by0ung(at)brigham.net Guest
Posted: Fri Aug 17, 2007 9:08 am Post subject: hks on a mkIII |
I think at sealevel the mkIII would be ok with the HKS... but at
altitude.... the 912 was my minimum.
Boyd
Brigham city ut... 4226 ft msl da over 6000 most of the summer.
Do not archive.
Nope, not the right answer.
Kolb marketed the MKIII with the 503 for several years, and I flew one built
to minimum weight with a dual carb 503 on it. With two people, it was slow
climbing, but better than a Cessna 152. An HKS makes more power than a 503,
so you would get performance about mid way between what you get with a 503
and a 582.
Obviously it would be much less fun than with 65, 80, or 100 HP, but it
would certainly be airworthy.
Richard Pike
MKIII N420P (420ldPoops)
