Riveting to nylon?
a.s.elliott(at)cox.net
PostPosted: Fri Aug 17, 2007 5:08 pm    Post subject: Riveting to nylon? Reply with quote
Just asking for opinions - When riveting 1/8" nylon to the aluminum structure, is it better put the shop head on the metal side or on the nylon side? If it weren't for the "head forming" puller, I would always put the head on the nylon side. Perhaps best to use other rivets? or to countersink the nylon and pull it with a flat-head puller?
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
Ron Lendon
PostPosted: Fri Aug 17, 2007 5:22 pm    Post subject: Re: Riveting to nylon? Reply with quote
I put the shop head against metal
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Afterfxllc(at)aol.com
PostPosted: Fri Aug 17, 2007 6:17 pm    Post subject: Riveting to nylon? Reply with quote
You could also put a washer on the rivet before you pull it.
In a message dated 8/17/2007 9:09:50 PM Eastern Daylight Time, a.s.elliott(at)cox.net writes:
N601GE (reserved)
t_fogelson(at)yahoo.com
PostPosted: Fri Aug 17, 2007 7:43 pm    Post subject: Riveting to nylon? Reply with quote
Second the opinion of using a washer, also you
probably need to drill the hole in the nylon a little
oversize, so the expansion of the shank of the rivit
does not split the nylon.
Terry
N601GE (reserved)
http://smallbusiness.yahoo.com/webhosting
psm(at)ATT.NET
PostPosted: Fri Aug 17, 2007 8:07 pm    Post subject: Riveting to nylon? Reply with quote
Hi Andy,
I have used A5 rivets with the nylon fairleads without regard to the
direction of the rivets, and they seem to work just fine. I choose
the direction of the rivet by the location of the part rather than
the type of material.
Paul
XL fuselage
N601GE (reserved)
