Bending Brake for 701
JerryHey
PostPosted: Wed Sep 05, 2007 11:50 am    Post subject: Bending Brake for 701 Reply with quote
What length bending brake is needed for the 701? I have a good
brake but only 52 inches. Thanks, Jerry
bryanekholm
PostPosted: Wed Sep 05, 2007 1:24 pm    Post subject: Re: Bending Brake for 701 Reply with quote
A six foot brake should be long enough to bend all of the parts. I'm not certain how long the elevator and horizontal stabilizer spars are, but I'm thinking they are right at about 6 feet. I don't have my plans available to look at right now.
Bryan Ekholm
Bryan Ekholm
dougsnash(at)yahoo.com
PostPosted: Wed Sep 05, 2007 2:15 pm    Post subject: Bending Brake for 701 Reply with quote
Almost all bends on the 701 can be done on a on a 72
inch break except the elevator and H-stab spars. The
require a 96 inch break.
Doug MacDonald
CH-701 Scratch builder
NW Ontario, Canada
have a good
ifly4fun2(at)sbcglobal.ne
PostPosted: Wed Sep 05, 2007 3:33 pm    Post subject: Bending Brake for 701 Reply with quote
PostPosted: Wed Sep 05, 2007 4:04 pm    Post subject: Bending Brake for 701 Reply with quote
rickpitcher
PostPosted: Wed Sep 05, 2007 4:34 pm    Post subject: Bending Brake for 701 Reply with quote
---I don't know what the longest part is on a 701, but I was able to bend
almost everything I needed for a 601 on a 4-foot brake.
I ALSO took a few sheets of aluminum over to a local sheet metal fabrication shop and had them cut &bend the aft spars and a couple other large pieces. They sheared and bent all the"L"'s I needed for the project too.
The fab shop charged $100 for all this. A lot cheaper than buying a 8 foot
brake!
Rick
graeme(at)coletoolcentre.
PostPosted: Wed Sep 05, 2007 5:35 pm    Post subject: Bending Brake for 701 Reply with quote
Hi rick
did you have any trouble getting them to ajust their bender to get the right
radius of the bends.
most have there bender set with the wrong radius and don't like changing
their machine
Graemecns
ch701builder
PostPosted: Wed Sep 05, 2007 6:00 pm    Post subject: Bending Brake for 701 Reply with quote
Part #7H2-2 Stabilizer Rear Spar is 2220mm (87.4") long. The other long part is 7H2-8 at 2180mm (85.8").Another suggestion could be to purchase it, by itself, (or other parts that are too big for the 72" brake) from Zenith. The current Zenith Data Base shows the 7H2-2 for $57, and 7H2-8 for $72, or as Rick suggested, find a local metal worker and "Supervise his work", making sure the bending radius is not too sharp, or your metal may end up cracking.
Good Luck!!
Keith
CH701 scratch builder
N 38.9947
W 105.1305
Alt. 9,100'
rickpitcher
PostPosted: Wed Sep 05, 2007 7:22 pm    Post subject: Re: Bending Brake for 701 Reply with quote
graeme(at)coletoolcentre. wrote:
Hi rick
their machine
Graemecns
Good point Graeme. The shop I went to is a sheet metal fabrication shop, not an Air Conditioning duct shop. The AC guys do use a tighter bend radius, but they can make adjustments if they know what you expect. Someone else mentioned that you'd want to supervise them. Good idea.
Rick
