Spinner help
VHMUM(at)bigpond.com
PostPosted: Sun Aug 26, 2007 5:22 pm    Post subject: Spinner help Reply with quote
Bit confused with spinner as first part of instructions say match drill all
the #30 holes to1/8 of the doubler ring to spinner back plate.
What 1/8th holes
regards Chris
Tim Olson
PostPosted: Sun Aug 26, 2007 5:49 pm    Post subject: Spinner help Reply with quote
If this is after the point where you have nutplates in the backplate
rings, then I think all they want you to do is look through the
semi-transparent spinner and drill where you see light coming
through the nutplate holes. But, this is from memory and not from
reading the plans. If this doesn't sound right, give the step number
and page and I'm sure people will jump in.
Chris and Susie McGough wrote:
<VHMUM(at)bigpond.com>
all the #30 holes to1/8 of the doubler ring to spinner back plate.
What 1/8th holes
regards Chris
PostPosted: Sun Aug 26, 2007 6:18 pm    Post subject: Spinner help Reply with quote
Thanks Tim and no first step.
plans 47-2 step 1
Tim Olson
PostPosted: Sun Aug 26, 2007 6:55 pm    Post subject: Spinner help Reply with quote
Ouch, I see it now...if your S-602B doesn't have 1/8" holes
on it, you must have a part that wasn't completed all the way.
Might have to look ahead in the plans to make sure there's nothing
that you'd upset by just placing them where they make sense.
You're kind of far away to have it be worth getting a new part
over. Maybe they can email you a full-size template or something?
Or, hey, if anyone on the list has that part and wants to trace it
and scan it in, they could get it to you somehow...just have
to make sure it's printed to scale.
Thanks Tim and no first step. plans 47-2 step 1
PostPosted: Sun Aug 26, 2007 7:04 pm    Post subject: Spinner help Reply with quote
Thanks Tim I have emailed Vans I am sure they will just send a new part.
They have sent many a part free of charge including a gear leg can you
believe!
Chris
ddddsp1(at)juno.com
PostPosted: Sun Aug 26, 2007 7:34 pm    Post subject: Spinner help Reply with quote
Tip on the SPINNER: If you wanna be able to use CS washers and flush screws ...........DO NOT center drill the holes for the back spinner plate per the instruction. If you do there is not enough room for the CS washer. Drill the holes more toward the spinner tip......approx 1/8" off center line.
DEAN 805HL
________________________________________________________________________
/2-2130421-177">Surprise your friends with a FREE Juno Video Mail! Sign up today.
