Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
Posted: Tue Sep 18, 2007 9:19 am Post subject: Running new lines in a closed wing |
The wings are closed in the second-hand 601XL kit I bought. The original
builder ran the Pitot/static lines and wires for the landing lights. The
existing wires run through grommeted holes in the ribs. But I'm adding
strobes, nav lights and an AOA probe. The AOA probe is like the AFS probe
with flush ports in the upper and lower wing surfaces near the tip
(www.advanced-flight-systems.com/Products/AOA/aoa.html). So I don't need
access to the middle of the wing, just a way to run wires and Tygon from the
root to the tip.
So how do I run the new lines? I've thought of a number of approaches:
- just lay the lines through the lightening holes and let them flap around
(semi-serious)
- lay conduit through the lightening holes and only clamp it at the ends.
- like above but add an inspection port in the middle of the wing's bottom
surface to allow a third clamp for the conduit in the middle.
- remove the existing wires and use an electricians 5 foot drill extension
from both ends to enlarge holes to support conduit.
- open the skins.
Comments? Other approaches? If I open the skins can it be done without
having to re-jig the wing?
-- Craig
Gig Giacona
Posted: Tue Sep 18, 2007 10:59 am Post subject: Re: Running new lines in a closed wing |
You should have once access point at the aileron bell-crank. You might be able to reach far enough in there to put some sort of clamp on the bundle.
I'd add another access somewhere else and do the same.
This is assuming that you don't have wing lockers that you are going around.
| craig(at)craigandjean.com wrote: | The wings are closed in the second-hand 601XL kit I bought. The original
root to the tip.
(semi-serious)
- open the skins.
-- Craig |
601XL Under Construction
Posted: Tue Sep 18, 2007 11:17 am Post subject: Running new lines in a closed wing |
| Quote: | This is assuming that you don't have wing lockers that you are going
around.
Nope, no wing lockers so the lightening holes are available. Now adding wing
lockers would get me some access in to the wing's interior but they are
pretty close to the root.
I've considered the crank access hole but it is pretty small to work
through. I think I'd need an arthroscopic surgeon to do the work. Dred is
used to working in small places but I think he uses both hands.
-- Craig
dredmoody(at)cox.net Guest
Posted: Tue Sep 18, 2007 11:27 am Post subject: Running new lines in a closed wing |
I confess that I made significantly larger aileron bellcrank access ports. But then again, I do work on the back end of third molars.
Dred
---- Craig Payne <craig(at)craigandjean.com> wrote:
around.
Gig Giacona
Posted: Tue Sep 18, 2007 12:31 pm Post subject: Re: Running new lines in a closed wing |
My bell-crank access points are large. I made the same mistake twice.
But for this you really won't need access to them after you do the original install so there isn't a problem with doing as many as you need and riveting the cover on them.
Ron Lendon
Joined: 10 Jan 2006 Posts: 659 Location: Clinton Twp., MI, R/S, Wings done Working on Fuselage
Posted: Tue Sep 18, 2007 8:13 pm Post subject: Re: Running new lines in a closed wing |
Craig,
I am just about to close up my left wing. It has all the stuff in it you are planing and has been rotated several times. I think you could remove the top leading edge skin and top wing skin as long as you have a good flat table to check the wing you should be able to take it apart and put it back together.
Punch the rivet centers back then just take the heads off with a sharp drill.
I would want to check the wings out any way. Zenith made up a new book this year that shows a method of checking Wing Twist "6w08aa.pdf", it's in the builders photo assembly guide area.
If you find the wing is in good shape just re-wire, plumb and assemble.
_________________ Ron Lendon, Detroit, MI
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
http://www.zenith.aero/profile/RonLendon |
