Amber residue in 912 intake Model 4-1200
Goto page 1, 2  Next
Giovanni Day
PostPosted: Fri Aug 31, 2007 6:08 am    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
I have about 20 hours on my model 4 1200 now. The last time I flew it was not running the best. Went out to fly last night and it would not run without the choke at all. Pulled the carbs off and there is a thick amber residue lining the intake and the inside of the carbs. The engine is not new and I never have seen this before. It was not there 20hours ago. It seems the fuel has something in it doing this. Any help in figuring out what it is would help.
_______________________________________
Giovanni Day
Model 4 speedster 912
akflyer
PostPosted: Fri Aug 31, 2007 6:15 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
sounds like varnish. How long ago was the last time you flew it or ran it?
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
thesupe(at)hotmail.com
PostPosted: Fri Aug 31, 2007 6:27 am    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
Just a bit of a guess, but are you running gas with ethonal (alcohol) in
your fiberglass tanks? If so, perhaps the tanks are disolveing. ???
Alcoho will melt some fiberglass resins. Jim Chuk Avid/Jab
Subject: Amber residue in 912 intake Model 4-1200
Date: Fri, 31 Aug 2007 07:08:22 -0700
not running the best. When out to fly last night and it would not run
Giovanni Day
http://forums.matronics.com/viewtopic.php?p=132010#132010
Booking a flight? Know when to buy with airfare predictions on MSN Travel.
http://travel.msn.com/Articles/aboutfarecast.aspx&ocid=T001MSN25A07001
kitfoxmike
PostPosted: Fri Aug 31, 2007 7:38 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
To check for the tanks coming apart you can do a check of the tanks by draining some fuel out the check valves at the bottom of the tank, you can also take a flash light and look inside the tank and slosh the tanks around. My guess is that the fuel is real old. Take a rubber hose about 3/8 size and about 4 ft long and shove it down in the tank and then take a straight razor blade and put a small cut in the end and then use compressed air and shot some into the crack you made to cause a siphon then let it drain into a tank and either throw it away or put it in your vehicle. Then put some fresh 89 octain fuel in. I find 89 to run the best in mine.
After all this take and buy some brake cleaner in a can, remove the bowls and take apart each circuit, there are three, and force the brake fluid through each, the one right in front of the main jets are the most important, this has a circuit for air bleed that goes right to the intake of the carb, it has a really tiny hole, remove the filter so that you can see the brake fluid coming out the hole, chase it with compressed air afterwards. Don't neglect doing this, I know about the bings doing this, mine did this same exact thing. It's also important to have good hoses, fuel injection hose for in the engine compartment and the blue bing hose from the tanks to the firewall.
hope this helps
Giovanni Day
PostPosted: Fri Aug 31, 2007 8:55 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
The plane has not sat and the fuel is not old. Some one has suggested that the MTBE is melting the tank. Is there a coating I can put in it?
Giovanni Day
kitfoxmike
PostPosted: Fri Aug 31, 2007 9:56 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
I would like to add a note on the fix for my carb problems. It was the air filters. What I found happening was the filters started coming apart, yup the little fibers went right into the air bleed that I talked about for the mid range. I had K&N filters. I bought new ones, they ended up being the bigger ones. I also bought the charge system for them also, I think I need to do it because the redness is going away from the bottom of the filters, after this weekends flyin at homedale I plan on doing them.
kitfoxpilot(at)msn.com
PostPosted: Fri Aug 31, 2007 10:09 am    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
I use KN filters also, everytime I clean my filters, I use the re-charge kit
and re-coat them with the red spay after they have dried.
Ray
Subject: Re: Amber residue in 912 intake Model 4-1200
Date: Fri, 31 Aug 2007 10:56:38 -0700
kitfoxmike
model IV, 1200
speedster
912ul
building
RV7a
slowbuild wings, fuse, finish kit
&quot;if you're not getting razzed from pilots or the FAA then you're not
flying enough&quot;
http://forums.matronics.com/viewtopic.php?p=132074#132074
A new home for Mom, no cleanup required. All starts here.
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
kitfoxmike
PostPosted: Fri Aug 31, 2007 10:26 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
That's what I plan on doing with mine, use the recharge kit. What happened to my old ones is brake cleaner got on them and litteraly distroyed them. Make sure and remove the filter before cleaning the carbs.
Giovanni Day
PostPosted: Fri Aug 31, 2007 10:46 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
I went out with some carb cleaner from wally world and it took the stuff right off. Took the bowls off and clean the carbs with it realy good. It was not hard to get them clean at all. Makes me wonder if it is really the tanks. I will see if the inside of the tanks feel gooey.
One note: There is no residue or fibers in the gascolator.
Giovanni Day
kitfoxmike
PostPosted: Fri Aug 31, 2007 10:54 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
make sure you unscrew the jets inside and force the carb cleaner through the opening. You have to get a small screwdriver in there and unscrew it, it has an oring and a long tube with a hole on the end and several holes on the side, I haven't seen that plug up but the inside of the carb that goes to the opening of the carb sure does. Put the plastic extension on the carb can and stick it up the opening and fire away until it comes out the little opening at the opening of the carb.
Giovanni Day
PostPosted: Fri Aug 31, 2007 10:59 am    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
I guess if I run 100LL that this might solve the problem. No ethanol or MTBE correct??
Giovanni Day
kerrjohna(at)comcast.net
PostPosted: Fri Aug 31, 2007 11:23 am    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
100LL can bring its own set of problems with lead build up. Special provisions are required with a straight diet of 100LL
Archi [quote][b]
barry(at)pgtc.com
PostPosted: Fri Aug 31, 2007 12:21 pm    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
Giovanni, if the amber coating is on the inlets to the carbs it must have
come from the filters or through the filters.
Barry West
Giovanni Day
PostPosted: Fri Aug 31, 2007 12:24 pm    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
There was very little on the inlet side of the carbs, realy almost none. On the side after the slide it was thick enough to scrape with my fingernail.
Good point about the 100LL. It is just like medicine. I feel at this point though I want to trade the tank cancer for a the manageable clogging of the arteries. Unless someone has a better solution to fix the tank cancer.
I will be sure to run conventional oil and change it more frequently. What else do I need to do to run 100LL on the 912? Thanks for all the good comments.
I checked my fuel source. They have stopped MTBE and started ethanol. Seems tanks with vinyl ester resins have less trouble. Maybe I could give my tanks a coat of it?
Giovanni Day
kitfoxmike
PostPosted: Fri Aug 31, 2007 1:34 pm    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
Well, the other thing to do is put in tcb. I think that's what it's called. Some marvel mystery. Last but not least. do a decarbin of the engine on a frequent basis. You will have a white coating on the exhaust valves, just remove the muffler system and take a looksy after using 100ll.
Float Flyr
PostPosted: Fri Aug 31, 2007 4:21 pm    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
MTBE won't do that but ethanol sure will!
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Aug 31, 2007 4:54 pm    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
True but you may have to change your plugs more often. If you can get
ethanol clean MOGAS ( wash the eth out with water) you can mix that with
100LL, around 50:50 and make a good fuel. Don't forget the lead can plate
out on the roller bearings of your crankshaft on a two stroke engine.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Giovanni Day
PostPosted: Fri Aug 31, 2007 4:59 pm    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
I had not thought about MOGAS. If it has no MTBE or Ethanol I can use it. I guess the real question it how long it will be available.
Giovanni Day
pwmac(at)sisna.com
PostPosted: Fri Aug 31, 2007 5:43 pm    Post subject: Amber residue in 912 intake Model 4-1200 Reply with quote
I think MTBE is gone. The phase out started several years ago only
to be replaced by ethanol. To bad because MTBE was not a concern. The
fuel companies once forecast that straight MTBE would be used to
replace 100LL. Unleaded gas without MTBE or Ethanol for your car is
available, but must be purchased out side the EPA control areas. Like
here in CO once you leave the Denver & Colo Spr populated areas you
can find it. Here in S CO we get good gas. but it has low octane due
to altitude.
Question: If you buy Mogas at the airport is it free if ethanol?
Paul
Giovanni Day
http://forums.matronics.com/viewtopic.php?p=132161#132161
Giovanni Day
PostPosted: Fri Aug 31, 2007 5:51 pm    Post subject: Re: Amber residue in 912 intake Model 4-1200 Reply with quote
I realy doubt that MOGAS is ethanol free. I will find out in the next few days. Are new kitfox kits with poly tanks or still fiberglass? Does someone make poly tanks to replace mine? Thanks again..
Giovanni Day
Goto page 1, 2  Next
Page 1 of 2
