Paul Valovich
Posted: Thu Aug 30, 2007 7:20 am Post subject: Precision Airmotive Eagle EMS |
Indecision is once again the key to flexibility! After several job-related delays, I’m REALLY at the engine-ordering stage of my -8A project. I’ve decided on an Aerosport 180 hp fuel injected engine and initially thought dual Lightspeed ignition was the way to go. However, I’ve now heard of the Precision Airmotive Eagle EMS and am somewhat intrigued.
Anyone have any experience – or opinions?
Paul Valovich
Ridgecrest, CA
N192NM Reserved
ronlee(at)pcisys.net Guest
Posted: Thu Aug 30, 2007 9:31 am Post subject: Precision Airmotive Eagle EMS |
While it sounds interesting I would like to see reasonable field use reports.
I am not one to be an early adopter of new aviation items like this. Nor am
I a fan of FADEC like systems. I have seen one and it struck me as too
complex, expensive, possible heavy and it "may" have been at fault in the
forced landing of a 7A that was essentially destroyed.
I like to lean my mixture after start up to taxi and after landing to minimize
plug fouling. That apparently is not possible with this system so I would
guess (not verified) that foiled plugs may be more common than with my
carbureted, manually leaned system.
I definitely see no reason to change from what I have. With a new purchase
it may make sense for some but with my perhaps close-minded view, I would
stick with your original plan.
A mag and one Lightspeed do provide different ignition failure modes.
Ron Lee
Posted: Thu Aug 30, 2007 9:33 am Post subject: Precision Airmotive Eagle EMS |
I just reread your ignition choice and see that you are planning DUAL
Lightspeeds versus my one (plus a mag). Lightspeed is the only system
that I would do that with.
Ron Lee
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Thu Aug 30, 2007 10:09 am Post subject: Precision Airmotive Eagle EMS |
I talked with them this year at SnF and was also intrigued. I really don't know where I would install the large CPU module, though. I also understand that it is still in development with only one model actually being tested..i.e. there is NO history yet on how well it performs.
Gonna watch closely...
Bret Smith
RV-9A "Fuselage"
Blue Ridge, GA
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
Posted: Fri Aug 31, 2007 7:03 am Post subject: Precision Airmotive Eagle EMS |
Another opinion. This is from today's AOPA newsletter. Note the part about the FADEC resetting.
DOUBLE ENGINE FAILURE PROMPTS DIAMOND AD PROPOSAL
The FAA is proposing an airworthiness directive (AD) for the Diamond DA42 Twin Star. The AD would require additional backup batteries for the full authority digital engine controls (FADECs) on TAE125-01 and TAE125-02-99 engines. This action was prompted by the in-flight shutdown of both TAE 125-01 engines on a DA42 flying over Germany in March. The pilot of the aircraft took off with an insufficiently charged aircraft battery. During a moment of low voltage when the aircraft's landing gear was retracting, the FADEC reset. This shut down the engines and caused the propeller blades to feather. Diamond has said that it will cover the cost of the battery installation, regardless of an AD. For more information, see Diamond's service bulleti! n."
Source AOPA ePilot, Volume 9, Issue 35 • August 31, 2007
