apilot2(at)gmail.com Guest
Posted: Sun Sep 16, 2007 5:52 pm Post subject: Desser vs. Michelin... TUBE WARS! |
Just my experience: 3 Desser leakguards. Mains are great, add air maybe every 6 months. Nose tube...no such ruck. Leaks worse than the standard tube previously there..have to add air every month.
On 9/16/07, Chris Johnston <CJohnston(at)popsound.com (CJohnston(at)popsound.com)> wrote:[quote] yay! while we're arguing about stuff... could you guys argue about this for me so i can decide? i'm trying to decide on some less leaky inner tubes, and i think it's between Desser's "leak guard", and Michelin's "airstop". what say you all? and is it reasonably self-explanatory to order the right size inner tube? is it possible for me to screw it up?
cj
#40410
fuse/finishing
www.perfectlygoodairplane.net
rvbuilder(at)sausen.net Guest
Posted: Mon Sep 17, 2007 6:52 am Post subject: Desser vs. Michelin... TUBE WARS! |
Now here is an off the wall thought, anyone give any consideration to using one of the leak sealant products in their tubes? Maybe something like Slime? Pro’s/Con’s? Might be just the thing to reduce air loss and the difference between being stuck on a backwoods strip or making it home. Thoughts from the peanut gallery? J
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Sunday, September 16, 2007 8:52 PM
Subject: Re: Desser vs. Michelin... TUBE WARS!
cj
#40410
fuse/finishing
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
bob.kaufmann(at)cox.net Guest
Posted: Mon Sep 17, 2007 4:38 pm Post subject: Desser vs. Michelin... TUBE WARS! |
I would not use it unless I had an emergency and needed to fix a flat. I think, with no rational reason, is that the chance of it puddleing and causing a grossly out of balance tire is to high.
Bob K
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Monday, September 17, 2007 6:52 AM
Subject: RE: Desser vs. Michelin... TUBE WARS!
Michael
cj
#40410
fuse/finishing
| Quote: | | http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com | 0123456789012
