tomd
Posted: Sun Aug 12, 2007 4:41 pm Post subject: Help to fix careless mistake |
I have just completed the left wing of my MkIII classic and am ready to begin the right wing. I realized that I have mistakenly used 1 1/4" tubing for the leading edge of the completed left wing instead of the 1 1/2" called for in the plans. I see two choices; drill out all of the leading edge rivets and replace the 1 1/4" with 1 1/2" or also build the right wing with 1 1/4" tubing and keep pressing on. Obviously the 1 1/2" is stronger but is it enough to make a difference? I appreciate any suggestions.
Malcolmbru(at)aol.com Guest
Posted: Sun Aug 12, 2007 4:57 pm Post subject: Help to fix careless mistake |
just press on it will be weaker but that is not where it needs to be the strongest I new a guy that flew into a tree crash landing into a swamp and he fixed his leading edge with a closet rod and duck tape then flew it bask out . malcolm michigan
AOL.com.
Posted: Sun Aug 12, 2007 5:05 pm Post subject: Help to fix careless mistake |
| Quote: | | Tom D: The leading edge of the Kolb wing is the hardest working part of the wing. If the wing fails, the leading edge will be the first to go. I take no short cuts on building Kolb wings. In fact, I build them much stronger than the plans call for. Reason: For my own self satisfaction. If it was my wing, I would drill them out and replace with the correct size tubing. | 0123
_________________ John Hauck
Titus, Alabama |
Posted: Sun Aug 12, 2007 5:13 pm Post subject: Help to fix careless mistake |
[quote] Malcolm Michigan: How much weaker? john hmkIII [b]
Titus, Alabama |
Posted: Sun Aug 12, 2007 5:27 pm Post subject: Help to fix careless mistake |
I saw a video of a guy named Denis, he flew a ultrastar into several high G maneuvers trying to wreck a wing when it did fail it was not the leading edge that failed it was the jury strut. when he deployed his chut it subjected the plane to moor G,s than wrecking the wing did. malcolm michigan
AOL.com.
Richard Pike
Posted: Sun Aug 12, 2007 5:31 pm Post subject: Help to fix careless mistake |
Sorry Mal, but I think that is bad advice.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Sun Aug 12, 2007 5:34 pm Post subject: Help to fix careless mistake |
If you want it dun fast and cheep just hire a poor lazy man mal
Ralph B
Posted: Sun Aug 12, 2007 5:35 pm Post subject: Re: Help to fix careless mistake |
Replace it with the correct tubing. After it's built you will have the satisfaction of knowing it’s done right. If you don't fix it, and put the covering on, it will be harder to replace the tubing if the plane has some bad tendencies. A sharper leading edge makes for a sharper stall.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
jindoguy(at)gmail.com Guest
Posted: Sun Aug 12, 2007 6:34 pm Post subject: Help to fix careless mistake |
Think of it like this. It's a beautiful day, the air is clear and bouyant, a perfect day to fly. The convective activity begins and before too long you're having to tug the straps a little tighter because you're getting some negative G's. Are you going to be thinking about your flying or about the weak ass leading edges in your wings?
If you allow yourself to overlook a mistake of this magnitude, what else will you let yourself get away with? This is the proverbial slippery slope.
If you can't bring yourself to fix this now, while it's relatively easy, stop working on it and sell it to someone who will.
I always remember Burt Rutan's admonition in the LongEZ Plans. "Your best work is barely good enough."
Rick
On 8/12/07, Malcolmbru(at)aol.com (Malcolmbru(at)aol.com) <Malcolmbru(at)aol.com (Malcolmbru(at)aol.com)> wrote:[quote] If you want it dun fast and cheep just hire a poor lazy man mal
AOL.com.
[quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
Posted: Sun Aug 12, 2007 7:19 pm Post subject: Help to fix careless mistake |
Malcolm
I have been a member of this list for better than 10 years and this is the most stupid and irresponsible advice I have ever heard!!!
Tom
Fix the mistake. If not you or some one you love it might bite some one else and YOU would be responsible how would you feel? Please fix it.
Rick Neilsen
Redrive VW powered MKIIIC
GeoR38
Joined: 25 Jan 2006 Posts: 60 Location: The Villages, fl
Posted: Sun Aug 12, 2007 7:51 pm Post subject: Help to fix careless mistake |
In a message dated 8/12/2007 11:20:47 P.M. Eastern Daylight Time, NeilsenRM(at)comcast.net writes:
[quote] Malcolm
Tom
Rick Neilsen
_________________ George Randolph
Firestar driver, The Villages, fl |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Sun Aug 12, 2007 8:33 pm Post subject: Re: Help to fix careless mistake |
If you want to design your own wing fine, be a test pilot and let us know how long the weaker tube lasts over years of flexing and G-Loading.
If you want to enjoy flying your aircraft as designed and benefit from all the others who have gone before you and will let us all know if something needs fixing and when, then build it as designed.
You know the old saying about aircraft design..."Changing 1 thing changes everything"
I'd say that the price of 2 new tubes and some work is the ONLY option unless you know aircraft design and can run your tubes and new wing design through a strength and dynamic loading analysis to verify its new lower G-loading limits. Also don't foget a physical proof loading as well to verify the results.
I'd say that redesigning the wing is a LOT more work than fixing what you stated yourself is a MISTAKE!!!
Ultimately its YOUR butt in the seat....choose wisely as aviation is unforgiving of mistakes.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
d-m-hague(at)comcast.net Guest
Posted: Mon Aug 13, 2007 9:19 am Post subject: Help to fix careless mistake |
At 09:45 PM 8/12/2007, Tom Deiulio wrote:
| Quote: | | ...I have mistakenly used 1 1/4" tubing for the leading edge of the completed left wing instead of the 1 1/2" called for in the plans. I see two choices; drill out all of the leading edge rivets and replace the 1 1/4" with 1 1/2" or also build the right wing with 1 1/4" tubing and keep pressing on. Obviously the 1 1/2" is stronger but is it enough to make a difference? |
Assuming the same wall thickness (and not knowing how it ties into the rest of the structure), the 1 1/4" tubing is only 57% as strong for bending loads as the 1 1/2". Do you really want to fly an airplane whose wings are only half as strong as they should be?
Fix it right.
-Dana
"The budget should be balanced, the Treasury should be refilled, public
debt should be reduced, the arrogance of officialdom tempered and
controlled, and the assistance to foreign lands should be curtailed lest
Rome become bankrupt" -Cicero, 68 B.C. [quote][b]
tomd
Posted: Wed Aug 22, 2007 12:44 pm Post subject: Re: Help to fix careless mistake |
I have decided to replace 1 1/4" tube with 1 1/2". I will be using oversized rivets (5/32) for holes that are not salvageable but I have has good luck drilling out so far. I coated my rivet heads with primer which has had a unanticipated secondary benefit, holding the rivet heads from spinning as I drill them out. Thanks to all for your help with this temporary set back.
WhiskeyVictor36(at)aol.co Guest
Posted: Wed Aug 22, 2007 5:59 pm Post subject: Help to fix careless mistake |
In a message dated 8/22/2007 4:45:25 P.M. Eastern Daylight Time, tpd47(at)earthlink.net writes:
| Quote: | | I coated my rivet heads with primer which has had a unanticipated secondary benefit, holding the rivet heads from spinning as I drill them out. |
tom d,
Thanks for posting that advice. I have helped my buddy rebuild his wings/ailerons a couple of times now, and spinning rivets, while drilling them out, has always been a problem. Hopefully I'll remember this for the next time.
Bill Varnes
Original Kolb FireStar
Audubon NJ
olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Thu Aug 23, 2007 5:56 am Post subject: Re: Help to fix careless mistake |
Hey Tom D,
I just noticed you are in Scotia. I'm right near you. I would love to come over and see your Kolb. We have a pretty good EAA chapter also and you may want to come to the meeting Monday. Send me an email if you want to get together.
olendorf at gmail.com
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
jb92563
Posted: Thu Aug 23, 2007 6:42 am Post subject: Re: Help to fix careless mistake |
I read that coating a surface the rivet is in contact with before riveting is NOT an approved method for aircraft construction.
You can however paint over the rivet.
I forgot what the exact reason was, but it had something to due with the compression of the coating and the rivet becomming loose eventually and loosing the integrity of the joint.
Just an FYI so others dont think its a proven approved method....just the opposite actually.
Moni MotorGlider
Do Not Archive |
Posted: Thu Aug 23, 2007 7:00 am Post subject: Help to fix careless mistake |
Ray, I'm not sure why riveting with a dab of zinc chromate or other primer under the rivet head would be any different than riveting together two parts that have been painted prior to riveting. Seems like it would squeeze out the liquid and maybe not do as good a job at corrosion protection, but how it would effect the clench strength of the riveted joint isn't clear.
I'll see if I can find any reference in AC 43-13 later.
Rick
On 8/23/07, jb92563 <jb92563(at)yahoo.com (jb92563(at)yahoo.com)> wrote: | Quote: | --> Kolb-List message posted by: "jb92563" < jb92563(at)yahoo.com (jb92563(at)yahoo.com)>
Ray
Riverside County, CA
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Richard Pike
Posted: Thu Aug 23, 2007 7:07 am Post subject: Help to fix careless mistake |
On my MKIII, I applied the zinc chromate and then put the rivit in while the
paint was still wet. Solves the Problem.
Richard Pike
Kingsport, TN 3TN0
jb92563
