		pchapman(at)ionsys.com Guest
				 Posted: Wed Aug 29, 2007 11:57 am    Post subject: tuft test video - 601 HDS |
				I finally got around to doing a little video of some tuft testing on
 the 601 HDS I fly, filmed with a 0.3 wide angle lens on the camcorder.
 It is posted online at http://pcxstuff.blip.tv/file/356716/ and can
 also be downloaded as a 13MB .wmv file. It's not a particularly clear video.
 It was an unprofessional test, a flight with no detailed plan, on a
 dark, turbulent day, quickly done before the weather got any worse.
 But I haven't seen anything better, so this will have to do until I
 get around to trying again.
 In its nearly 2 minutes, the video basically shows slow flight,
 throttled back, with a few approaches down to incipient stalls. Audio
 was removed (including a lot of oil canning noise near the stall!),
 but some indicated speeds called out by the pilot are shown in text
 on screen. Speeds are typically low, eg 70 mph indicated before
 slowing down, then down to 50 or 40 indicated (naturally likely
 inaccurate) for the slow flight. The pitch angle against the horizon
 is an indication of the speed.
 At about 37 and 49 seconds seconds there are clear stall recoveries,
 after a lot of wing rock. I don't know if there was an actual stall
 break or the pilot simply let the stick forward once the bucking was
 getting enough.
 I haven't thought through it all yet myself, but a few observations
 are possible:
 -- One can clearly see the region of separated airflow spread
 outboard and forward as the wing gets closer to a stall.
 -- Even when in slow flight not right at a stall, a large area near
 the wing root doesn't have straight fore to aft flow. I'm not current
 on my aerodynamics, but a waving yarn might only indicate an area of
 a turbulence within a thick boundary lager, and not fully separated
 flow. One can't see the actual wing/fuselage junction, but even
 outboard of that, the flow isn't all front to back.
 --  It doesn't take much to mess up airflow right down on the wing
 surface, if closer to the leading edge.
 There's a yarn just behind of the aft, inboard Dzus fastener on the
 wing locker. Even when the plane dives with speed when recovering
 from a stall, that yarn doesn't like to stay straight. On the other
 hand, the yarn behind the top of the main wheel strut, also behind an
 obstacle, does stay straight. A quick guess is that the slight
 upwards bulge of the wing locker near the front of the locker is
 what's actually causing a flow problem, not the Dzus fastener. The
 slight bulge is far enough forward on the airfoil that the shape
 becomes critical, unlike for the gear strut which is further back.
 The yarn that is forward of the "behind the Dzus" one, is right on
 the locker, and it shows a tendency to lift off the surface rather
 than stay flat on the wing.
 -- There is substantial inwards flow near the trailing edge of the
 wing. Some is expected near the tip as the tip vortex rotates up and
 inwards. But at low speed  there's some inwards flow component along
 the aileron pretty much all the way inboard. Some inwards flow can be
 expected from a sharply forward swept trailing edge wing, but the
 amount is much more than I expected.
 -- Right when the plane is about to stall, it is impressive how many
 of those little yarns are trying to go the wrong way, to jump the
 aerodynamically sinking ship!
 Peter Chapman
 Toronto, ON
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gig Giacona
				 Posted: Wed Aug 29, 2007 12:23 pm    Post subject: Re: tuft test video - 601 HDS |
				Great video. I to looks like the air is really confused just aft of the inboard corner of the wing locker.
 I wonder if this is caused by the locker?
601XL Under Construction
		grs-pms(at)comcast.net Guest
				 Posted: Wed Aug 29, 2007 1:12 pm    Post subject: tuft test video - 601 HDS |
				Thanks for posting the video.  The wing locker is obviously disturbing the
 flow.  It would be interesting to locate an array of VGs at about 5% of the
 local chord in front of the locker area.  I'd bet on an improvement.  Also I
 notice that the tufts near the tip stay pretty well aligned as the angle of
 attack approaches the stall point.  Credit to Chris for that.
 How about tufting the canopy aft of the high point and along the top skin
 behind the canopy.  I'll bet there is considerable separation there, even at
 cruising speed.  I expect that Zodiacs pay a price for that great
 visibility.
 As for the area near the wing root, I wonder if a suitable fillet wouldn't
 improve that.
 George
 Do not archive.
		Gig Giacona
				 Posted: Wed Aug 29, 2007 2:40 pm    Post subject: tuft test video - 601 HDS |
				George wrote:
  	  | Quote: | 	 		  How about tufting the canopy aft of the high point and along the top skin
 Good idea.
 There's a single canopy tuft test picture that I took years ago, 3/4
 the way down the page:
   http://web.ionsys.com/~pchapman/zdc/zdc_photos_construction.htm
 (I haven't updated the 601 part of my website in years.)
  	  | Quote: | 	 		  As for the area near the wing root, I wonder if a suitable fillet wouldn't
 improve that.
 .. Like Dave Austin put on his plane. While the video showed an area
 of disturbed airflow much larger than a fillet, the video was all at
 low speed and not cruise.  (A small photo of Dave's fillet is on the
 same web page mentioned above.)
 Gig wrote:
  	  | Quote: | 	 		  Since you are doing tuft testing how about doing the side of they
 fuselage and find a good location for a static port.
 I'm NOT planning to duct tape the camera to the wingtip to look back inboard.
 Peter Chapman
 Toronto, ON
				 Posted: Wed Aug 29, 2007 3:50 pm    Post subject: tuft test video - 601 HDS |
				Peter:
 Nice set of pictures.  I wonder if VGs mounted on the aft canopy bow would
 be too far aft to improve the situation.  It should be relatively easy to
 attach them to the screws that tie the bow to the plexiglass and experiment
 a bit.  Ideally the VGs should be forward of the crown of the canopy, but,
 at least in your photo, the flow appears to remain attached aft of that
 point.
 George
		Terry Phillips
  Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
				 Posted: Thu Aug 30, 2007 6:43 am    Post subject: tuft test video - 601 HDS |
				Peter, thank you for posting the video. Very interesting results there. It
 is really great when someone takes the time and effort to produce real
 data, rather than just speculating--like I am doing
 Your study reminds me of the work that Klaus Truemper did on his HDS--see:
 http://www.utdallas.edu/~klaus/Airplane/airplane.html
 and follow the link to the wing root fairing. Klaus used a manometer to
 look at the pressure at various points on his HDS and demonstrated that the
 curvature of the fuselage over the wing creates a low pressure region at
 the wing root aft of the widest part of the fuselage. Klaus built wing root
 fairings that reduced the effect of the low pressure zone and improved the
 performance and stall behavior of his aircraft. Is it possible that the
 inward flow at the aileron is caused by the low pressure region all the way
 in at the wing root? I plan to put fairings on my 601XL, but I'm hoping
 that someone will start selling them before I get to that point so that I
 don't have to make them myself.
 The turbulence around the wing locker is troubling. I am putting in the
 wing lockers, and I am planning to use flexible tape to cover the hinge.
 Soaring pilots commonly use tape to seal gaps, see, e.g.,
 http://www.wingsandwheels.com/page29.htm
 My goal was primarily to seal the rain out. However, there might be a
 fringe benefit of reducing boundary layer separation caused by the locker
 door hinge. The separation along the inboard side of the wing locker door
 could be caused by air leakage from the inside of the wing. The bottom of
 the wing is a high pressure area. I'm guessing that the inside of the wing
 is pressurized through any small opening on the bottom of the wing. There
 appears to be a gap along the inside edge of the locker door. Leakage
 through that gap could induce separation, and your video suggests that is a
 problem area on that wing. It would be interesting to know if taping that
 gap would affect the separation in that zone. If leakage is causing the
 problem, possible fixes might be to use more Dzus fasteners along the door
 edge, putting a thin gasket to improve the seal, or stiffening the door by
 gluing or riveting on longitudinal doubler strips to the inside of the door.
 Thanks again for posting the video. Nice work.
 Terry
 At 03:54 PM 8/29/2007 -0400, you wrote:
 I finally got around to doing a little video of some tuft testing on the
 It is posted online at http://pcxstuff.blip.tv/file/356716/ and can also
 It was an unprofessional test, a flight with no detailed plan, on a dark,
 turbulent day, quickly done before the weather got any worse. But I
 haven't seen anything better, so this will have to do until I get around
 to trying again.
 In its nearly 2 minutes, the video basically shows slow flight, throttled
 back, with a few approaches down to incipient stalls. Audio was removed
 (including a lot of oil canning noise near the stall!), but some indicated
 speeds called out by the pilot are shown in text on screen. Speeds are
 typically low, eg 70 mph indicated before slowing down, then down to 50 or
 40 indicated (naturally likely inaccurate) for the slow flight. The pitch
 angle against the horizon is an indication of the speed.
 At about 37 and 49 seconds seconds there are clear stall recoveries, after
 a lot of wing rock. I don't know if there was an actual stall break or the
 pilot simply let the stick forward once the bucking was getting enough.
 I haven't thought through it all yet myself, but a few observations are
 possible:
 -- One can clearly see the region of separated airflow spread outboard and
 -- Even when in slow flight not right at a stall, a large area near the
 wing root doesn't have straight fore to aft flow. I'm not current on my
 aerodynamics, but a waving yarn might only indicate an area of a
 turbulence within a thick boundary lager, and not fully separated flow.
 One can't see the actual wing/fuselage junction, but even outboard of
 There's a yarn just behind of the aft, inboard Dzus fastener on the wing
 locker. Even when the plane dives with speed when recovering from a stall,
 that yarn doesn't like to stay straight. On the other hand, the yarn
 behind the top of the main wheel strut, also behind an obstacle, does stay
 straight. A quick guess is that the slight upwards bulge of the wing
 locker near the front of the locker is what's actually causing a flow
 problem, not the Dzus fastener. The slight bulge is far enough forward on
 the airfoil that the shape becomes critical, unlike for the gear strut
 which is further back. The yarn that is forward of the "behind the Dzus"
 one, is right on the locker, and it shows a tendency to lift off the
 surface rather than stay flat on the wing.
 -- There is substantial inwards flow near the trailing edge of the wing.
 Some is expected near the tip as the tip vortex rotates up and inwards.
 But at low speed  there's some inwards flow component along the aileron
 pretty much all the way inboard. Some inwards flow can be expected from a
 sharply forward swept trailing edge wing, but the amount is much more than
 I expected.
 -- Right when the plane is about to stall, it is impressive how many of
 Peter Chapman
 Toronto, ON
 Terry Phillips
 ttp44~at~rkymtn.net
 Corvallis MT
 601XL/Jab 3300 slow build kit - Rudder done--finally; working on the stab
 http://www.mykitlog.com/N47TP/
  _________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
				 Posted: Thu Aug 30, 2007 8:14 am    Post subject: tuft test video - 601 HDS |
				At 10:37 30-08-07, you wrote:
  	  | Quote: | 	 		    Is it possible that the inward flow at the aileron is caused by
  the low pressure region all the way in at the wing root?
 For all I know, sure, it could be encouraging some of that inwards flow.
  	  | Quote: | 	 		  There appears to be a gap along the inside edge of the locker door.
 Yes that particular locker door is a little bulged in spots -- I
 think a snugly fitted door would do better. Just didn't come out
 perfectly when built. Next time I should put yarn right next to those
 gaps to see if I can detect outflow -- or tape up the gap for one
 flight. I personally wouldn't worry about gap taping the hinges given
 all the other drag sources, and because water can also leak in from
 the sides. But no objections if one can get it to fit snugly over the
 hinge. (I did use some sort of gap seal like tape on the top wing
 skin where the locker doors press on them when closed, to try to
 reduce any metal on metal (or metal on paint) rubbing.)
 I sometimes thought of doing water manometer tests of pressures in
 the rad ducting in my engine compartment... and now that I've looked
 again at Klaus' page, I see he has done exactly that.
 Peter Chapman
 Toronto, ON
