		clemwehner(at)sbcglobal.n Guest
				 Posted: Sat Sep 08, 2007 2:51 pm    Post subject: firewall penetration |
				I'm installing my  912 in a KF IV and have a question that seems really dumb, but I can't find an  answer in anything I've read.
  What is the proper  way to pass things like wires, hoses, and tubing through the firewall?  Is  it through simple rubber grommets, or is there a special fitting used?
  thanks,
  Clem  Wehner
  KFIV-912
  Lawton,  OK
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		john(at)leptron.com Guest
				 Posted: Sat Sep 08, 2007 4:00 pm    Post subject: firewall penetration |
				Clem,
 For everything except my thermocouple wires, I used computer type 9 and 14 pin connecters.
 John Oakley
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of clemwehner
  Sent: Saturday, September 08, 2007 4:51 PM
  Subject: firewall penetration
 thanks,
 Clem Wehner
 KFIV-912
 Lawton, OK
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Kitfox-List  | 	  01234
		dcsfoto
				 Posted: Sat Sep 08, 2007 4:05 pm    Post subject: Re: firewall penetration |
				Aircraft spruce has some nice plastic snap bushings,page 94
		Mdkitfox(at)aol.com Guest
				 Posted: Sat Sep 08, 2007 4:32 pm    Post subject: firewall penetration |
				In a message dated 9/8/2007 6:53:02 P.M. Eastern Daylight Time,  clemwehner(at)sbcglobal.net writes:
   	  | Quote: | 	 		     What is the proper    way to pass things like wires, hoses, and tubing through the firewall?     Is it through simple rubber grommets, or is there a special fitting    used?
 It seems to me the firewall must remain intact.  If there were a  fire, it could pass thru a plain rubber or plastic grommet.  I used  the Kitfox firewall blanket first then inserted a stainless steel  eyeball for most pass thru's.  For the rubber and plastic pass  thru's I covered them all with high temp RTV.  It may not  keep all the fire out, but it would hopefully keep it to a minimum.
  Rick  Weiss
 Series V Speedster - N39RW, 912S Power
 DO NOT  ARCHIVE
 See what's t="_blank">Make AOL Your Homepage.
		marin
				 Posted: Sat Sep 08, 2007 6:43 pm    Post subject: firewall penetration |
				Clem
 You should keep your firewall integrity at all times and use hardware that will help you maintain it.
 Check out Aircraft spruce for fire wall blankest and stainless steel firewall shields. Try the link bellow. Also talk to the local EAA chapter and see if they have any technical advisers.
 http://www.aircraftspruce.com/menus/ap/firewalls.html
 Marin Streeter
  _________________ Marin |
		pwmac(at)sisna.com Guest
				 Posted: Sat Sep 08, 2007 7:23 pm    Post subject: firewall penetration |
				Special fitting is required. Never use rubber.
  As with all things electrical check out the archives of the aeroelectric list on matronics. This subject has been beat to death.
   Another resource are the Bingillis how to do books which are sold by EAA.
   Regards, Paul
  [quote]On Behalf Of clemwehner
  Sent: Saturday, September 08, 2007 3:51 PM
  thanks,
  Clem Wehner
  KFIV-912
  Lawton, OK
		barry(at)pgtc.com Guest
				 Posted: Sun Sep 09, 2007 2:34 am    Post subject: firewall penetration |
				I used the screw together electrical fittings that  are available from any electrical supply company.  They have rubber  stoppers in them that can be split if needed to fit around tubes and wires  and are compressed with the outside nut.  They also have a jam nut to  firmly attach to the firewall.  This is not a good description but go to a  supplier and ask to see the feedthroughs that are used on junction  boxes.
  Barry West
  [quote]   ---
		hflynn46531(at)yahoo.com Guest
				 Posted: Sun Sep 09, 2007 4:08 am    Post subject: firewall penetration |
				You should get FAA AC 43.13-1b Aircraft Inspection and Repair Manual. It's the aircraft mechanics Bible. Published by Jeppesen. I think I paid about $20.00 For it. Answered most of my questions when I built my S5. I'm now restoring a J3 cub. Couldn't do it right without this manual.
 Barry West <barry(at)pgtc.com> wrote:  [quote]        I used the screw together electrical fittings that are available from any electrical supply company.  They have rubber stoppers in them that can be split if needed to fit around tubes and wires and are compressed with the outside nut.  They also have a jam nut to firmly attach to the firewall.  This is not a good description but go to a supplier and ask to see the feedthroughs that are used on junction  boxes.
   Barry West
   [quote]  ---
		Guy Buchanan
				 Posted: Sun Sep 09, 2007 6:29 am    Post subject: firewall penetration |
				At 03:51 PM 9/8/2007, you wrote:
   	  | Quote: | 	 		  I'm installing my 912 in a KF IV and have a question that seems really dumb, but I can't find an answer in anything I've read.
    | 	  It's funny how people think the hard questions are really dumb. No such luck this time Clem. If you want to see a "hot" topic, fire this one up on the Lancair or AeroElectric list. You'll get weeks of discussion. This means that if you want to read about virtually every possible penetration technique you should do extensive searching there.  www.lancair.net/maillist.html for Lancair and  www.matronics.com/searching/search.html for AeroElectric.
   	  | Quote: | 	 		  | What is the proper way to pass things like wires, hoses, and tubing through the firewall?  Is it through simple rubber grommets, or is there a special fitting used?  |
  As has been stated, the primary concerns are chafe and fire. You want a penetration that will allow the items to pass without being cut over time while not allowing something like a 1600F flame to pass after 15 minutes. There are also considerations of convenience, such as putting bulkhead electrical connectors so everything firewall forward can be disconnected. (You'll find these are heavily disparaged by the reliability set who don't like unnecessary connectors.)
  I can't give you a shopping list, as I became overwhelmed when I tried it during my build. I did find two items which may be of use to you, however. The first is  www.epm-avcorp.com/tubeseal.html, which is the only penetration I could find anywhere, (including mil-spec,) that was tested for fire. I used at least one of these and would have used them more extensively if I'd have found them earlier.
  The other item is 3M™ Fire Barrier MP+ STIX . These are available at contractor supply stores and on-line. It is:
  "A synthetic elastomer designed for use as a one part, intumescent fire resistive putty used to restore the integrity of fire rated building construction. Stays pliable, allows easy access for cable mining at a later date."
  I molded this around my existing rubber grommet penetrations in the hope that it would delay burning of the grommet and subsequent fire entry. The specs indicate that when subjected to fire the putty expands and chars, forming a very high temperature barrier.
  My grommet penetrations used standard AN931 rubber grommets covered by Aircraft Spruce firewall shields. ( www.aircraftspruce.com/menus/ap/firewalls.html) I then covered the exposed rubber + 1/4" around with the putty.
  Good luck and report back when you've decided!
  Guy Buchanan
  San Diego, CA
  K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar.     [quote][b]
Deceased K-IV 1200
A glider pilot too. |
				 Posted: Mon Sep 10, 2007 5:19 am    Post subject: firewall penetration |
				Harold, I think your idea of referring to FAA AC  43.13-1b is good but I just reviewed my copy and could not find information on  feeding through the firewall.  Can you give me the section and page number  where I can find this?
  Barry West
  [quote]   ---
		darinh
				 Posted: Mon Sep 10, 2007 10:53 am    Post subject: Re: firewall penetration |
				My firewall for my Series 7 came with a number of holes in it for wires, cables, etc.  My main question is with the heater.  This thing mounts right behind the firewall with the supply and return fittings passing through.  What have people done in this situation for fireproofing?
  _________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
				 Posted: Tue Sep 11, 2007 4:29 am    Post subject: firewall penetration |
				I looked in the manual and it does not address that subject. What I used was a rubber grommet and a stainless steel firewall shield which I got from Aircraft Spuce. They also sell nylon bulkhead seals for the same purpose. In the 2006-2007 catalog pages 135-294 and 436 you should find what you need
 Barry West <barry(at)pgtc.com> wrote:  [quote]    Harold, I think your idea of referring to FAA AC 43.13-1b is good but I just reviewed my copy and could not find information on feeding through the firewall.  Can you give me the section and page number where I can find this?
   Barry West
   [quote]  ---
		dave.wahlquist(at)ics.uwe Guest
				 Posted: Tue Sep 11, 2007 5:15 am    Post subject: firewall penetration |
				Hey all,
 Sport Aviation Dec 2006 had a good article on firewall penetrations.
  They did some great flame testing to prove out what worked best to keep the fire and fumes on the engine side of the firewall.
 Dave Wahlquist
  Model 3 582 Wisconsin
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Harold Flynn
  Sent: Tuesday, September 11, 2007 7:27 AM
  Subject: Re: firewall penetration
 Barry West
		akanka(at)kiamichiwb.org Guest
				 Posted: Tue Sep 11, 2007 12:25 pm    Post subject: firewall penetration |
				The  entire FAA Advisory Circular library, with all current changes, is available on  line at:
  http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/MainFrame?OpenFrameSet
  Just  select how you would like them displayed from the links on the left side of the  page.  For example,
  clicking on "Current ACs" presents sub-list that has:               [url=http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/ACNumber!OpenView]By        Number[/url]          [url=http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/ACDate!OpenView]By        Date[/url]                 [url=http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/ACPart!OpenView]By        FAR, CAR, SFAR Part[/url]
        Clicking on "By Number" presents the ACs in numerical order.         This link will display the list numerically:
        There are several pages to the list.  Clicking either "Next"        at the top of the list, or "MORE" at the bottom will
        take you to the next page of the list.
        Each AC can be saved to your hard drive, put on a CD or any other        way you would like to save them for reference without internet        connection.
        John Hart
  [quote]   --
