George McNutt
Posted: Fri Feb 17, 2006 12:03 am Post subject: SS firewall penetration |
Hi Bill
I was thinking of using JB Weld, is the fire temperature rating for the
itumescent caulk higher than the 500 degree F. rating for JB Weld?
George in Langley BC
I have the itumescent caulk from the Aviation department at Lowe's. That was the easy part.
-Bill B
chaztuna(at)adelphia.net Guest
Posted: Fri Feb 17, 2006 5:31 am Post subject: SS firewall penetration |
George,
The firewall sealant should be of a flexible nature, as there is
significant flexing in this area. I doubt that JB weld would be suitable there.
Charlie Kuss
Hi Bill
>-Bill B
nuckollsr(at)cox.net Guest
Posted: Fri Feb 17, 2006 5:36 am Post subject: SS firewall penetration |
At 12:02 AM 2/17/2006 -0800, you wrote:
Hi Bill
Much higher. JB Weld is not rated for effects of a fuel-fed fire.
It's a filled epoxy not a self protecting putty. You can
test it yourself for suitability but it's a lot of work.
I'd recommend you stay with materials designed and tested
to the task.
dennis.glaeser(at)eds.com Guest
Posted: Fri Feb 17, 2006 10:03 am Post subject: SS firewall penetration |
Is there firesleeve available to work with the Home Depot 1.5" SS grab
bar for roll-your-own firewall penetrations? If so, what "hose size" do
I look for to equal 1.5" ID or OD? I'm getting the feeling after
bringing home a 1.5" grab bar that I should have ordered the 1.25" stuff
from McMaster-Carr. Even so, I'm still not sure what stock # of
firesleeve will fit this. Any tips? Thanks. I have the itumescent caulk
-Bill B
Bill,
Check out this website: http://www.racerpartswholesale.com/aero6.htm
They have ID's listed up to 1.5"
Dennis Glaeser
7A Fuselage
sportav8r(at)aol.com Guest
Posted: Fri Feb 17, 2006 11:26 am Post subject: SS firewall penetration |
Good resource; thanks!
-Bill
retasker(at)optonline.net Guest
Posted: Sat Feb 18, 2006 11:26 am Post subject: SS firewall penetration |
Heck, McMaster Carr has it in sizes up to 4" diameter for "standard"
grade and up to 3" for "aerospace" grade.
See www.mcmaster.com , and enter 737 in the search window and it will
go to page 737 where the sleeve is shown about half way down.
Lots cheaper than www.racerpartswholesale.com, too.
Dick Tasker
-Bill
Posted: Sat Feb 18, 2006 2:53 pm Post subject: SS firewall penetration |
Thanks- that's a good resource. I have to order my grab bar from them anyway, most likely.
