clint_bazzill(at)hotmail. Guest
Posted: Thu Sep 06, 2007 7:11 am Post subject: Vortex Generators/Turbulator's |
My tests are complete on Harrison Designs Vortex Generators.
I had approval from FAA to test these generators and am wrting up my results
on Kitfox Model IV-1200. I revisited early flight tests and did a complete
calibration of system. Had a chase plane follow and video tape tuffed wing
prior to installation. I am in the precess of writing up a 3 part series
on procedures and results. Stay tunned in Clint Kitfox IV-1200 912ULS
1250 Hours.
Share your special parenting moments!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
dave
Posted: Thu Sep 06, 2007 7:41 am Post subject: Re: Vortex Generators/Turbulator's |
Clint good stuff, I have several sets of Vgs here and am contemplating doing mine soon. My IV flies great but I have just gotta know .....
I have harrison VGs as well as stol speed ones.
I did use VGs on a lower cowl redesign and they contributed to a 20 F drop in water temps .
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Thu Sep 06, 2007 8:24 am Post subject: Vortex Generators/Turbulator's |
That is definitely good news Clint. Please keep us in the loop.
Deke
dave
Posted: Fri Sep 14, 2007 5:15 am Post subject: Re: Vortex Generators/Turbulator's |
Clint,
I used some harrison Vg;s on the lower cowl mods i did and they contributed to a 20F drop in coolant temps
http://www.cfisher.com/cowl.html
Last weekend I put some Vgs on my wings.
I have started a page here http://www.cfisher.com/vg.html
I put up a video of some flying with them on to be found there as well.
I placed the leading edge of VGs 4.625 inches back from leading edge as measured through the chord not following the curvature of the top of the wing. This puts the centre of the VG at exactly 10% of the chord.
So far favorable results, but nothing like I have read about the 8 mph stall speed drops. Looks like about 2 mph drop in stall to about 36-37 mph clean. No speed loss and if any less than 1 mph but no gain either.
Slow speed flight does seem a little more stable but I have never complained or had any issues with slow speed flight on my IV. I have been reluctant to put on the VGs as the Kitfox of mine has had such good performance.
I did do another mod that has added favorable results this week as week which was correcting the exhaust form how Skystar had cut the 90% elbow and shortened the actual header length. If definitely has added HP as RPM has increased at idle, static and wide open throttle in flight by 200 to 300 rpm . I have now re pitched and picked up some speed as well but will post data once done another re pitch and some more flight data.
Float Flyr
Posted: Fri Sep 14, 2007 6:32 am Post subject: Vortex Generators/Turbulator's |
Glad to see you're back to the list.
Do you think the VGs on the lip of the cowl will help cooling without the
radiator scoop?
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Dave can we see a straight down view of the installation showing the spacing
and angles between individual VGs?
Liked the video!... Beats the tar out of Flight Sim but the plane seems
strangely familiar.
Noel
[quote] --
Kitfox III-A
dave
Posted: Fri Sep 14, 2007 6:51 am Post subject: Re: Vortex Generators/Turbulator's |
Noel,
I am not sure but I think the rad scoop does help with cooling.
The same setup without the scoop? should be ok but i will have to remove to validate for sure.
Quote: | Do you think the VGs on the lip of the cowl will help cooling without the
radiator scoop?
Noel |
dave
Posted: Fri Sep 14, 2007 7:15 am Post subject: Re: Vortex Generators/Turbulator's |
Noel, I cannot help you with a pic other than at http://www.cfisher.com/vg.html but you can see how the spacing changes
But I followed these directions http://stolspeed.com/content.php?id=27
from last outer rib for a about 3 feet 60mm spacing
Then rest of wing to windshield I spaced them 90 mm
Quote: | Dave can we see a straight down view of the installation showing the spacing
and angles between individual VGs? |
Float Flyr
Posted: Fri Sep 14, 2007 12:59 pm Post subject: Vortex Generators/Turbulator's |
As you know I don't have a scoop on my plane... Then again I haven't had
any cooling issues either. I'm just trying to keep options open. Is it
advisable to use the same rad for the 912 that I am using with the 582?
Noel
[quote] --
Kitfox III-A
dave
Posted: Fri Sep 14, 2007 1:51 pm Post subject: Re: Vortex Generators/Turbulator's |
Noel, I think the rad is the same one -- 4" x 20 " approx. but surely someone will comment for sure to confirm.
Float Flyr
Posted: Fri Sep 14, 2007 2:49 pm Post subject: Vortex Generators/Turbulator's |
Found what I needed on the link you provided... Thanks
[img]cid:899513722(at)14092007-2DB8[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
438 Time(s) |
Kitfox III-A
dave
Posted: Mon Sep 17, 2007 4:07 am Post subject: Re: Vortex Generators/Turbulator's |
Update on VG testing .........
just in from more aggressive stall testing.
power off -- full aft stick - just get a 500 fpm mush with less buffet that without VGs and no nose drop.
power on -- 3 stalls - one right wing dropped other 2 no wing drop .
still less buffeting that before .
So far, satisfied with VGs and no cruise speed loss it seems. as far as claims of these 8 + mph stall speed drops -- in my case that just a myth so far but 2 or 3 mph about the most of got SO FAR .
dave
Posted: Wed Sep 19, 2007 5:48 am Post subject: Re: Vortex Generators/Turbulator's |
one more attribute on the Vg's that I failed to mention originally was a greater AOA on climb out was evident.
dave
Posted: Fri Nov 09, 2007 8:11 pm Post subject: Re: Vortex Generators/Turbulator's - Clint |
Hi CLint, I am still anxious to read your report on Vgs. Where can I expect to read it ?
Quote: | Posted: Thu Sep 06, 2007 11:11 am Post subject: Vortex Generators/Turbulator's
1250 Hours.
Posted: Sat Nov 10, 2007 9:09 pm Post subject: Vortex Generators/Turbulator's |
Juat got back from a trip to Israel and put together a video that has taken most of my time. Alao am working on house design in airpark. Haven't forgotten and will get it out. Clint
Quote: | Subject: Re: Vortex Generators/Turbulator's
Date: Fri, 9 Nov 2007 20:11:55 -0800
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
> 1250 Hours.
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://forums.matronics.com/viewtopic.php?p=144861#144861
&g=======================
&g==============
