Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
jeff(at)westcottpress.com Guest
Posted: Wed Sep 12, 2007 3:51 pm Post subject: Firewall Sealant |
I'm about to order my CS 1900 Firewall Sealant as I've reached the
point of riveting the forward rib subassemblies to the firewall and
the final instruction on page 27-6 is to "proseal any gaps around the
F-1001K Recess" etc.
While I'm doing that, would it make sense to put a thin coat across
the flush rivet lines on the engine side of the firewall?
Jeff Carpenter
40304
AV8ORJWC
Posted: Wed Sep 12, 2007 6:33 pm Post subject: Firewall Sealant |
The final texture of the CS 1900 is much different from the other
products.
Reserve your decision until after you watch the dried product on the rib
subassemblies. Then you should have no regrets.
Fire Annunciation, Fire Suppression, walking away for another day is
what it is all about.
John Cox
40600
orchidman
Joined: 10 Jul 2006 Posts: 276 Location: Oklahoma City - KRCE
Posted: Thu Sep 13, 2007 4:27 am Post subject: Re: Firewall Sealant |
| AV8ORJWC wrote: |
John,
Could you please expand on this. I will be starting Section 27 next week and want to make sure I understand what you are saying.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
AV8ORJWC
Posted: Thu Sep 13, 2007 9:09 am Post subject: Firewall Sealant |
For those builders who have used PolySulfate (stinky) Thioxotrophic
(sticky shit) sealer known as "Proseal" by one brand name, and maligned
by other makers. The product used for fuel tank sealing is entirely
different than the product to sustain higher temperatures inside an
engine cowl.
It is wise to observe the appearance of the final "High Temperature"
sealant after cure before making a commitment to use it beyond its
intended purpose.
The manufacturer (You) has lots of products to chose from. A material,
B material and C material all have differing viscosities. 1/4 sets in
15 minutes, 1/2 sets in 30 and 2 sets in two hours. Each product number
change also changes the properties, color, flexibility and heat
resistance.
Is that what you wanted Gary?
John
orchidman
Posted: Thu Sep 13, 2007 6:24 pm Post subject: Re: Firewall Sealant |
| AV8ORJWC wrote: |
John
No, I am aware of the basic differences but the way I read your comment, there was something in the way the Firewall product was used or ??? that I might need to be aware of in where or how I would want to use it on the Firewall.
Sorry, it is late and today has been a hard day at work so I know I am not making sense.
Gary
RV10 - # 40674
(N2GB Flying) |
apilot2(at)gmail.com Guest
Posted: Thu Sep 13, 2007 6:45 pm Post subject: Firewall Sealant |
I think John was referring to the firewall version having a different consistency, that perhaps doesn't flow as smooth or dry as smooth as the tank sealing version..so you may want to be more cautious where you apply it, to keep a nice looking firewall. I'm sure that if I am misinterpreting, John will speak up in the morning after work.
On 9/13/07, orchidman <gary(at)wingscc.com (gary(at)wingscc.com)> wrote:[quote] --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com (gary(at)wingscc.com)>
AV8ORJWC wrote:
John
Gary
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
