was Re: Re: autopilot install- now which one?
rv10builder(at)verizon.ne
PostPosted: Wed Aug 29, 2007 4:29 pm    Post subject: was Re: Re: autopilot install- now which one? Reply with quote
As always, thanks for the insight Tim. Want simple; tried and true, will go
with Trutrak the problem is do I spend $2350 for a top notch servo to fit
the RV-10ap, and sorcerer or will the simple $1000 cut it.. that is my
dilemma.
So survey here (for everyone):
which AP version was bought and would get/recommend (trutrak only) based on
flying the RV-10.
Is the Van's Aileron trim equal to the Aerotrim Jesse keeps suggesting?
either one work better in one way.. etc.
Thanks!
Pascal
Deems Davis
PostPosted: Wed Aug 29, 2007 5:03 pm    Post subject: was Re: Re: autopilot install- now which one? Reply with quote
Pascal, I may be wrong, as I'm electron challenged, but I believe that
the Tru Trak AP requires their servos, not sure they will work with
others. IIRC TT either updated their servo or recommmended one of their
larger servo's for the -10.
I went with the Digiflight VSVG , with vertical steering from the OP (in
development but not yet available) I can fly WAAS overlay approaches and
will not require the ILS from the Sorcerer. (At least that's what my
reasoning has been to this point :-\ ).
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
will go with Trutrak the problem is do I spend $2350 for a top notch
servo to fit the RV-10ap, and sorcerer or will the simple $1000 cut
it.. that is my dilemma.
based on flying the RV-10.
suggesting? either one work better in one way.. etc.
Thanks!
LloydDR(at)wernerco.com
PostPosted: Thu Aug 30, 2007 5:25 am    Post subject: was Re: Re: autopilot install- now which one? Reply with quote
I have the Sorcerer, will be adding Yaw to it, and I have Van's Aileron
trim. Both packages are nice and simple to install, and can both be done
after the fact, because I did it that way because the wings went to
paint early. But, and let me stress this but, I am in total agreement
with Tim that it is much easier to do it before the wings are on. There
is safety wire and several other things that need to be done that are
much easier when looking at it in the wing cradle, rather than trying to
reach up from a crawler on the floor. The next one I do will have
everything done in the wings before they are attached.
Dan
N289DT RV10E Flying
PostPosted: Thu Aug 30, 2007 8:43 am    Post subject: was Re: Re: autopilot install- now which one? Reply with quote
Thank you to those who responded with feedback. I called TT this morning and
discovered that regardless of which AP I decide to go with I (as does anyone
with a -10) need the servo specific to the RV-10 ($2350) as it includes the
Torque enhancer that the other servos don't need.
So I now know I need to get the AP servo while building and I appear to have
one choice on the servo anyway.
Again thanks for the guidance.
Pascal
40720 Wings shipped!
Tim Olson
PostPosted: Thu Aug 30, 2007 9:00 am    Post subject: was Re: Re: autopilot install- now which one? Reply with quote
That's a pair, right? I mean, the whole DFIIVSGV autopilot is
under $5K.
and discovered that regardless of which AP I decide to go with I (as
does anyone with a -10) need the servo specific to the RV-10 ($2350) as
it includes the Torque enhancer that the other servos don't need.
have one choice on the servo anyway.
Pascal
PostPosted: Thu Aug 30, 2007 9:25 am    Post subject: was Re: Re: autopilot install- now which one? Reply with quote
I remember it being around $2k for the servo's and the remainder was
based on what APhead you bought
Dan
