GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Fri Aug 24, 2007 2:23 am Post subject: CANOPY FLASHING |
HI ALL
I AM NOW WORKING ON THE FLASHING ON THE FRONT OF THE CANOPY RAILS. BEST I CAN TELL THESE ARE TO SLIDE UNDER THE TOP SKIN WHEN THE CANOPY IS OPENED. FOR PILOTS SIDE I CAN DO THIS IF I CUT A SLOT JUST ABOUVE THE BEND, BUT THE OTHER SIDE IS ANOTHER 1/8 INCH OUTBOARD. SEEMS LIKE I CAN HAVE IT GO OUTSIDE THE TOP SKIN AND JUST LET THE RUBBER SEAL SLIDE OVER THE SKIN.
THANKS
GLENN
THANKS ALSO FOR THE IDEAS FOR THE SCREWS IN THE SIDE FLASHING.
dredmoody(at)cox.net Guest
Posted: Fri Aug 24, 2007 7:50 am Post subject: CANOPY FLASHING |
Glenn, I think the entire front flashing should be positioned inboard of the front top skin so no slots need to be cut. The front top skin should fit over the flashing, over the combination canopy hinge and upper motor mount bracket, and even over the canopy hinge bolt. If you need some photos, email me back off list, but there are decent photos in the assembly guide that should help you.
Dred
---- GLJSOJ1 <gljno10(at)HOTMAIL.COM> wrote:
HI ALL
THANKS
GLENN
http://forums.matronics.com/viewtopic.php?p=130692#130692
