Posted: Thu Aug 23, 2007 1:38 pm Post subject: Out-of-spec 601XL/Jabiru 3300 motor mount |
My motor mount was supplied by Jabiru USA about 8 months ago. After seeing
that the engine's thrust-line didn't match the Zenith plans I took some
measurements of the mount's tubes as requested by Jabiru USA. They said that
the top tubes were about 10 cm too long and that they would exchange the
mount. So if you have such a mount do some checking before you paint your
mount and hang your engine. The easiest way to check the mount is with a
digital level.
-- Craig
Gig Giacona
Posted: Thu Aug 23, 2007 1:50 pm Post subject: Re: Out-of-spec 601XL/Jabiru 3300 motor mount |
10 cm or mm?
601XL Under Construction
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Thu Aug 23, 2007 4:14 pm Post subject: Re: Out-of-spec 601XL/Jabiru 3300 motor mount |
Would you be so kind as to share the measurements Jabiru sent you? I have an engine mount that I received from them in May but who knows when it was made......
Thanks!
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Thu Aug 23, 2007 4:45 pm Post subject: Out-of-spec 601XL/Jabiru 3300 motor mount |
I only have the measurements I made and the "top tubes 10 mm too long"
comment from Jabiru USA. Below are my measurements. Since the tubes are cut
on a diagonal these measurements are on the longest, outside edges of the
tubes from the plates at the firewall to the disks at the rear of the engine
mount "pins". Take these measurements as approximate as it was hard to make
some of them with a steel tape with the mount and engine on the plane:
top tube, pilot side: 445 mm
top tube, copilot side: 465-470 mm
bottom, pilot side: 380 mm
bottom, copilot side: 400-405 mm
What is actually critical is the angle of the engine (horizontal and
vertical) to the firewall. So it is best to measure these directly and
compare them to 6-JE-1 in the Zenith plans.
-- Craig
dredmoody(at)cox.net Guest
Tim Juhl
Posted: Fri Aug 24, 2007 9:05 am Post subject: Re: Out-of-spec 601XL/Jabiru 3300 motor mount |
Just to be sure I understand you correcly..... The measurements you provided were of the original mount that was "too long", correct?
CFII
Champ L16A flying
Posted: Fri Aug 24, 2007 11:11 am Post subject: Out-of-spec 601XL/Jabiru 3300 motor mount |
| Quote: | Just to be sure I understand you correctly..... The measurements you
Yup, those are the measurements of my bad mount, the one that tilts the
engine's nose down about 2 degrees too much. That would make sense if (as
Jabiru USA says) the top tubes are 10 mm too long. I never got around to
checking the side angle.
-- Craig
Tim Juhl
Posted: Sun Aug 26, 2007 4:56 pm Post subject: Re: Out-of-spec 601XL/Jabiru 3300 motor mount |
Checked my mount today..... my top tubes are about 10 mm shorter than yours so hopefully I've got a good one.
Thanks for sharing your experience!
CFII
Champ L16A flying
Posted: Sun Aug 26, 2007 5:04 pm Post subject: Out-of-spec 601XL/Jabiru 3300 motor mount |
| Quote: | Checked my mount today..... my top tubes are about 10 mm shorter than
Glad to hear it. Do you have any way to measure the angle of the plane
defined by the disks at the back of the mounting pins relative to the plane
defined by the plates that bolt to the firewall? That (and the angle of your
firewall to the upper longerons) are the critical numbers.
-- Craig
Tim Juhl
japhillipsga(at)aol.com Guest
Posted: Mon Aug 27, 2007 6:50 am Post subject: Out-of-spec 601XL/Jabiru 3300 motor mount |
Tim, I happen to have an extra XL/Jab3300 engine mount. Depending on where you are you are welcome to use it. Call my cell at 478-731-9678. Bill of georgia
