Tim Olson
Deems Davis
Posted: Wed Aug 29, 2007 6:21 pm Post subject: Wingtip lens |
It's mine and all it is is silver rattle can paint applied from the
inside of the lens. Jeff Bordelon (my LED nav/strobe lite guy) did this
to his plane and I shamelessly copied it!
Deems
David Maib wrote:
That really looks great, Deems. Is that your airplane? What is the material that is covering the nut plates?
David
On Wednesday, August 29, 2007, at 05:53PM, "Deems Davis" <deemsdavis(at)cox.net> wrote:
> Here's another idea that 'hides' the nut plates and I think gives a bit
> of decoration.
> http://deemsrv10.com/album/LED%20Nav%20&%20Strobes/slides/DSC02219.html
> Deems Davis # 406
> 'Its all done....Its just not put together'
dmaib@me.com
Posted: Wed Aug 29, 2007 7:02 pm Post subject: Wingtip lens |
And I shall shamelessly copy both of you! ^_^
David
On Wednesday, August 29, 2007, at 09:27PM, "Deems Davis" <deemsdavis(at)cox.net> wrote:
Deems
> David
>> of decoration.
>> Deems Davis # 406
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
dmaib@me.com
Posted: Wed Aug 29, 2007 7:03 pm Post subject: Wingtip lens |
Now that looks like a "nuclear hardened" wingtip lens!
David
On Wednesday, August 29, 2007, at 09:00PM, "Robin Marks" <robin1(at)mrmoisture.com> wrote:
| Quote: | I also thought we needed a few more screws:
That should do it!
Robin
RV-10 #40559
coop85(at)cableone.net Guest
Posted: Wed Aug 29, 2007 7:36 pm Post subject: Wingtip lens |
Same thoughts as Scott. I have 194 hours with multiple runs a high speed with no issues on just 2 screws, but a few extra might provide some peace of mind.
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Wednesday, August 29, 2007 3:53 PM
Subject: Re: Wingtip lens
Just to be the different one, I used only two screws and I have a great fit and so far I've had no problems.
I've flown near the Vne 200 kts TAS and no problems. Adding more screws makes sense though.
It is not like you take the lens on and off very often and it doesn't hurt.
So those of you with 2 screws, don't get too nervous. It will work great and you will be able to care a couple more
dimes in your pockets at gross.
Scott Schmidt
scottmschmidt(at)yahoo.com
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
glastar(at)gmx.net Guest
LloydDR(at)wernerco.com Guest
Posted: Thu Aug 30, 2007 5:45 am Post subject: Wingtip lens |
And I copied yours! But used blue instead so they match my paint stripe
out there...we all copy the good ideas, and Deems has allot of them and
freely shares.
The RV community is great about that, each of us trying to build a
better mousetrap and sharing that info with others!
Dan
N289DT RV10E
robin1(at)mrmoisture.com Guest
Posted: Thu Aug 30, 2007 8:02 am Post subject: Wingtip lens |
I was just goofing around at my second home on a laptop with only the
touchpad and very limited time before flying out ahead of some
thunderstorms. Next time I email a Twin RV-10 I will take greater care
in cleaning up the photo.
Robin
ddnebert
Posted: Thu Aug 30, 2007 6:23 pm Post subject: Re: Wingtip lens - strobe light lens |
| Deems Davis wrote: | It's mine and all it is is silver rattle can paint applied from the
Deems
I see you do not have a glass globe on your strobe. Is this not something to worry about?
Doug Nebert
Builder # 40546 - in the wings
_________________ RV-10 Builder #40546
Tail mostly done, wings complete, end of SB fuse, working on doors and fiberglass |
Deems Davis
Posted: Thu Aug 30, 2007 7:06 pm Post subject: Wingtip lens |
It's not something I'm worrying about at the present. What is the hazard
and related consequence that would be avoided with a glass cover? I'm
not trying to be smart, I really don't know. The strobe is 'protected'
from direct moisture by virtue of the plexi.
Deems Davis # 406
ddnebert wrote:
> Deems
Doug Nebert
http://forums.matronics.com/viewtopic.php?p=131953#131953
