jack(at)comconn.com Guest
Posted: Sat Sep 15, 2007 11:12 am Post subject: Broken tailwheel spring- revelation |
It finally happened- I broke my tailwheel spring
after a landing. Not during the landing, but
after. If you could see the condition of the
runway I generally use, you'd understand.
Anyway- no real damage, other than the fabric on
the rudder having numerous holes punched by the
dragging tailwheel. And, of course the need for
a new spring.
Which, as they say, is the point. This occurred
while landing an Avid MK IV. They have that
nicely rounded rudder, and the "round" at the
bottom keeps the rudder off the asphalt if
the spring breaks. I looked at the kitfox I
parked next to it, and noted that if *that*
spring broke, I'd trash the rudder. And, since
I had the avid rudder in hand, I held it up and...
Did you know that, with the exception of the rudder
horns being higher, and the top of the rudder sitting
maybe 1 inch higher, that the rounded rudder will fit
right onto the kitfox? The hinge tabs are in *exactly*
the correct place. A new stop, or moving the horns,
adding an inch to the top of the verticle stabilizer,
and suddenly you have a more effective, and less easily
damaged rudder.
$.02
Jack
Kitfox I Rotax 582 GSC prop
Avid Mk IV jabiru 2200 prince ptip
Michel
Posted: Sat Sep 15, 2007 11:51 pm Post subject: Broken tailwheel spring- revelation |
On Sep 15, 2007, at 9:12 PM, Jack L Bell wrote:
| Quote: | It finally happened- I broke my tailwheel spring
after a landing.
I did the same thing last year, Jack. My single blade tailwheel spring
gave up after about 950 landings. It was on asphalt and the plane went
in a 270 degrees ground loop. Luckily the speed was so low that it went
well. I have now two blades on my tailwheel spring.
I see your point with the Avid rudder that is more curved and doesn't
rest on the ground in the event of the lost of the tailwheel. I guess
the Kitfox is more squared because Denney and later, Skystar, tried to
increase as much as possible the rudder authority with surface.
Anyway, I also needed some repair to the rudder as it had been shaved
by the asphalt. I repaired it with glassfiber, epoxy, a piece of fabric
and paint. It is not a structural part of the aircraft so I guess it
should be good enough.
Geir-Olav, if you read this: Remember to add a second blade to your
tailwheel spring on your model IV!
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Lynn Matteson
Posted: Sun Sep 16, 2007 8:49 am Post subject: Broken tailwheel spring- revelation |
Michel-
When you speak of a "single blade", and later adding a "second
blade", are you counting all the blades/leafs (that's what they call
'em Stateside)? I ask because I also broke the main leaf in my
original 2-leaf spring, and replaced it with a three leaf
spring...that is: two main leafs that have bolt holes in each end,
and a helper leaf that only has a bolt hole where it attaches to the
fuselage. Now understand that I'm talking about the steel leaf
springs that measure 1/4" (~6mm?) each, not the thick aluminum one
piece spring.
With the newer design 3-leaf spring (available from John McBean)
which consists of the aforementioned 2 main leafs and one helper or
booster leaf, breaking a main leaf won't normally cause any dropping
of the fuse on the ground, and subsequent damage to the aircraft,
because normally only one of those main leafs will break at a
time...unless you're having a REALLY bad day. : )
On Sep 16, 2007, at 3:51 AM, Michel Verheughe wrote:
> after a landing.
spring gave up after about 950 landings. It was on asphalt and the
plane went in a 270 degrees ground loop. Luckily the speed was so
low that it went well. I have now two blades on my tailwheel spring.
doesn't rest on the ground in the event of the lost of the
tailwheel. I guess the Kitfox is more squared because Denney and
later, Skystar, tried to increase as much as possible the rudder
shaved by the asphalt. I repaired it with glassfiber, epoxy, a
piece of fabric and paint. It is not a structural part of the
aircraft so I guess it should be good enough.
Michel Verheughe
Norway
Lynn Matteson
flying w/400+ hrs
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Sun Sep 16, 2007 9:22 am Post subject: Broken tailwheel spring- revelation |
Hello Lynn,
On Sep 16, 2007, at 6:53 PM, Lynn Matteson wrote:
| Quote: | When you speak of a "single blade", and later adding a "second blade",
are you counting all the blades/leafs (that's what they call 'em
Stateside)?
Yep, that's what I meant. Speaking foreign languages can sometimes be
very funny. The first price, I think, goes to my Norwegian wife who
said, many years ago: public hair, when she meant: pubic hair!
Yes I was talking about the 1/4" steel leaf. I had only the main one.
Now I have a new main one and a "helper," as you call it. I was also
told that John had three leafs springs. But I figured out that if I
could do 950 landings on a single one, I can do with two leafs for a
while. The think is: when I do the weight and balance on my model 3, I
have only 18 kg (40 pounds) on the tail. Many of the newer models are
much heavier than that.
But you've got a good point there, if I am to break my main leaf now,
the plane will rest on the 'helper' and the rudder will be safe.
Michel Verheughe
dave
Posted: Sun Sep 16, 2007 1:11 pm Post subject: Re: Broken tailwheel spring- revelation |
Michel,
Not so, The tailwheel will be bouncing around and likely go through your rudder. Ask me how i know <snicker>
I have 3 leafs on mine now and hopefully they will have a good long life. .
| Quote: | But you've got a good point there, if I am to break my main leaf now,
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Mon Sep 17, 2007 2:24 am Post subject: Broken tailwheel spring- revelation |
Not so fast there, Michel...when I broke my 2-leaf (main and helper/
booster/whatever) I still got a bit of rash on my rudder because the
tailwheel flopped around a bit and the rear of the plane dropped down
to be SUPPORTED by the helper leaf (as it dragged along in the dirt),
but the tailwheel could STILL cause you damage because it is no
longer held in position by anything. You could still break your main
leaf and cause damage to the plane without the rudder actually
hitting the ground. With the new three-leaf spring, there are two
main leafs that have to break before the above scenario would happen.
My 2-leaf spring broke at about the 450 or so landings mark, and
based on metallurgy, your new one may go before or after that. I had
43 pounds on my tail during weighing. I bought the 3-leaf model
because it is a safety feature, not because I needed a stiffer spring.
Taking this whole safety/stiffness thing a bit further, one might
conclude that if a spring were to be made of 1/8" (3mm) leaves, one
could use maybe four leaves that are all held by the current two
bolts, that maybe a softer ride would result, and the safety margin
would be much greater.
Lynn Matteson
flying w/400+ hrs
On Sep 16, 2007, at 1:21 PM, Michel Verheughe wrote:
Hello Lynn,
> call 'em Stateside)?
be very funny. The first price, I think, goes to my Norwegian wife
who said, many years ago: public hair, when she meant: pubic hair!
one. Now I have a new main one and a "helper," as you call it. I
was also told that John had three leafs springs. But I figured out
that if I could do 950 landings on a single one, I can do with two
leafs for a while. The think is: when I do the weight and balance
on my model 3, I have only 18 kg (40 pounds) on the tail. Many of
the newer models are much heavier than that.
now, the plane will rest on the 'helper' and the rudder will be safe.
Michel Verheughe
N369LM |
poasttown(at)yahoo.com Guest
Posted: Mon Sep 17, 2007 12:25 pm Post subject: Broken tailwheel spring- revelation |
Would a metal tube shaped like a C attached right in front of the tail wheel spring serve as a stop to prevent damage in the event of a tail wheel spring break? This could resemble the skid used on the d tail wheel planes.
Mike Chaney
Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson
Lynn Matteson
flying w/400+ hrs
[quote] --> Kitfox-List message posted by: Michel Verheughe
Hello Lynn,
on [quote][b]
shinco(at)bright.net Guest
Posted: Mon Sep 17, 2007 4:38 pm Post subject: Broken tailwheel spring- revelation |
Too Lynn Matteson: where can I get the triple leaf??I too only have
single leaf.and it all ready broke once on this plane.I want to up date
it all so.can U tell me where to go for this??Steve Shinabery,N554KF,
KF2 582 gray head,,,St.Marys Ohio
Mike Chaney wrote:
| Quote: | Would a metal tube shaped like a C attached right in front of the tail
wheel planes.
Mike Chaney
Lynn Matteson
flying w/400+ hrs
> Hello Lynn,
hair!
> on
dave
Posted: Mon Sep 17, 2007 5:04 pm Post subject: Re: Broken tailwheel spring- revelation |
Call John Mc Bean, he sells them.
You can make your own if you can find 1 1/4 " wide springs but they hard to find.
IF you want one now just call and get it shipped right away. I forget price but I think 50 to 75$ area. I got one and it works ok.
Lynn Matteson
Posted: Tue Sep 18, 2007 7:24 pm Post subject: Broken tailwheel spring- revelation |
Call John or Debra McBean at Kitfox Aircraft, LLC, or just stay tuned
in here, and John or Debra will answer your question.
Lynn Matteson
flying w/400+ hrs
On Sep 17, 2007, at 8:39 PM, Steve Shinabery wrote:
have single leaf.and it all ready broke once on this plane.I want
to up date it all so.can U tell me where to go for this??Steve
Shinabery,N554KF, KF2 582 gray head,,,St.Marys Ohio
> Mike Chaney
> helper/
> because the
> dropped down
> dirt),
> your main
> happen.
> I had
> spring.
> leaves, one
> margin
> Lynn Matteson
N369LM |
Lynn Matteson
Posted: Tue Sep 18, 2007 8:10 pm Post subject: Broken tailwheel spring- revelation |
It might, but you've still got the tailwheel flopping around back
there, possibly causing some damage. Better (in my opinion) to do
something to prevent...as much as possible...the breakage in the
first place. By going to the three-piece spring, you will have two
main leaves, thus giving you 100% redundancy....the chances of
breaking both main leaves at the same time, thus putting the t'wheel
into "flop mode" are pretty slim, I would think. And if you slam it
down hard enough to do that, you've got other issues to deal with
other than a little rash on the rudder.
Lynn Matteson
flying w/400+ hrs
Mike Chaney
Lynn Matteson
N369LM |
Michel
Posted: Wed Sep 19, 2007 10:47 am Post subject: Broken tailwheel spring- revelation |
On Sep 16, 2007, at 11:11 PM, dave wrote:
| Quote: | Not so, The tailwheel will be bouncing around and likely go through
your rudder.
On Sep 17, 2007, at 12:28 PM, Lynn Matteson wrote:
| Quote: | Not so fast there, Michel...when I broke my 2-leaf (main and
helper/booster/whatever) I still got a bit of rash on my rudder
because the tailwheel flopped around a bit and the rear of the plane
dropped down to be SUPPORTED by the helper leaf
Then I must have been very lucky, Dave and Lynn. When I broke my
tailwheel spring, I was the right-hand seater; my son being the PIC. As
I got out of the plane, I thought first that I had entirely lost the
tailwheel because I couldn't see anything. It turned out that the right
hand spring link to the rudder broke too and the wheel was trailed on
the left side of the fuselage, away from the rudder.
Michel Verheughe
Norway
