Steve Boetto
Posted: Thu Aug 16, 2007 11:57 am Post subject: 447 fuel line, again |
Just the other day I realized that the fuel line pump ball combo on my Flats Skiff is the same one that came with it 8 years ago. And that I had one hanging on the wall from a prior boat twice that old. Both are still soft and pliable and work fine.
The 447 is a different set up than most other engines in that your are running mixed fuel through the lines rather than straight gas. If you used Auto fuel line the oil tends to breakdown the rubber. The clear UL line is only good for about a year.
I just got back from the Yamaha boat shop and the counter guy there confirms what I thought. The Yamaha Fuel Bulb set P/N 6Y1-24306-55 is far better than anything on the market. For 32 bucks you get 10 foot of line and a superior pump bulb. or you can buy the hose by the foot for $3.60.
I plan to splice in a bypass loop and install as normal. If anyone knows of a better source for this hose let me know.
Steve
jindoguy(at)gmail.com Guest
Posted: Thu Aug 16, 2007 12:17 pm Post subject: 447 fuel line, again |
Try Bing alcohol resistant fuel line from any of the usual suppliers, it's about $1.20 a foot, or you can get the Tygothane line Lockwood sells for $.70 a foot.
Rick
On 8/16/07, N27SB(at)aol.com (N27SB(at)aol.com) <N27SB(at)aol.com (N27SB(at)aol.com)> wrote:[quote] Just the other day I realized that the fuel line pump ball combo on my Flats Skiff is the same one that came with it 8 years ago. And that I had one hanging on the wall from a prior boat twice that old. Both are still soft and pliable and work fine.
Steve
AOL.com.
[quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
Steve Boetto
Posted: Thu Aug 16, 2007 12:31 pm Post subject: 447 fuel line, again |
Thanks Rick, but both of those look like they need to be replaced in about a year.
Steve
a58r(at)verizon.net Guest
Posted: Thu Aug 16, 2007 12:32 pm Post subject: 447 fuel line, again |
"Better hose", try Mark Smith mark(at)trikite.com (mark(at)trikite.com)
regards,
Bob N. FireFly 070 Old Kolb
Steve Boetto
Posted: Fri Aug 17, 2007 10:22 am Post subject: 447 fuel line, again |
After some research on the internet it looks like the tubing I am using is probably VITON. No wonder it cost so much. It is a good choice for the application because of its high resistance to UV and practically all solvents and fuels. But it's a bit pricey at around $5/ft from McMaster-Carr. On the other hand you may not ever have to replace it.
steve
JetPilot
Posted: Wed Aug 22, 2007 9:09 pm Post subject: Re: 447 fuel line, again |
Some of the guys around here use fuel lines made for Boats, the marine fuel line is UV resistant, much better than the clear ultralight plastic type lines, much stronger, and well worth it at even 5 times the cost.
When it comes to my plane, I would never try to save a few dollars for a fuel line that may deteriorate and leak over time.
Mike
Kolb MK-III Xtra, 912-S |
Steve Boetto
Posted: Thu Aug 23, 2007 3:34 am Post subject: 447 fuel line, again |
In a message dated 8/23/2007 1:10:19 A.M. Eastern Daylight Time, orcabonita(at)hotmail.com writes:
What are they using?
steve
Posted: Thu Aug 23, 2007 4:42 am Post subject: 447 fuel line, again |
Mike, Even the best plastic deteriorate over time. On all my machines, whether they fly or not, I inspect the fuel and pulse lines regularly and just replace them when I think they need it. I get my line from the Bing Agency, primarily because it's just up the road, right here in Kansas. Different philosophy, I guess.
To make replacement easier, I coat the barbed fittings with lithium grease before I slide the line on. Keeps me from having to cut the line off the fitting when the time comes.
Rick
On 8/23/07, N27SB(at)aol.com (N27SB(at)aol.com) <N27SB(at)aol.com (N27SB(at)aol.com)> wrote:[quote] In a message dated 8/23/2007 1:10:19 A.M. Eastern Daylight Time, orcabonita(at)hotmail.com (orcabonita(at)hotmail.com) writes:
steve
AOL.com.
Posted: Thu Aug 23, 2007 5:03 am Post subject: 447 fuel line, again |
Hi Rick:
Personally, I would not put grease on my barbed fuel fittings. I do not want them to be easily removed. If I have to cut them off, when the time comes, so be it.
Undoubtedly, the "grease'em up" system works for you or you would not use it.
I use neoprene rubber fuel line on my MKIII and 912ULS. Have not used plastic in years. I have heard there is some problem using premixed fuel/oil with some black neoprene line, but also heard marine grade fuel line will work with that combo. I have used marine fuel line before. It is much heavier, thicker wall, than regular Gates auto fuel line. Capable of making tight bends without collapsing.
UV, heat, and fuel will eventually get any flexible fuel line, but the black neoprene rubber line will far outlast plastic.
Does anyone know why the UL community decided to use plastic fuel line instead of black neoprene rubber?
[quote] To make replacement easier, I coat the barbed fittings with lithium grease before I slide the line on. Keeps me from having to cut the line off the fitting when the time comes.
Rick
_________________ John Hauck
Titus, Alabama |
ez(at)embarqmail.com Guest
Posted: Thu Aug 23, 2007 5:26 am Post subject: 447 fuel line, again |
On Aug 23, 2007, at 9:03 AM, John Hauck wrote:
| Quote: | Does anyone know why the UL community decided to use plastic fuel
Well ya gotta keep the air-vehicles separate from the air-craft some
how and since air-vehicles are not
automobiles ,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Oh, I just lost my ,,,
train,,, of thought,
What were we talking about?
positively do not archive
Posted: Thu Aug 23, 2007 6:12 am Post subject: 447 fuel line, again |
John, Don't confuse easier with easily. They're still a pain to pull off, much harder than the fittings on Mikuni fuel pumps and the Rotax pulse port fitting, and I never rely on anything less than a good safety wire wrap as a hose clamp.
Rick
On 8/23/07, Eugene Zimmerman <ez(at)embarqmail.com (ez(at)embarqmail.com)> wrote: | Quote: | --> Kolb-List message posted by: Eugene Zimmerman <ez(at)embarqmail.com (ez(at)embarqmail.com)>
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Steve Boetto
Posted: Thu Aug 23, 2007 6:24 am Post subject: 447 fuel line, again |
In a message dated 8/23/2007 9:04:32 A.M. Eastern Daylight Time, jhauck(at)elmore.rr.com writes:
Hi John, You and I have discussed this before, I even tried using auto line but as you know it did not work for us lowly mixgas types. The fuel line I am talking about appears to be superior to auto line. It is not the big clunky stuff for under the hull install, it is very flexible and non collapsing.
I do not need to test this hose because I have already used it for years exposed to UV and mixed fuel on skiffs. The added bonus is that for those using a pump bulb, The bulb on the Yamaha assy seems to be the same material and is far superior to any I have seen.
I think that standard auto hose is great for unmixed fuel but this is the best thing that I have seen for fuel/oil mix.
steve
rlaird
Posted: Thu Aug 23, 2007 11:58 am Post subject: 447 fuel line, again |
I use fuel-injection line that is compatible with all fuels with any
mixes: SAE 30R9 (one popular mfg is Gates). Most NAPA stores will
have an SAE 30R9 equivalent. Also, I haven't used it, but check out
Areoquip FC332...
http://www.hosexpress.com/hose/socketless/FC332.htm
-- Robert
On 8/23/07, N27SB(at)aol.com <N27SB(at)aol.com> wrote:
collapsing.
steve
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Steve Boetto
Posted: Thu Aug 23, 2007 12:43 pm Post subject: 447 fuel line, again |
Thanks Robert, I will check it out
steve
d-m-hague(at)comcast.net Guest
Posted: Thu Aug 23, 2007 1:39 pm Post subject: 447 fuel line, again |
At 09:03 AM 8/23/2007, John Hauck wrote:
Does anyone know why the UL community decided to use plastic fuel line instead of black neoprene rubber? |
I'm guessing it's because the clear line makes it possible to see air bubbles if any are present, which can be pretty important in keeping a 2-stroke healthy.
Funny... Aircraft Spruce sells the blue Bing urethane fuel line, which one presumes is good if the carburetor manufacturer sells it... it's what I bought for my US. OTOH, over on the Quicksilver list where I used to hang out for awhile, they hate the blue line, preferring (I think) the yellow Tygon fuel line, which I've used with no problems on my PPG (you still have to replace it every few years). McMaster sells the yellow Tygon, and they also sell a cheaper generic yellow fuel line, which hardens up much faster than the genuine Tygon.
When I bought a primer bulb (Suzuki, I think) from a boat dealer a few years ago it came with some very nice looking gray tubing (which I never used as it was too short).
-Dana
Children seldom misquote you. In fact, they usually repeat word for word what you shouldn't have said. [quote][b]
