CH Stick grips
Carl
PostPosted: Tue Sep 04, 2007 8:12 am    Post subject: CH Stick grips Reply with quote
[img]cid:image001.jpg(at)01C7EEEC.C1F85B40[/img]Does anyone have experience with the CH stick grips, I like their weight and ambidextrous design, but since I need to have quality for switch control also, I thought I would ask for experience. Thx cj
 Filesize:  35.73 KB
 Viewed:  377 Time(s)
Carl Bell
Building N947CB
RV 7A
daverv6a(at)gmail.com
PostPosted: Tue Sep 04, 2007 9:53 am    Post subject: CH Stick grips Reply with quote
Hi Carl,
I have them in my 6A. They have worked well so far, I like the feel, and were fairly easy to wire. They have them set up for pilot and passenger sticks, make sure you get the correct one. I have one of each. I have it set up :- trigger - ppt; front - flip flop ( you need to watch this one, have changed channel without realizing it) - coolie hat Elev & Ail trim and Top two - auto pilot engage & disengage.
Dave Burnham
On 9/4/07, Carl Bell <carlbell(at)gforcecable.com (carlbell(at)gforcecable.com)> wrote:
 Filesize:  35.73 KB
 Viewed:  372 Time(s)
williamc(at)RV9Builder.co
PostPosted: Tue Sep 04, 2007 10:06 am    Post subject: CH Stick grips Reply with quote
CJ
I’m currently using these grips in my aircraft but only have ~10 hrs TT at this point. I have had no problems or issues so far. Since these are gamer joysticks I assume that the contacts are rated for many-many operations. That is as long as you don’t try to run excessive current through them.
Good Luck
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Bell
Sent: Tuesday, September 04, 2007 9:12 AM
To: rv-list(at)matronics.com
Subject: CH Stick grips
Carl
PostPosted: Tue Sep 04, 2007 10:38 am    Post subject: CH Stick grips Reply with quote
Thx Bill, I plan to order them, did you shorten your sticks to get down to Vans original height?
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill Cary
Sent: Tuesday, September 04, 2007 2:05 PM
Subject: RE: CH Stick grips
CJ
Good Luck
Carl Bell
Building N947CB
RV 7A
PostPosted: Tue Sep 04, 2007 11:06 am    Post subject: CH Stick grips Reply with quote
CJ
Yes, I shortened them so that the hand would rest at about the same height if using a simple rubber grip. I may shorten another 1” but plan on waiting until I get more flying time in.
Sent: Tuesday, September 04, 2007 11:37 AM
[quote] [b]
n616tb(at)btsapps.com
PostPosted: Tue Sep 04, 2007 12:06 pm    Post subject: CH Stick grips Reply with quote
My grips are at the standard height but I have thought many times I would like to shorten them. When I flew with Mike Seager a year and a half ago he was pretty insistent that my hand was all the way up on the grip for landing and takeoff. I have kept that advice even today. I fly normally however with my hand much lower as it is more comfortable.
All the way up at the standard Van’s height however still seems pretty high. I am wondering what advice anyone has for how much it could be shortened without jeopardizing control stability for landing. An inch? Two?
Sent: Tuesday, September 04, 2007 2:07 PM
CJ
PostPosted: Tue Sep 04, 2007 12:49 pm    Post subject: CH Stick grips Reply with quote
Tim,
I cut my sticks - don't remember how many inches - I have attached a photograph. I measured to make sure the grip didn't hit the panel and cut it there - I have the extended panel so it is a little lower than the standard one.
I generally fly with only thumb and 2 fingers, never a problem with control.
Dave
All the way up at the standard Van's height however still seems pretty high. I am wondering what advice anyone has for how much it could be shortened without jeopardizing control stability for landing. An inch? Two?
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Bill Cary
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
CJ
Yes, I shortened them so that the hand would rest at about the same height if using a simple rubber grip. I may shorten another 1" but plan on waiting until I get more flying time in.
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Carl Bell
 Filesize:  308.94 KB
 Viewed:  376 Time(s)
PostPosted: Tue Sep 04, 2007 1:08 pm    Post subject: CH Stick grips Reply with quote
Hi Dave,
Nice panel! What is the glass clear over on the passenger side?
I fly with only my thumb and 2 fingers also except for take off and landing. At that point I move my hand completely up onto the stick as I was taught by Mike. It would seem to me that control would be easy enough obtained even if I cut a couple inches off but wanted to bounce it off of others.
Thanks for you input
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Burnham
Sent: Tuesday, September 04, 2007 3:46 PM
Subject: Re: CH Stick grips
Tim,
Dave
CJ
PostPosted: Tue Sep 04, 2007 1:32 pm    Post subject: CH Stick grips Reply with quote
Hi Tim
Advanced Flight Systems - engine monitor - Just amazing piece of engineering.
http://www.advanced-flight-systems.com/
Dave
On 9/4/07, Tim Bryan <n616tb(at)btsapps.com (n616tb(at)btsapps.com)> wrote: [quote]
Hi Dave,
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of David Burnham
Tim,
Dave
CJ
ronlee(at)pcisys.net
PostPosted: Tue Sep 04, 2007 2:20 pm    Post subject: CH Stick grips Reply with quote
I fly with my hand resting on my leg. This places the PTT switch at the
top of the handle too high. I don't move my hand higher for take-off or landing.
Bottom line is that my stick could be even shorter than it is.
Ron Lee
retasker(at)optonline.net
PostPosted: Tue Sep 04, 2007 4:17 pm    Post subject: CH Stick grips Reply with quote
I don't yet have flying experience with the sticks, although I do have
two in my almost completed RV9A. The following email was posted in Nov
of 2004 regarding research I did on the switches used in the sticks.
Previous email:
There has been discussions about the CH Products control sticks (http://www.chproducts.com/retail/aircraft.html) on the newsgroups lately. I have two of them, but there was a question about what the switch ratings were. I contacted Kevin Williamson of CH Products and he was kind enough to supply me with a set of sample switches (from Omron) and the part numbers thereof.
I downloaded the complete data sheet from the web, reviewed the specifications and then called the Omron factory representative. There are a few minor errors in the datasheet available on the web, so the rep emailed me the revised (corrected) sheets. I also discussed with him the specifications listed and got clarification, although it turned out that when I received the revised data sheets, the specification is very clear now.
The bottom line is that the electrical rating for all three different switches is: 1-50mA, at 5-24V.
The explanation for the ratings is:
1. The lower values (1 mA at 5V) are to make sure that the switch sees enough energy when switching to keep the contacts clean. Any lower values would not guarantee that the contacts will always make proper contact over the life of the switch. If for some reason the load being switched is too low, a resistor could be added in parallel with the load to increase the current to at least 1 mA.
2. The higher values (50 mA at 24V) are the maximum values that should be switched that will not damage the switch. Switching any higher loads will risk damaging the contacts - either welding them shut or warping them or causing excessive arc damage - and will certainly shorten the life of the switch.
3. These ratings are for a resistive load, so if they are to be used with a relay or motor the contacts MUST be protected with a diode or other type of snubber network!
Of course, the manufacturer always has a margin in the design so if one chooses to switch 55mA at 14V (for instance), the switch will probably still have a reasonable life. However, pushing them to 100 mA or more will definitely shorten the life and may result in a catastrophic failure at some point.
These switches are rated for a lot of actuations so their use in an airplane should be no problem. The hat switches are rated for 300,000 operations (minimum), the switches on the top face of the stick are rated for 100,000 operations (minimum) and the trigger (typically used for push-to-talk) is rated for 1,000,000 operations (minimum).
To put these numbers in perspective, let's assume you make one flight every day for ten years. For each flight you could use the hat switch to trim the airplane 82 times in each direction, you could actuate the flaps (assuming that is what you use the two gray switches on the top of the stick for) 27 times each up and down and you could push-to-talk 274 times.
I am satisfied that the switches used are as robust as you will find and the ratings are adequate for the task. Just don't go overboard on what you connect direct to the switches and your CH Products control stick will have a long and happy life!
Dick Tasker
Do not archive (since it is already there)
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
tgpritchard(at)hotmail.co
PostPosted: Fri Sep 07, 2007 11:57 am    Post subject: CH Stick grips Reply with quote
I'm a total newbie to the list but hope to build a 9A in a couple years.
Regarding the control stick - would it be feasible to machine the stick in such a way as it can be telescoped out (and locked) for take off and landing but collapsed during regular flight?
Tom
More photos; more messages; more whatever – Get MORE with Windows Live™ Hotmail®. NOW with 5GB storage. Get more! [quote][b]
carlosh(at)sec-engr.com
PostPosted: Fri Sep 07, 2007 1:11 pm    Post subject: CH Stick grips Reply with quote
Just curious why you'd want to do this?
Carlos
Tom
Carlos Hernandez <carlosh(at)sec-engr.com>
Structural Engineers, LLC
2963 W. Elliot Rd. - Suite 3
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
CONFIDENTIALITY NOTICE
The information in this email may be confidential and/or privileged.
This email is intended to be reviewed by only the individual or
organization named above. If you are not the intended recipient or
an authorized representative of the intended recipient, you are hereby
notified that any review, dissemination or copyingof this email and
its attachments, if any, or the information contained herein is
prohibited. If you havereceived this email in error, please
immediately notify the sender by return email and delete this email
from your system.
panamared5(at)brier.net
PostPosted: Fri Sep 07, 2007 2:18 pm    Post subject: CH Stick grips Reply with quote
Everyone is different, and in that respect, I find any type of stick
grip unusable, even when I am using a flight simulator on the
computer. I find that I can not get fine precise movement when I put
my entire hand on the stick grip. Same with the airplane.
I learned how to fly a sensitive aircraft from an F-4 pilot when he
told me that in cruise he rested his forearm on his thigh and used
the tip of this index finger and thumb to fly the aircraft. I find
that works well with my RV. But for aerobatics, I have my full fist
on the top of the stick. And sometimes I use both hands on the
stick, not because of the stick forces, but for more precise control
when doing large control deflections.
Some people may be making more out of this stick grip thing than is
necessary. I know before I flew my airplane I wanted to install
them, but after flying for a few years, I can not imagine how I could
possible use them. I do use both my left and right hand to fly the
aircraft and as I recall the stick grips are mostly right or left handed.
RV6 "Wicked Witch of the West"
ChickenHawk
PostPosted: Fri Sep 07, 2007 3:52 pm    Post subject: Re: CH Stick grips Reply with quote
Carlos
Carlos,
Just showing my ignorance. I have never flown an RV. I have flown a Diamond Katana which has a very light touch on the stick. I noticed a message earlier that recommended that one keep ones hands high on the stick during take offs and landings. My assumption (always a big risk) is that this is improve leverage and refine the movements on the stick. I too prefer to set my hands low on the stick with arm resting on my leg. My thought was that a telescoping stick might provide both requirements, although I admit it makes the system more complicated.
Since I haven't flown an RV and my RV of choice will probably be the 9A, this may be totally unnecessary.
Tom
Carlos Hernandez <carlosh>
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
from your system.[/quote]
PostPosted: Fri Sep 07, 2007 6:28 pm    Post subject: CH Stick grips Reply with quote
I fly with my hand resting on my thigh and my fingers below the top of the
stick.
I have no need to hold my hand higher and my landings are usually good.
I would fly an RV then forget about this idea.
Ron Lee
PostPosted: Sat Sep 08, 2007 9:44 am    Post subject: CH Stick grips Reply with quote
stick.
Ron Lee
Here is a response to my landing assertion:
" Mr. Lee,
This e-mail is in response to your braggadocio that your landings are
usually good,
as appeared in a recent RV list posting. I have flown with you enough to
know that
your passengers' kissing the ground upon every landing is not a reflection
on your
expertise at greasing a landing. Indeed, I think it is closer to the truth
to think that
it is more a testament to the design of the RV that it takes that licking
time and time
again and still rolls in a straight line. Please confine your remarks to
the same zip
code as the truth and do not attempt to confuse the RV public with your
mendacity.
R"
Personally, I get the impression that this anonymous person is making fun of
my
wonderful landing. I suspect that he is rather full of himself since he
uses big words
like "medacity."
Ron Lee
