best price on 503
Larry Cottrell
PostPosted: Sun Feb 19, 2006 10:15 pm    Post subject: best price on 503 Reply with quote
I am considering upgrading to a 503 for my firestar II, and was wondering if
any one in this great group of knowledge, would know the best (cheapest)
place to obtain this engine? Will I need anything else like a mounting plate
or will the 447 one I have fit? I would also entertain suggestions for a
three blade prop for it as well.
Larry, Oregon
Denny Rowe
PostPosted: Mon Feb 20, 2006 5:34 am    Post subject: best price on 503 Reply with quote
Larry,
I don't know the best place to buy your engine but I would shop around all
the big dealers including Green Sky and Lockwood etc, also check with Kolb,
sometimes the manufacturers pass engine discounts on to the buyers.
Also consider the C gearbox with the 3.47 reduction and the tapered Warp
drive blades or a Powerfin F model three blade. The big reduction ratio will
give you the ability to swing the 70 -72 inch blades that will deliver
maximum thrust. You will have to raise the engine mounts a little but you'll
know you have all the power you can get from your 503.
Denny Rowe, Mk-3, 690L-70, Powerfin do not archive
herbgh
PostPosted: Mon Feb 20, 2006 10:12 am    Post subject: best price on 503 Reply with quote
Speaking of Props---I think the boys at Kolb are handling one of the
European brands now.. Herb
On Mon, 20 Feb 2006 08:32:24 -0500 "Denny Rowe" <rowedl(at)highstream.net>
writes:
Larry,
around all
with Kolb,
Warp
ratio will
deliver
but you'll
Steven Green
PostPosted: Mon Feb 20, 2006 3:40 pm    Post subject: best price on 503 Reply with quote
Larry,
If you want to go all the way to a 582 I can fix you right up. Engine,
prop, mounts, the whole works ready to run. $3,950
Steven Green
Steven Green
Larry Cottrell
PostPosted: Mon Feb 20, 2006 6:14 pm    Post subject: best price on 503 Reply with quote
Richard Pike
PostPosted: Mon Feb 20, 2006 8:02 pm    Post subject: best price on 503 Reply with quote
A FSII with a 582 turning 4900 rpm goes as fast as one with a 503
turning 5600 rpm and uses about the same amount of fuel. There are
reasons to choose a 503 over a 582, but fuel economy isn't one of them.
Richard Pike
MKIII N420P (420ldPoops)
Larry Cottrell wrote:
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
herbgh
PostPosted: Mon Feb 20, 2006 8:18 pm    Post subject: best price on 503 Reply with quote
Richard Steve Larry
I have two friends who ran Rans S-12 's side by side for several
years... One with a 503 and the other with a 582. The 582 won on Fuel
consumption. Herb
On Mon, 20 Feb 2006 23:02:32 -0500 Richard Pike <richard(at)bcchapel.org>
writes:
them.
Richard Pike
<lcottrel(at)kfalls.net>
Larry Cottrell
PostPosted: Mon Feb 20, 2006 10:04 pm    Post subject: best price on 503 Reply with quote
herbgh
PostPosted: Mon Feb 20, 2006 10:23 pm    Post subject: best price on 503 Reply with quote
Larry
It should be noted that the 503 ran out to over 600 hours trouble free
and the 582 went down with a seizeure at 150 or so.. Herb
I am sure that both of you are right, however, I (personal opinion
only)
prefer to run the engine a bit faster than midrange. Then too I am
sure that
if I had the power, I would abuse it. It is the way that I am.
Larry, Oregon
Dave Bigelow
PostPosted: Tue Feb 21, 2006 1:13 pm    Post subject: Re: best price on 503 Reply with quote
Larry,
I'm in the process of converting my Firestar 2 to twin Hirth F-33's. I took off my 503, but am keeping it until I'm done testing the twin installation. I have the engines mounted, but still have to work out the throttle hookup, hook up the fuel system, and do the wiring. I'm thinking about two months more.
The 503 has 50 hours on it, and has never been overheated, seized, or in any way been abused. It has a B box, twin altitude compensated carbs, powerfin two bladed prop, and comes with a 503 "Smart Single" digtal engine monitering system and an analog tach. It's completely ready to go except for the engine mounts, which can be obtained from Kolb or elsewhere. I used this engine to climb to 16,000 feet, and it never has missed a beat. You can get back to me via a Private Message if you are interested.
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
Kirk Smith
PostPosted: Tue Feb 21, 2006 3:53 pm    Post subject: Re: best price on 503 Reply with quote
Interesting......One prop or two?
Dave Bigelow
PostPosted: Tue Feb 21, 2006 8:08 pm    Post subject: Re: best price on 503 Reply with quote
Here's a photo of the engines temporarily mounted. The struts are attached to the original mount with Lord mounts. The engines are each mounted on the struts with their own set of Barry mounts.
 Filesize:  106.27 KB
 Viewed:  1096 Time(s)
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
Kirk Smith
PostPosted: Wed Feb 22, 2006 2:18 pm    Post subject: best price on 503 Reply with quote
Dave
Looks nice. I wonder what would happen if the belt broke on one engine
while they were in full throttle climbout? A free wheeling prop on one side
and full thrust on the other would sure make it want to twist those struts
and lord mounts. Kirk
WhiskeyVictor36(at)aol.co
PostPosted: Wed Feb 22, 2006 9:06 pm    Post subject: best price on 503 Reply with quote
In a message dated 2/20/2006 1:16:32 A.M. Eastern Standard Time,
lcottrel(at)kfalls.net writes:
Check with the New Kolb Co. My buddy just got a new 447 and after checking
out prices with other distributors, Kolb offered the best deal. Included
extras such as: engine mount plate, cables, muffler assembly, fuel pump, etc.
As I understand, it's like getting the engine kit part of a Kolb kit.
Bill Varnes
Original Kolb FireStar
Audubon NJ
Paul Petty
PostPosted: Thu Feb 23, 2006 11:18 am    Post subject: Re: best price on 503 Reply with quote
Larry,
Buddy of mine has a low time 503 he might sell. He upgraded to a 582. Contact me if interested.
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
