Ray.R.Doerr(at)sprint.com Guest
Posted: Wed Sep 12, 2007 4:30 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
Here is the email chain I had with Ameri-King about there plans for a 406 Mhz ELT.
Thank You
Ray Doerr
40250
N519RV (Hobbs = 310)
Looking forward to LOE 07
Jack.Phillips(at)cardinal Guest
Posted: Wed Sep 12, 2007 4:52 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
Good information, Ray. Did they happen to mention their proposed price
for the AK-451?
Jack Phillips
#40610
poneill(at)irealms.com Guest
Posted: Wed Sep 12, 2007 5:21 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
With regard to the GPS location data option, has anyone seen any statistics
on the benefit of this? How accurate is the satellite positioning on the
406 mhz units? Is the accuracy such that the GPS link makes a big
difference in locating the beacon?
Best Regards,
Patrick #40715
james.k.hovis(at)gmail.co Guest
Posted: Wed Sep 12, 2007 7:16 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
I think it could make a big difference in time needed to locate a
beacon. Older ELT's bsically just send out a toned signal. You need
direction finding radio equipment to find the bearing to the
transmitter and then triangulate that with one or two other DF
stations to find the location. This could take some time. Also,
transmitter power and terrain may limit the effectiveness of the DF
equipment recieving the signal. As far as accuracy of the GPS reading,
the ELT itself will contain a GPS reciever that should be as accurate
as any other TSO'd GPS unit. The ELT signal will contain a data stream
containing the GPS coordinates that is relayed by satellite to the
central processing center. Once the coordinates are decoded, this can
be relayed to the rescue units. This should save quite a bit of time.
Of course, the accuracy of the GPS data the ELT transmits is a
function of how many GPS satellites it "sees" at any one time (need at
least three), just as it is with any GPS unit. In a crash I suppose
this could be an issue.
Kevin H.
Best Regards,
Patrick #40715
rvbuilder(at)sausen.net Guest
Posted: Wed Sep 12, 2007 9:14 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
| Quote: | From what I have read, GPS data get's you a couple things. First and foremost it gives rescuers immediate coordinates to begin their search within a 100 meter radius. With just the 406 beacon, it will take several passes of low orbit SAR satellites to narrow down your location using Doppler Shift. The feds also say accuracy using DS is 1-3 miles, time & samples variable.
Michael
Posted: Thu Sep 13, 2007 5:11 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
No, Ameri-King did not indicate the price or timeframe for this new ELT, I was just glad to hear we are going to have competition in this space.
As for the GPS option on the ELT, I for one was hoping to not have another GPS in my airplane, when I already have 3. I have dual Garmin 430W which are WAAS certified and a Garmin 496 handheld. I am wanting to connect the RS-232 aviation output from one of my 430W to the ELT and then have the ELT keep a copy of the latest GPS Sentence which has the Long/Lat and then transmit that, if the ELT was activated. But so far, I think all ELT's with the GPS option are embedding it into the ELT itself, so now you will likely need another GPS Antenna mounted on top and I don't want that. With everything having GPS in it in the future, I can see a time where we have 4+ GPS Antenna's on the plane. One for you Panel Mount, Handheld, ADSB UAT and ELT. I am just trying to minimize this. There is no reason the ADSB UAT and the ELT can't use the output from my 430W!
Thank You
Ray Doerr
40250
N519RV (Going to LOE 07)
Posted: Thu Sep 13, 2007 5:36 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
When thinking about integrating devices, it's not always best to have all of your eggs in one basket. In my mind I would want a completely independent system when it comes to SAR. For instance, the ELT runs off its own internal power, isolating it from ship faults. Another potential problem is what if you were to lose ship power completely in IFR. It's totally feasible to carry on for quite a while using vacuum instruments but your ELT would now have coordinates that would have the SAR teams in a completely different area.
Integration is a good thing under normal conditions. But when your ELT needs to be used, you are usually outside the normal envelope and all bets are off. Really stop and think about what integration vs. stand alone get's you for saving that extra couple bucks and a few ounces. To each his own but I want something that is isolated from ship functions when it may make the difference between finding me or being one of the 8 other aircraft out there that is found years later while looking for someone famous. God speed to all those lost souls.
Michael
Posted: Thu Sep 13, 2007 5:41 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
One other thing to add. When you survive a forced landing in the mountains, it would be nice to pull the ELT and take it with you. If you are integrated with the ships GPS it might get a bit messy ripping out a surviving GPS and rigging up a cable to get the ELT to update your coordinates when you go and seek shelter, water, or food. Then there is the problem of carrying around a heavy battery, etc. You get my point.
Michael
Posted: Thu Sep 13, 2007 10:18 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
Good point, maybe we can at least get them to design a integrated Antenna for both GPS and 406 Mhz transmission.
Thank You
Ray Doerr
Mike Whisky
Posted: Thu Sep 13, 2007 10:23 pm Post subject: Re: Is AmeriKing going to create a 406 Mhz ELT. |
There was a new ELT presented at Oshkosh.
http://en.martec.fr/page/p-191/art_id-/
They claim to be better than the competition.
Michael
www.wellenzohn.net (just painted the interior)
_________________ RV-10 builder (flying)
#511 |
glastar(at)gmx.net Guest
Posted: Fri Sep 14, 2007 12:53 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
Michael,
did you see their price? Christen sells one for close to 2300$ wonder
what the difference to the ME406 is as it seems currently the cheapest
on the market.
br Werner
Michael Wellenzohn wrote:
Posted: Fri Sep 14, 2007 5:58 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
On another note, AOPA plans to fight any mandatory upgrades to 406 because of the large price difference.....
http://www.aopa.org/whatsnew/newsitems/2007/070913elt.html
Michael
GRANSCOTT(at)aol.com Guest
Posted: Fri Sep 14, 2007 6:21 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
Michael...I know AOPA is fighting this with good cause for us...but also be aware that the USAF informed the CAP folks that they will no be accepting the old 121.5 code for SAR's in the future. The will only be responding to the 406 series for SAR's...I don't know how they are going to handle a physical report for an over due aircraft, though.
When you read on these ELT's you'd believe they are all fail safe which they are not. CAP still finds down aircraft via search in air and on ground besides electronic methods...but it's not so immediate, though.
Patrick
See what's new at AOL.com and Make AOL Your Homepage.
moons1999(at)yahoo.com Guest
Posted: Fri Sep 14, 2007 6:26 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
It seems to me that they are fighting the wrong battle. What they should be doing is working on ways to get more companies to manufacture them so there is more competition and (hopefully) lower prices. I will admit, though, that it seems that in aerospace the first company to market sets the price and then everyone else just seems to follow that pricing. It seems to me that the 406 is a much better solution yet things like this only prove to impede the acceptance of the newer standards.
--Shawn
40366 - Wings
Posted: Fri Sep 14, 2007 7:06 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
This is very true, but it gives people options like keeping your existing ELT until prices drop a bit and using a portable 406 PLB like the MicroFix. I expect that most airliners and many other aircraft will continue to fly with their second radio tuned to 121.5 as good members of the community. For me this seems like a good compromise and allows for portability that you just can’t get in the on board units. When the on board units drop in price to a reasonable figure I will then replace and have two levels of redundancy for that rare case I need SAR to find me.
Yes for this to work it requires the PLB to be activated prior to an incident in case of unconsciousness. I plan to mount it somewhere in arms reach so that I can add it to the emergency checklist. The nice thing with the Microfix is it’s just a matter of hitting one button and freeing the antenna. If it’s secured someplace like under my legs, it has a very good chance of surviving if I do. And with the canopy being made of fiberglass it is essentially transparent to the beacon.
My $0.02
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com
Sent: Friday, September 14, 2007 9:21 AM
Subject: Re: Re: Is AmeriKing going to create a 406 Mhz ELT.
Patrick
See what's new at Make AOL Your Homepage.
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
Tim Olson
Posted: Fri Sep 14, 2007 7:46 am Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
Wondering....this might be a good place for the experimental
community to step in. Perhaps a manufacturer to offer a well-priced
experimental product, or, maybe we use some brain power. It wouldn't
seem to hard to take an existing ELT case, leave the switches and
crash sensing stuff, and rip the guts out and install a good
GPS equipped PLB and maybe adjust the antenna length accordingly.
In fact, if done right, you could use a GPS equipped PLB that
could be removed after crash for when you're hiking it
back to camp. Ideally, we'd have a product that would offer the
best of all worlds....a manually switch-on-able portable built
in GPS, with a removable handheld module for hiking out,
and an external GPS feed for in-flight use pre-crash. Seems
that if someone designed all this stuff there would not only
be a better product, but one that could be made cheaper or at
least be worth a thousand bucks.
RV Builder (Michael Sausen) wrote:
| Quote: | This is very true, but it gives people options like keeping your
My $0.02
Michael
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*GRANSCOTT(at)aol.com
*Sent:* Friday, September 14, 2007 9:21 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Re: Is AmeriKing going to create a 406 Mhz ELT.
Patrick
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
apilot2(at)gmail.com Guest
Posted: Fri Sep 14, 2007 7:46 pm Post subject: Is AmeriKing going to create a 406 Mhz ELT. |
A friend reported he had a 406 unit self activate while the aircraft was in hangar with no one around. I don't know how FAA will handle overdue and reports of aircraft hearing ELT, but I would expect they would be relaying to USAF expecting normal SAR treatment.
On 9/14/07, GRANSCOTT(at)aol.com (GRANSCOTT(at)aol.com) <GRANSCOTT(at)aol.com (GRANSCOTT(at)aol.com)> wrote: | Quote: | Michael...I know AOPA is fighting this with good cause for us...but also be aware that the USAF informed the CAP folks that they will no be accepting the old 121.5 code for SAR's in the future. The will only be responding to the 406 series for SAR's...I don't know how they are going to handle a physical report for an over due aircraft, though.
Patrick
[/b] |
