Did It Again.
Goto page Previous  1, 2
PostPosted: Tue Sep 04, 2007 9:19 am    Post subject: Did It Again. Reply with quote
> 2. Is it "legal" to land on a taxi way.....
I don't understand why you couldn't enter the pattern ,
> Mike & "Jaz" in MN
Mike:
My thoughts on your questions. Forgive me for commenting late. Been out of
town for a couple days.
Not legal to land on a taxiway unless it was a dire emergency.
Don't need a radio to enter traffic and land. However, an ultralight
vehicle has last priority in the chain. Everyone else has priorty over an
UL vehicle, legally. I think I could have probable found a way to get in
the pattern and land without landing on the taxiway.
jindoguy(at)gmail.com
PostPosted: Tue Sep 04, 2007 12:39 pm    Post subject: Did It Again. Reply with quote
And then there are the four magic words, if you have a radio. That gets you to the top of the food chain, post haste. Just be able to prove it afterward, should you be asked.
Rick
On 9/4/07, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:[quote] --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
> Mike & "Jaz" in MN
Mike:
"Ya'll drop on in"
takes on a whole new meaning
APilot(at)webtv.net
PostPosted: Tue Sep 04, 2007 6:21 pm    Post subject: Did It Again. Reply with quote
Not legal to land or takeoff from a taxi way? Tell that to the Navy and
Marines. They do not obey any laws except their own. A Marine
helicopter took off from a taxiway when I was landing at an airshow and
turned me and my ultralight upside down. I requested that they pay for
the damage of $1200 and they blew me off for the second time. What is
their famous saying?...."Kill them all and let God sort it out."
APilot(at)webtv.net
PostPosted: Tue Sep 04, 2007 6:23 pm    Post subject: Did It Again. Reply with quote
I just ordered enough Max-Gain "E" fiberglass 1.5" dia rods for 3 gear
legs. Will let you know if they do the job that the 7075-T6 legs do
not.
PostPosted: Tue Sep 04, 2007 6:38 pm    Post subject: Did It Again. Reply with quote
not.
Maybe you need to change pilot technique.
I still bend heat treated 4130 legs. Still trying to change my landing
technique. Don't bend'em unless I drop it in.
APilot(at)webtv.net
PostPosted: Tue Sep 04, 2007 6:56 pm    Post subject: Did It Again. Reply with quote
You are absolutely right. I should wheel land. Actually, I am not all
that critical of the aluminum legs because I know that they have saved
my fuselage several times. I have also appreciated my tension wires
between the axles. I snapped two of them recently and the gear leg
stayed straight. Lets hope that my experiment with the fiberglass will
solve all the problems. The danger is: If one should break....there
goes a wing. I plan to over sleeve the lower stress riser. We shall
see. I often wonder why Kolb has not tried this over the years and made
a report on it. Max-Gain has supplied many axles/legs for Challengers
with good success. With the gear reliable and with a good 4 cycle
engine such as the 912, Geo, HKS etc., the Kolb will be the most perfect
"Fun" airplane that I have ever flown. So good, in fact, I may go
somewhere in it someday.
herbgh
PostPosted: Tue Sep 04, 2007 7:02 pm    Post subject: Did It Again. Reply with quote
Copy paste from Challenger list:
"Hello. I too have a Challenger II LW and use fiberglass gear legs and I'm
just delighted about them. They absorb shock very well whereas aluminum legs
will absorb loads but sometime stay bent.
You can buy them from
SKYES THE LIMIT! - Mike Harrison
Phoenix AZ
602-938-9735
Harrison3(at)cox.net
or in Canada
Turbulence Aviation
http://www.turbulence.ca/an
or better still, you can make your own from stock fiberglass rods at a
fraction of the price, at Max Gain System.
http://www.mgs4u.com/fiberglass-tube-rod.htm
An 8 foot rod would cost you about $60.00." End quote
Main thing is to save the cage..abt 2.5 k or so on the Firefly and goes up from there.. Smile Herb
gear
do
not.
Email BR>> Archive and much href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
nbsp; available href="http://forums.matronics.com">http://forums.matronics.com
ElleryWeld(at)aol.com
PostPosted: Wed Sep 05, 2007 12:23 am    Post subject: Did It Again. Reply with quote
Just my opinion but better landing technique like John said would save you gear legs and embarrassment and the trouble of trying to be an engineer
comment from the Peanut Gallery
Ellery
gaman(at)att.net
PostPosted: Wed Sep 05, 2007 12:49 pm    Post subject: Did It Again. Reply with quote
I have tried the fiberglass gear legs,made up the axle fabrications and really like the way they level out the ride taxiing on rough ground.But they don't fit the cage well,ID of the sockets is a bit larger,and after ten Hrs,I took them off and saw the pressure points wearing on the glass from the sockets.I tried brass shim stock to line the sockets,and that seemed to cure that.But if you pull your plane backward into a trailer after every flight as I do, the flex in the legs makes them toe out as you pull it backwards and it gets real hard to pull uphill.The final reason I pulled them was I could not get a firm quote on the breaking point of the 1 1/4 rods at the length we use.
All this probably gives you some insight into my ability to execute smooth landings with any regularity,but if anyone wants to try them,the legs are here with the steel fabrications attached,and mountings holes drilled.They are painted black. You may have them for the come and gett'in
herbgh(at)juno.com wrote:[quote]
Phoenix AZ
602-938-9735
or in Canada
Turbulence Aviation
[quote] gear
do
not.
nbsp; available [quote][b]
pj.ladd(at)btinternet.com
PostPosted: Thu Sep 06, 2007 9:19 am    Post subject: Did It Again. Reply with quote
As I am flying an ultralight vehicle, I am supposed to give way to all
other flying aircraft.>>
Hi,
that is a problem that we dont have in the UK. Steam still gives way to
sail at sea but in the air a plane is a plane is a plane.Except that we all
give way to balloons.
Are you persona non grata because you are unregistered? All aircraft are
registered here. Gliders in the UK but not in Europe have been unregistered
for years but even the gliders have lost that distinction recently in our
rush to regularise things across Europe.
Interesting the way our systems differ. As usual there are swings and
roundabouts(carousels). The problems about selling or registering a plane
by someone other than the builder which is a hot topic on the list at the
moment is just something which does not arise here. On the other hand we do
not have the freedom of your Experimental category .
We have moved a little way toward it though by allowing a really light
ultralight to be built without having to receive a C of A. It will have to
have a noise certificate however and be registered.
The dead hand of bureaucracy is everywhere. Lucky you in spite of the
problems seem to have more freedom left than most of us.
Cheers
Pat ( Still waiting for the paperwork to arrive so that I can test fly my
repaired Xtra.)
gaman(at)att.net
PostPosted: Fri Sep 07, 2007 6:10 am    Post subject: Did It Again. Reply with quote
you share the same dilemma we all have.You can give way or you can carry on till impact.
pat ladd <pj.ladd(at)btinternet.com> wrote:[quote] --> Kolb-List message posted by: "pat ladd"
Hi,
Interesting the way our systems differ. As usual [quote][b]
russ(at)rkiphoto.com
PostPosted: Fri Sep 07, 2007 6:57 am    Post subject: Did It Again. Reply with quote
My approach always has been "if there's a conflict, he wins". We can sort it out later if we're still alive.On boats, if he's a lot  bigger he has the right-of-way. But I still blow 7 blasts to let him know (and everyone else within  earshot) he's being an  idiotdo not archive
On Sep 7, 2007, at 10:10 AM, gary aman wrote:
[quote]you share the same dilemma we all have.You can give way or you can carry on till impact.
Hi,
JetPilot
PostPosted: Sat Sep 08, 2007 7:49 pm    Post subject: Re: Did It Again. Reply with quote
I have flown without a radio, lots of guys do. I really like having a radio for traffic but it is not required, and if my radio is out for some reason, I still fly.
As far as landing on a taxiway, that is a HUGE NO NO even for an ultralight. If no one has said anything to you, consider yourself very lucky. There is no exemption just because you are an ultralight, if an FAA guy or the wrong person ever sees you take off or land on a taxiway, you will have major problems. I cannot think of a better way to get very unwanted attention. We all stretch the rules or even ignore them sometimes, but landing on a taxiway is not one I would ever consider doing. That rates right up there with flying over the White House, or buzzing the control tower Wink
Kolb MK-III Xtra, 912-S
a58r(at)verizon.net
PostPosted: Sun Sep 09, 2007 9:37 am    Post subject: Did It Again. Reply with quote
Re: statement that "landing on a taxiway is forbidden," I reiterate
that at OKV ULs ARE SUPPOSED TO OPERATE (land/takeoff) FROM NORTH END
OF TAXIWAY.
We don't have a twr, thank goodness, but do have Unicom for our 5600
rnwy. I'll quote exact para. when I go out next week. The use of the
taxiway was a compromise between restricting ULs completely, and
allowing some operation. I was chrm of Airport Advisory Cmte.
regards,
Bob N. FireFly 070 Old Kolb
Steve Boetto
PostPosted: Sun Sep 09, 2007 9:48 am    Post subject: Did It Again. Reply with quote
In a message dated 9/8/2007 11:51:19 P.M. Eastern Daylight Time, orcabonita(at)hotmail.com writes:
I seem to remember that Lakeland used the taxiway as the main landing strip during SnF. Is my memory wrong?
Steve B
Firefly 007/Floats
Make AOL Your Homepage.
Page 2 of 2
