bob(at)frontrange-pc.com Guest
Posted: Fri Aug 24, 2007 2:44 pm Post subject: somewhat off topic - Purchasing an incomplete homebuilt |
I looked at CH601HD project, recently advertised here, and have a couple
of questions about purchasing a work in progress:
1 - Is it possible to be the A&P for a purchased project? I seem to
recall that this honor can be bestowed on the original builder and I
wonder if it is applicable to someone who finishes a project.
2 - What must be done to satisfy the FAA that you meet the 51% rule?
Thx
Bob Percival
CH701 scratch builder - glacial pace
bryanmmartin
Posted: Fri Aug 24, 2007 5:11 pm Post subject: somewhat off topic - Purchasing an incomplete homebuilt |
As far as the 51% rule is concerned, you only have to accomplish 51% of the various tasks needed to build the airplane, you don't have to actually build 51% of the airplane. For instance, if you build one wing, that demonstrates the skills necessary to build a wing. Then you could hire someone to complete the other wing if you wanted to. Actually, just building the rudder would probably be enough to demonstrate the necessary sheet metal skills for the entire project. I believe the EAA website has a sort of check list for the tasks needed to satisfy the 51% rule.
The repairman certificate can only go to one person per airplane -- the primary builder. This term is not well defined. If someone else started the project and you bought the incomplete and did the necessary work to finish it and get it airworthy, you will probably have no trouble getting the repairman certificate, especially if you are able to show compliance with the 51% rule.
On Aug 24, 2007, at 6:42 PM, Bob Percival wrote:
| Quote: | --> Zenith-List message posted by: Bob Percival <bob(at)frontrange-pc.com (bob(at)frontrange-pc.com)>
I looked at CH601HD project, recently advertised here, and have a couple of questions about purchasing a work in progress:
1 - Is it possible to be the A&P for a purchased project? I seem to recall that this honor can be bestowed on the original builder and I wonder if it is applicable to someone who finishes a project.
Thx
Bob Percival
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
txpilot
Posted: Sat Aug 25, 2007 9:39 pm Post subject: Re: somewhat off topic - Purchasing an incomplete homebuilt |
Bob,
The following is from AC 20-27F, Section 7g:
(3) Buying an Aircraft Built From a Partially Completed Kit. If you buy an aircraft built from a partially completed kit, you should get all fabrication and assembly records, such as receipts for materials, the builder’s log, and aircraft, engine, and propeller logbooks, from the previous owner. You
should add the construction efforts of the previous amateur builders to your builder’s log to show the construction history of the kit. This information may help us to determine that your aircraft is eligible for amateur-built certification.
This AC contains other information regarding the Repairman Certificate. Also, you might want to check AC 65-23A regarding the Repairman Certificate. Hope this helps.
Best Regards,
Dan Ginty
cbaron66
Posted: Mon Aug 27, 2007 5:25 am Post subject: Re: somewhat off topic - Purchasing an incomplete homebuilt |
Just a small note of correction: If the plane/parts meet the qualifications, you might get a repairmans certificate. Unless you complete the necessary schooling and or expeariance and pass all the written, oral and practical tests, you will never be an A&P
