis(at)msm.umr.edu writes:
| Quote: | --> RV10-List message posted by: Tim Lewis <Tim_Lewis(at)msm.umr.edu>
alternator.
Tim Lewis |
wcurtis(at)nerv10.com Guest
Posted: Fri Aug 17, 2007 7:46 am Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
The RV-10 firewall forward kit *use* to come with the Van's (Nippondenso) 60A alternator. I can't remember who, but someone told me at OSH that they have replaced the Nippondenso 60A (ES ALTERNATOR 60A KIT) with the Plane Power 60 (ES ALTERNATOR DELUXE) in the Firewall Forward kits. I elected to upgrade to the PP unit for the additional $100. Can anyone receiving the Firewall Forward Kit recently confirm this?
William
http://wcurtis.nerv10.com/
scottmschmidt(at)yahoo.co Guest
Posted: Fri Aug 17, 2007 8:25 am Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
All I can say is that most people at our airport have had such bad experiences with the standard Van's alternator that they all use B&C now.
I haven't heard of the Plane Power system though. May work just fine.
I used B&C right from the start. My starter is stock but if it every goes out I will replace with B&C. They really do a great job and are easy to work with.
We won't be coming to the homecoming either this weekend. We tried to fit it in and would love to see the Spruce Goose just down the road. This weekend I will be rotating tires, replacing brake pads and replacing my wing strobes (they both went out and I cannot figure it out). Hope you all have a great time.
Scott Schmidt
scottmschmidt(at)yahoo.com
VHMUM(at)bigpond.com Guest
Posted: Sat Aug 18, 2007 2:47 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
William I deleted the Vans Alt from F/ forward kit and got Aerosport to put
on a plane power alt. I got my FF kit a year ago.
Chris
elhershb(at)comcast.net Guest
Posted: Sat Aug 18, 2007 5:19 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
Last week I ordered my FWF kit from the list provided from Van's. This list shows part: ES Alternator Deluxe (60A kit w/OV protection). This is in the 2007 Accessories Catalog from Van's on page 10. The description states that it is the "Plane Power" alternator.
Ed (40430)
Wings
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
[quote] --> RV10-List message posted by: "Chris and Susie McGough"
Chris
Posted: Sun Aug 19, 2007 7:01 am Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
That confirms it--the Plane Power 60A DELUXE alternator is now standard in the FWF kit. Either enough people were excluding or upgrading so they are just including it now. This was not the case with my kit purchsed in May '07.
William
zackrv8
Posted: Sun Aug 19, 2007 10:09 am Post subject: Re: Seeking good and bad experiences with Plane Power, B& |
Also, in regards to the FWF kit, I recieved a Niagra Oil Cooler (SCT'ed) in my FWF kit instead of the Positech or other brands that Van's was shipping. I guess Van's realized that there could/might be a an oil temp issue.
Zack
| wcurtis(at)nerv10.com wrote: | That confirms it--the Plane Power 60A DELUXE alternator is now standard in the FWF kit. Either enough people were excluding or upgrading so they are just including it now. This was not the case with my kit purchsed in May '07.
William
_________________ RV8 #80125
RV10 # 40512 |
