doug.medema(at)comcast.ne Guest
Posted: Mon Aug 20, 2007 9:01 pm Post subject: Gear legs rusting in mounts |
I recently removed my gear legs and found them to be corroded at
the points they go into the mounts, especially the lower collar.
I have since stripped, sanded, acid etched, conversion coated,
primed, and painted the legs and am ready to reinstall them. Since
you can't paint over the places with close tolerances, they will just
rust again unless I do something to protect them. I was thinking
of just putting a good layer of grease on them, but am wondering
if anybody else has a better idea.
Again, this is just on the two areas that make contact with the
gear mounts. All the rest of it is protected.
Doug Medema
RV-6A N276DM down for painting after 170 hours.
8/20/2007 1:08 PM
Vanremog(at)aol.com Guest
Posted: Mon Aug 20, 2007 9:24 pm Post subject: Gear legs rusting in mounts |
In a message dated 8/20/2007 10:02:49 P.M. Pacific Daylight Time, doug.medema(at)comcast.net writes:
| Quote: | I recently removed my gear legs and found them to be corroded at
I used one of the corrosion resisting sprays applied just as I installed them in late '97. I've forgotten which LPS product I used and I haven't removed the mains since installed, but I did retrofit my nose gear a few years back and the old one came out easy and looked fine for its age.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 864hrs, Silicon Valley, CA)
AOL.com.
billsettle(at)bellsouth.n Guest
Posted: Tue Aug 21, 2007 12:53 am Post subject: Gear legs rusting in mounts |
I've used this in the past with good results...
http://www.aircraftspruce.com/catalog/appages/corrosionx.php
Date: 2007/08/20 Mon PM 11:59:34 EST
To: <rv-list(at)matronics.com>
Subject: Gear legs rusting in mounts
corroded at
collar.
coated,
Since
will just
thinking
wondering
the
Doug Medema
Date: 8/20/2007 1:08 PM
rv9jim(at)juno.com Guest
Posted: Tue Aug 21, 2007 5:06 am Post subject: Gear legs rusting in mounts |
Doug,
Here in the south with the salt air I would recommend using
"anti-seize" compound like you use on your spark plugs. If the steel is
clean, the anti-seize will protect it from rust. Be very careful as the
stuff will "travel" if you get it on you and don't clean it off. Its
hard to clean off once its on something. You can use either the "silver"
colored or the "copper" colored anti-seize. The copper stuff is higher
temp rated.
Jim
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Tue Aug 21, 2007 5:25 am Post subject: Gear legs rusting in mounts |
My legs have been sitting down in -- what used to be -- the family room (becoming a family room again now that I'm moving stuff to the hangar). On Saturday I picked them up off the rug and had two real nice rust stains on the carpet where the bottom of the legs (un powdercoated) had been sitting for a year. Can't get the rust off the carpet, but I sanded the legs and then just rubbed 3-in-1 all over them like I should've done before.
Anyway, couldn't you just oil down the parts?
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com
Sent: Tuesday, August 21, 2007 12:24 AM
To: rv-list(at)matronics.com
Subject: Re: Gear legs rusting in mounts
AOL.com.
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
aerokinetic(at)sbcglobal. Guest
Posted: Tue Aug 21, 2007 6:06 pm Post subject: Gear legs rusting in mounts |
Doug,
Get yourself some Par-al-Ketone... it usually comes in a can with a bear on it, and you can get it from Spruce or any of the usual suspects (I prefer Wicks). It is an anti-corrosion agent commonly used in control cables. It comes out of the can as a slippery brown liquid with a viscosity similar to a very thick oil and 'dries' to a fairly soft waxy pariffinic film that won't come off on your hands but will deliver superb protection. It is *the* answer to your needs. It can be removed or thinned with Mineral Spirits and easily comes loose when needed to. It is safe on virtually all surfaces and isn't any more toxic than oil. Super handy stuff. Been using it for years. Put my wing bolts, gear legs and other items in 'wet' with it. They will never corrode. Ever. I'm convinced. There are other agents with similar properties, but this is easily found and all you need. It's cheap and one can will last you forever. You can even use it for conditioner after shampooing for silky smooth hair... okay... maybe not.
Scott
N4ZW
A&P 17 years for what it's worth.
Posted: Wed Aug 22, 2007 5:12 am Post subject: Gear legs rusting in mounts |
Hi crew-
| Quote: | ... I would recommend using
"anti-seize" compound like you use on your spark plugs. ...
Please be mindful of the fact that graphite, the useful ingredient in the
grey spark plug anti-seize, is corrosive to aluminum.
FWIW-
glen matejcek
aerobubba(at)earthlink.net
Posted: Wed Aug 22, 2007 7:44 am Post subject: Gear legs rusting in mounts |
In a message dated 8/22/2007 6:14:45 A.M. Pacific Daylight Time, aerobubba(at)earthlink.net writes:
| Quote: | >... I would recommend using
| Quote: | "anti-seize" compound like you use on your spark plugs. ...
For different types of anti-seize compounds and their uses see http://www.lub-o-seal.com
They can recommend the right material for the application.
AOL.com.
jrdial(at)hal-pc.org Guest
Posted: Wed Aug 22, 2007 9:13 am Post subject: Gear legs rusting in mounts |
I know the gear legs and mounts are not aluminum but the cylinder heads you are screwing the spark plugs in are aluminum?
DO NOT ARCHIVE
Posted: Thu Aug 23, 2007 5:08 am Post subject: Gear legs rusting in mounts |
HI JR-
| Quote: | I know the gear legs and mounts are not aluminum but the cylinder heads
That was the first thing that occurred to me when the whole graphite
causing Al corrosion was pointed out to me. The fine print, though, is
that the spark plugs actually screw into steel inserts, like heli-coils.
Hence the admonitions to use the anti-seize sparingly. It prevents there
being excess compound which could migrate to contact with the aluminum head.
glen matejcek
Posted: Thu Aug 23, 2007 5:34 am Post subject: Gear legs rusting in mounts |
glen matejcek wrote:
| Quote: | | Quote: | --> RV-List message posted by: "glen matejcek" <aerobubba(at)earthlink.net> (aerobubba(at)earthlink.net)
HI JR-
causing Al corrosion was pointed out to me. | | The only thing I've seen on the graqphite/aluminum subject was a picture of thin aluminum sheet that had been corroded through and a disc fell out. Don't know any more about that particular situation though.
| Quote: | | Quote: | The fine print, though, is
that the spark plugs actually screw into steel inserts, like heli-coils. | | Only if they've been installed. No steel inserts AFAIK in new cylinder heads. | Quote: | | Quote: | Hence the admonitions to use the anti-seize sparingly. It prevents there
being excess compound which could migrate to contact with the aluminum head. | | The problem with excess antisieze is that a glob inside the cylinder will become red-hot without burning off and cause run-on during shutdown.
Linn
[quote] [b]
dale1rv6(at)comcast.net Guest
Posted: Thu Aug 23, 2007 8:58 pm Post subject: Gear legs rusting in mounts |
| Quote: | | The fine print, though, isthat the spark plugs actually screw into steel inserts, like heli-coils. |
Only if they've been installed. No steel inserts AFAIK in new cylinder heads. | Quote: | | Hence the admonitions to use the anti-seize sparingly. It prevents therebeing excess compound which could migrate to contact with the aluminum head. |
Linn
[quote] Question about run-on: If firing sparkplugs don’t cause run-on during shutdown, how would red hot globs? Or would the real concern be pre-ignition during normal operation? Dale[b]
Posted: Fri Aug 24, 2007 5:13 am Post subject: Gear legs rusting in mounts |
HI Linn-
| Quote: | > The fine print, though, is
heads.
That certainly makes sense, but my info on this issue came from Champion.
I suppose it's not impossible that their reps pooched it...
head.
| Quote: | >
Linn
I have a hard time imagining a scenario where one could properly apply any
type of dope on any male threads, and get it into the bore of the device.
Plus, a glowing deposit in the cylinder should cause pre-ignition and
perhaps lead to detonation, which could well preclude run-on Not
to mention, run on takes fuel, the absence of which is how we kill aircraft
engines anyway!
glen matejcek
Posted: Fri Aug 24, 2007 5:18 am Post subject: Gear legs rusting in mounts |
Dale Walter wrote:
| Quote: | <![endif]--> <![endif]-->
Linn
| Quote: | | Question about run-on: If firing sparkplugs don’t cause run-on during shutdown, how would |
Good point. I've had run-on even after I've shut the mags off. Especially in my Pitts (O-360) after I've worked her hard and the temps are still up. I hate the stink! I've never noticed a pre-ignition problem, but that's really hard with that big snarling thing so close up front! I do use auto fuel in it though. The bottom line for me is the high temp stuff in the antisieze also makes it harder to burn off.
Linn
[quote] | Quote: | | that the spark plugs actually screw into steel inserts, like heli-coils. | 0 [b]
az_gila
Posted: Sat Aug 25, 2007 5:52 am Post subject: Re: Gear legs rusting in mounts |
This is similar to the nose gear mount in my Grumman Tiger.
The Maintenance Manual calls for the nose gear to be installed with a wet application of zinc chromate primer and then torqued. Silicon sealer (RTV) is to be applied at the ends of the mounting socket to prevent entry of moisture.
It also calls for a yearly removal and inspection - a procedure most owners do not perform.
gil in Tucson
