a.s.elliott(at)cox.net Guest
Posted: Wed Sep 19, 2007 12:33 pm Post subject: Non-LSA ops limits |
Gang:
If I plan to certify my plane experimental, but not light sport, what are reasonable values for max gross and G limits?
Also, does anyone know if the CG envelope has any gross weight dependence? That is, do the CG limits change with load?
Finally, is this information on the ZAC web site somewhere? I couldn't find it.
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Wed Sep 19, 2007 1:01 pm Post subject: Re: Non-LSA ops limits |
You don't have to certify a plane as a LSA in order to fly it as one.... it just has to meet the requirements.
As to max gross and G limits, I would think you would have to go with those specified by the designer which would be 1320 lbs and +6 -6 ultimate (although I've sometimes seen the ultimate - G load given as 3g's.
The info is on the first page of the plans as well as on Zenith's website. I don't believe there is any change in gross wt limits based upon CG.
Check out http://www.zenithair.com/zodiac/xl/specification.html
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
dfmoeller
Posted: Wed Sep 19, 2007 3:03 pm Post subject: Re: Non-LSA ops limits |
As to the Cg limitation, I asked the guys at Zenith this very question a couple of months ago. The answer was that the Cg limits do not vary with loading, although if you do a search on this board, someone posted some English certifications that did, indeed, vary the Cg limits with weight. This was with the CZAW built plane though, I believe, and they mount the engine considerably further forward, or that is my understanding.
Doug
Craig.Spainhower(at)exelo Guest
Posted: Thu Sep 20, 2007 2:34 pm Post subject: Non-LSA ops limits |
Andy,
If you don't care about being LSA compatible you should contact Zenith and get their concurrence on the increased gross weight. At least one lyc powered 601XL has been certified (in Canada) for a 1500' gross weight. I also heard Chris Heintz say the plane can safely fly (at) 1500'. Be aware that once a gross weight higher than 1320' has been certified the plane can never be made LSA compatable.
Craig S.
N601XS, 601xl 0-235 lyc, wiring/plumbing in progress
find it.
This e-mail and any of its attachments may contain Exelon
Corporation proprietary information, which is privileged,
confidential, or subject to copyright belonging to the Exelon
Corporation family of Companies.
This e-mail is intended solely for the use of the individual or
entity to which it is addressed. If you are not the intended
recipient of this e-mail, you are hereby notified that any
dissemination, distribution, copying, or action taken in relation
to the contents of and attachments to this e-mail is strictly
prohibited and may be unlawful. If you have received this e-mail
in error, please notify the sender immediately and permanently
delete the original and any copy of this e-mail and any printout.
Thank You.
smoore
Posted: Thu Sep 20, 2007 2:57 pm Post subject: Re: Non-LSA ops limits |
So this brings up an interesting question I've never seen answered.
Lets say someone registers the airplane with a 1500lb gross weight. The SP regulations say, "Maximum takeoff weight".
If the SP never loads it up beyond 1320lb, is he legal?
_________________ --
Sean Moore
... re-evaluating mission |
smoore
Posted: Thu Sep 20, 2007 3:02 pm Post subject: Re: Non-LSA ops limits |
Ugh, nevermind. If my question was legal, any 152 could be flown as a SP.
Silly me.
Sean Moore
malcolmhunt(at)mha1.fsbus Guest
Posted: Fri Sep 21, 2007 12:48 am Post subject: Non-LSA ops limits |
Doug
I have looked at the two sets of drawings (Zenith v CZAW) and the
dimensions of the CZAW engine mount (Rotax) are almost identical the Zenith,
CZAW do have an aluminium prop extension.
More of interest is that the CZAW aircraft have a different angle of
incidence of the wing. Looking at drawing 6-B-13 and the wing template the
angles on the Zenith drawing are 81deg and 77.5 deg but on the CZAW drawing
are 83deg and 75.5deg. This is why there is a difference in cof g limits,
according to UK agent this had been agreed with Chris Heintz. My view when
it comes to aerodynamics in all cases Build to the Drawings!
Best regards
Malcolm Hunt
CH601XL Plans builder in England.
dfmoeller
Posted: Fri Sep 21, 2007 4:50 am Post subject: Re: Non-LSA ops limits |
Malcolm,
I'd be very interested in what the CZAW drawings actually do show for the Rotax mount. I got my info from a earlier post last year on this thread about a guy moving his engine forward to correct the rearward weight bias of the Rotax 601XL via use of the CZAW mount. Caleb at Zenith also confirmed this to me in some correspondence at the first of this year. He indicated at that time (January), that the lightweight FF Rotax package would mount further forward and told me just to sit tight for a bit. I still have the email. Do me a favor, search this forum for posts with my user name (dfmoeller). At the bottom of the list look at these threads:
http://forums.matronics.com/viewtopic.php?t=24172&highlight=
New "European XL" from Zenith?
http://forums.matronics.com/viewtopic.php?t=11210&highlight=
Weight & Balance
I'm really curious now just what the deal actually is. I am in the middle of a large rebuilding project on mine and was hoping to rectify the weight issue by mounting the engine further forward. I also would really like to know how the new lightweight engine mount is formed. Take my word for it, if you are scratchbuilding, do everything you can to put a forward bias on the weight. Also, if using the Zenith gear, mount them in the forward position.
Any chance you could scan a section of the CZAW drawings?
Doug
| malcolmhunt(at)mha1.fsbus wrote: | Doug
Best regards
Malcolm Hunt
