rleffler
Posted: Tue Aug 28, 2007 5:16 pm Post subject: Dimple challenged tonight |
While dimpling the skins of the elevator, I started getting tired and was pushing myself to complete the tasks at hand. As you might suspect, Murphy showed up and I screwed up. The attached picture isn’t all that good, but you can clearly see that I missed the hole and it’s now elongated. This is the bottom outside corner of the trailing edge of the elevator.
I see my options as:
<![if !supportLists]>1. <![endif]>The anal perfectionist in me wants to order a new skin.
<![if !supportLists]>2. <![endif]>Find a way to make a repair that doesn’t look too bad.
<![if !supportLists]>3. <![endif]>Whatcha worried about, just keep building, the proseal will keep things together.
Thoughts, comments?
25.75 KB |
288 Time(s) |
_________________ Bob Leffler
N410BL - Phase I
rvbuilder(at)sausen.net Guest
Posted: Tue Aug 28, 2007 5:42 pm Post subject: Dimple challenged tonight |
Any chance you can drill it to a 30 and use an oops rivet?
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Tuesday, August 28, 2007 8:16 PM
Subject: FW: Dimple challenged tonight
Thoughts, comments?
papadaddyo(at)tampabay.rr Guest
Posted: Tue Aug 28, 2007 5:51 pm Post subject: Dimple challenged tonight |
We’ve all been there. Looks like you can drill it larger and use an oops rivet. If you can keep it smooth and the trailing edge is not out of whack, it’ll fly. Keep on building.
Rick
40397
Sent: Tuesday, August 28, 2007 9:16 PM
1. The anal perfectionist in me wants to order a new skin.
2. Find a way to make a repair that doesn’t look too bad.
3. Whatcha worried about, just keep building, the proseal will keep things together.
Thoughts, comments?
rleffler
Posted: Wed Aug 29, 2007 2:14 am Post subject: Dimple challenged tonight |
My concern is that the where the other hole is located is right at the rim of the dimple. It appears that the factory head, even for an oops rivet may not cover the mistake. Also, this is the bottom skin, so it should have the shop head of the rivet on this side (remember this is the trailing edge). The shop head of an oops rivet will certainly be larger.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Tuesday, August 28, 2007 9:42 PM
Subject: RE: FW: Dimple challenged tonight
Michael
Thoughts, comments?
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
__________ NOD32 2490 (20070829) Information __________
N410BL - Phase I
jwt(at)roadmapscoaching.c Guest
Posted: Wed Aug 29, 2007 3:58 am Post subject: Dimple challenged tonight |
I ended up filling all of the trailing edge rivets with either metal filler (Evercoat) before priming of with polyester filler (Easy Sand) after priming. You may be able to just fill this during finishing.
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Paint prep, interior, and LOTS of little stuff
Sent: Wednesday, August 29, 2007 6:13 AM
Michael
Thoughts, comments?
5No virus found in this incoming message. size=2>Version: 7.5.484 /
8/28/2007 4:29 PM
Posted: Wed Aug 29, 2007 4:39 am Post subject: Dimple challenged tonight |
As was already mentioned, it is the bottom skin, so the shop head of the
rivet will fill it. You can either use an Oops rivet or just use a longer
#3 rivet to fill the additional area. If you are worried about looks,
that will probably be filled when you fill the seam between the fairing
and the skin on the elevator. I don't know that I would be too worried
about the structural aspect of it. If you were worried, then you could
add an additional hole between that and the next good hole, although this
might be best done after the trailing edge is finished, in which case you
would need to machine countersink both sides, in which case the shop head
might not hold well on the bottom skin anyway. I doubt it is worth
replacing the skin, but that's up to you.
In the future, if you miss a hole, make sure to do it in a place that can
be easily filled with a simple rivet through the skin.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
352-427-0285
John Testement wrote:
| Quote: | Bob,
filler
John Testement
HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com
40321
Richmond, VA
_____
may
the
(Michael Sausen)
Michael
Murphy
things together.
Thoughts, comments?
http://forums.matronics.com
"http://www.matronics.com/Navigator?RV10-List"http://www.matronics.com/Navig
ator?RV10-List
"http://forums.matronics.com"http://forums.matronics.com
8/28/2007
4:29 PM
8/28/2007
4:29 PM
LloydDR(at)wernerco.com Guest
Posted: Wed Aug 29, 2007 5:22 am Post subject: Dimple challenged tonight |
Like everyone else is saying, rivet it and move on, you will have proseal and several other rivets to hold the trailing edge together. But in my opinion, I would not use an oops in the trailing edge because you would have to enlarge the hole in the wedge, and this is already a tight area. I would do as Jesse recommends and put in a slightly longer rivet, and be careful when setting it, so it does not cleat over and then fill the exposed hole, which is already backed by the wedge with proseal and sand it flat.
Just my .02
Dan
N289DT RV10E
Thoughts, comments?
Posted: Wed Aug 29, 2007 5:31 am Post subject: Dimple challenged tonight |
If you use an oops on the wedge, you will end up with the shop head side being way too big on the backside that is exposed for people to see, IE it will be real easy to see a -4 shop head when everything else is a -3. If the small extra dimple is bothering you, wait until you have a -4 in a line of -3's....but by the time you get to the end you will have forgotten about it, right up until Smoozer comes up and looks at the trailing edge and asks what you did there! LOL
Dan
Michael
Thoughts, comments?
5 [quote][b]
Kearney(at)shaw.ca Guest
Posted: Wed Aug 29, 2007 5:46 am Post subject: Dimple challenged tonight |
Hmmm
6nbsp;
What is the roleof the proseal in this aplicaton E I would hav thought that it is not structural but is merely holding the parts in alignment when setting up prior to rivetting etc E
6nbsp;
Inquiring minds need to know E E E E
6nbsp;
Les Kearney
340643
Posted: Wed Aug 29, 2007 6:11 am Post subject: Dimple challenged tonight |
flip the rivet over and have the smaller rivet head on the top side. Tim and others have riveted in opposite directions with their trailing edges so it's not uncommon.
Been there myself than when all was done I realized I couldn't even find some of my mistakes unless I specifically look for it.
Pascal
Posted: Wed Aug 29, 2007 6:14 am Post subject: Dimple challenged tonight |
Correct.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LES KEARNEY
Sent: Wednesday, August 29, 2007 8:45 AM
Subject: Re: RE: FW: Dimple challenged tonight
Hmmm
What is the roleof the proseal in this aplicaton. I would hav thought that it is not structural but is merely holding the parts in alignment when setting up prior to rivetting etc.
Inquiring minds need to know....
Les Kearney
#40643
rleffler
Posted: Wed Aug 29, 2007 6:22 am Post subject: Dimple challenged tonight |
Actually, Rick has given a suggestion that hasn't been mentioned here yet. Since he fiberglassed his tips, the last rivet will be hidden under the transition, so whether or not I use a longer rivet or an oops rivet, it would be hidden and add additional support.
The lesson I learned that if you get tired, just stop, even if you only have a little bit more to complete the task at hand.
Thanks for all the feedback!
Date: 2007/08/29 Wed AM 08:30:57 EST
Dan
_____
larger.
(Michael Sausen)
Michael
Murphy showed up and I screwed up. The attached picture isn't all that
good, but you can clearly see that I missed the hole and it's now
the elevator.
2. Find a way to make a repair that doesn't look too bad.
Thoughts, comments?
N410BL - Phase I
Posted: Wed Aug 29, 2007 6:40 am Post subject: Dimple challenged tonight |
It is only there for alignment during the riveting, but it will also add some adhesion, plus it will fill the hole and is sandable/ paintable.
Dan
Sent: Wednesday, August 29, 2007 9:45 AM
Hmmm
Les Kearney
#40643
AV8ORJWC
Posted: Wed Aug 29, 2007 7:29 am Post subject: Dimple challenged tonight |
Proseal has no effective purpose in the assemblage of a structural member. It has lots of great uses but this would not be one. Larger rivets when used on control surfaces create balance issues which VANS will tell you are not important. Then Ken Scott can repeat his presentation on “Flutter”.
Bondo is cosmetic. It brings back memories of fiberglass resin being used for everything back in the 60’s. Enough has been said to allow Bob the chance to do it right.
Do not Archive
Sent: Wednesday, August 29, 2007 6:45 AM
Hmmm
Les Kearney
#40643
carlosh(at)sec-engr.com Guest
Posted: Wed Aug 29, 2007 7:31 am Post subject: Dimple challenged tonight |
/"it is not structural but is merely holding the parts in alignment when
setting up prior to riveting"/
Almost verbatim from Ken at Vans when I called on a VERY similar question.
Carlos
LES KEARNEY wrote:
[quote] Hmmm
Les Kearney
#40643
Posted: Wed Aug 29, 2007 12:18 pm Post subject: Dimple challenged tonight |
Exactly my opinion aswell.
One additional thing you can do is glue in the fiberglass wingtip to take
more of the strain off the corner rivet with the bad hole. Make sure to glue
both rt and lf wingtips to keep it all syimetrical. make sure your botched
dimple fits well into the wedge countersink!!!!!!
This will not even show if you do a good job.
Remember, In WWll, a bullet hole in the skins didn't ground a plane and they
didn't put a new skin on either.
John G. 409 Hiatus, Last soaring day coming up this weekend.
| Quote: | From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Date: Wed, 29 Aug 2007 09:22:17 -0400
sand it flat.
Just my .02
Dan
N289DT RV10E
_____
the elevator.
Thoughts, comments?
