Fox5flyer Guest
Posted: Thu Sep 06, 2007 1:49 pm Post subject: 121.5 ELt termination |
In Feb 2009 the Copus-Sarsat will discontinue monitoring 121.5 ELT signals. You guys out there who are currently building might want to re-think installing one of these ELTs. In less than 18 months they'll be almost useless. There is an alternative.
I've pasted the FAA notice below.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
| Quote: | Termination of 121.5 MHz Beacons for Satellite Alerting is Coming Soon
Notice Number: NOTC0981
On 1 February 2009, the International Cospas-Sarsat[1] Organization (U.S.
included) will terminate processing of distress signals emitted by 121.5 MHz
Emergency Locator Transmitters (ELTs). This means that pilots flying aircraft
equipped with 121.5 MHz ELTs after that date will have to depend on pilots of
over flying aircraft and or ground stations monitoring 121.5 to hear and report
distress alert signals, transmitted from a possible crash site.
Why is this happening?
Although lives have been saved by 121.5 MHz ELTs, the downside has been their
propensity to generate false alerts (approximately 98 percent of all 121.5 MHz
alerts are false), and their failure to provide rescue forces with timely and
accurate crash location data. Both of which actually delay rescue efforts and
have a direct effect on an individual's chance for survival.Rescue forces have
to respond to all 121.5 MHz alerts to determine if they are real distress alerts
or if they are being generated by an interferer, an inadvertent activation (by
the owner) or equipment failure.
Is there an alternative?
Yes, the Cospas-Sarsat System (U.S. included) has been and will continue
processing emergency signals transmitted by 406 MHz ELTs. These 5 Watt digital
beacons transmit a much stronger signal, are more accurate, verifiable and
traceable to the registered beacon owner (406 MHz ELTs must be registered by the
owner in accordance with Federal Communications Commission (FCC) regulation).
Registration allows the search and rescue authorities to contact the beacon
owner, or his or her designated alternate by telephone to determine if a real
emergency exists. Therefore, a simple telephone call often solves a 406 MHz
alerts without launching costly and limited search and rescue resources, which
would have to be done for a 121.5 MHz alert. For these reasons, the search and
rescue community is encouraging aircraft owners to consider retrofit of 406 MHz
ELTs or at a minimum, consider the purchase of a handheld 406 MHz Personal
Locator Beacon (PLB) which can be carried in the cockpit whil
e continuing to maintain a fixed 121.5 MHz ELT mounted in the aircraft's tail.
Remember, after February 1, 2009, the world-wide Cospas-Sarsat satellite system
will no longer process 121.5 MHz alert signals. Pilots involved in aircraft
accidents in remote areas will have to depend on pilots of over flying aircraft
and or ground stations to hear emergency ELT distress signals. For further
information concerning the termination of 121.5 MHz data processing visit
www.sarsat.noaa.gov
[1] The Cospas-Sarsat Organization provides a satellite based world-wide
monitoring system that detects and locates distress signals transmitted by
Emergency Locator Transmitters (ELTs), Emergency Position Indicating Radio
Beacons (EPIRBs) and Personal Locator Beacons (PLBs). The system includes space
and ground segments which process the signals received from the beacon source
and forwards the distress alert data to the appropriate RescueCoordinationCenter
for action. |
kitfoxmike
Posted: Thu Sep 06, 2007 3:22 pm Post subject: Re: 121.5 ELt termination |
This is how I understand things. I talked to my local fsdo and was told that we can not use a 406 portable as our primary. These are around 600dollars. I will be having two airplanes. So my problem is, I don't want to spend big bucks to have two planes with a 406 that is certified for the airplane, generally 1500 dollars each. So I asked if I put in the old ELT system and buy a portable will that work. He said yes it will. So if you want to save some bucks and have a system that WORKS, than buy a portable 406 which is registered under the user, and retain the old ELT system for satifying the regs. That's my plan anyway.
jconnell(at)fmwildblue.co Guest
Posted: Fri Sep 07, 2007 6:34 am Post subject: 121.5 ELT Termination |
I have a Kitfox-II with the current 121.5 MHz ELT.
My wife and I are also building an RV-9A.
I'd like to be able to move a new 406 MHz ELT back and forth between the aircraft. I understand both the 121.5 and 406 units can use the same switch box on the instrument panel (marketing literature from ACK indicates this.)
If the new ELT is registered with the FCC, I wonder if it can reflect both aircraft. I'm afraid I'm looking at two new ELTs...
Joe Connell
kitfoxmike
Posted: Fri Sep 07, 2007 8:17 am Post subject: Re: 121.5 ELt termination |
Like me, I have the same situation. That's why I'm going with the portable unit. The same unit a mountain climber uses. Much cheaper and it gets put on you. You keep the 121.5 ELT to satisfy the regs.
torgemor(at)online.no Guest
Posted: Fri Sep 07, 2007 8:34 am Post subject: 121.5 ELT Termination |
Hi Joe,
the "new standard" the 406 Mhz ELT's, transmit your aircraft ID. One of
the brand (Cannad), have the ID strapping inside the mounting tray or in
the aircraft connector that's connected to the ELT. I.E. when moving the
ELT to the other craft the ID will still be unique for that aircraft.
Just make sure that your selected brand can do that.
A binary number is generated from your aircraft ID, this is the code
that's strapped inside the aircraft connector, your name is registered and
connected directly to this binary number. When an ELT is "chiming",
they'll know the aircraft and who to contact.
Torgeir.
On Fri, 07 Sep 2007 16:33:09 +0200, Joe & Jan Connell
<jconnell(at)fmwildblue.com> wrote:
| Quote: | I have a Kitfox-II with the current 121.5 MHz ELT.
indicates this.)
Joe Connell
Torgeir
Kitfox Model II, 1993
Engine: Rotax 532 with B gearbox
Propeller: IVO UL 366Q
Tromsoe
NORWAY.
Weather in Tromso right now:
http://met.no/troms/index.html
City map of Tromso:
http://www.avinor.no/English/Airports/Tromso_Airport/?module=Articles;action=ArticleFolder.publicOpenFolder;ID=1453
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Rhino
Posted: Fri Sep 07, 2007 9:18 am Post subject: Re: 121.5 ELt termination |
| kitfoxmike wrote: | | So my problem is, I don't want to spend big bucks to have two planes with a 406 that is certified for the airplane, generally 1500 dollars each. | They're down around $1,000 now, such as the one below, and they will eventually be going lower. The question is, how low will they go before February of 2009?
http://www.skygeek.com/455-6605.html
kitfoxmike
Posted: Fri Sep 07, 2007 10:50 am Post subject: Re: 121.5 ELt termination |
I like it. saving the info. thanks
Rhino
Posted: Fri Sep 07, 2007 11:02 am Post subject: Re: 121.5 ELt termination |
| kitfoxmike wrote: | | So if you want to save some bucks and have a system that WORKS, than buy a portable 406 which is registered under the user, and retain the old ELT system for satifying the regs. That's my plan anyway. | The plot may be thickening...
| Quote: | September 5, 2007
NTSB Wants Better ELTs in Aircraft
The FAA should require that all emergency locator transmitters in general aviation aircraft must be upgraded, the NTSB said (PDF) on Wednesday...... | http://www.avweb.com/avwebflash/news/NTSB_WantsBetterELTs_196080-1.html
There's more at the link. I didn't want to run afoul of any copyright claims.
akanka(at)kiamichiwb.org Guest
Posted: Fri Sep 07, 2007 1:28 pm Post subject: 121.5 ELt termination |
Sounds reasonable to do what you're doing. However, I got a sneaky
suspicion that The FAR's will probably be revised just about December 2008.
They will somehow manage to cost everybody a bunch of money.
John Hart
Guy Buchanan
Posted: Fri Sep 07, 2007 8:36 pm Post subject: 121.5 ELt termination |
At 10:18 AM 9/7/2007, you wrote:
| Quote: | They're down around $1,000 now, such as the one below, and they will
As with all digital hardware, you wait until the very last second,
lest they come out with either a drastic improvement of a drastic
price reduction. Of course, if I were buying an ELT now, I guess it
would be a 406. (Although the 121.5 units are probably getting pretty
cheap on the used market right about now.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
MichaelGibbs(at)cox.net Guest
Posted: Sun Sep 09, 2007 7:48 am Post subject: 121.5 ELt termination |
Kitfox Mike sez:
| Quote: | That's why I'm going with the portable unit. The same unit a
And since they must be activated manually, it's useless if you are
rendered unconscious in an accident. Do you value your life so
little that you are willing to risk that to save a few bucks? If you
rely on the 121.5 MHz ELT for these situations you should be aware
that it will add hours (or more) to the time required for searchers
to reach you, assuming the unit works at all. In the case of my
accident, I would have been dead by the time they found me.
I have a portable Emergency Position Indicating Radio Beacon (EPIRB)
in the plane also, but I would never rely on that alone. The new
'fox will have a 406 MHz ELT when it is completed.
Mike G.
N728KF
Phoenix, AZ
