mosquito56
Posted: Wed Sep 19, 2007 3:12 pm Post subject: Electronics |
I have only been on this forum for a few months and have searched the archives but still have a few questions concerning instruments for the 601xl.
Efis versus standard instruments. I have been reading alot on the electrics page about using solid electrics for flight instruments and the dangers if you have a power out situation.
Most of the info here seems to be use the efis with gyro backups. If I have gyro instruments why do I want an efis, speaking in a cost effective tone?
I can't seem to get any info on where I can buy gyro instruments. I don't wany anything used. A standard 6 pack is what I have in mind.
Any thoughts or suggestions would be appreciated.
Don
N601NV (Reserved)
601xl finishing wings
South Texas
heliav8r(at)swbell.net Guest
Posted: Wed Sep 19, 2007 3:49 pm Post subject: Electronics |
If VFR you won't need backups for anything. If you go IFR, depending upon
the equipment and your fear factor, you might want backups.
Samm Munn
CH-601XL(plans)
Corvair
jeffrey_davidson(at)earth Guest
Posted: Wed Sep 19, 2007 4:03 pm Post subject: Electronics |
"Efis versus standard instruments. I have been reading alot on the
dangers if you have a power out situation. "
Don,
Just two things to get this started: First, by and large the 601
and 701 are VFR airplanes. Redundancy is usually a concern associated with
IFR craft. In the case of the Dynon EFIS, I bought the backup battery that
is inside the EFIS case. In ground based testing, the EFIS keeps on going
even when all power is removed. According to Dynon, it should run on the
backup battery for 90 minutes. That should be enough time to get on the
ground to sort things out.
Jeff Davidson
CH 601 HD/3300A & all glass panel
First flight real soon now ....
mosquito56
Posted: Wed Sep 19, 2007 5:48 pm Post subject: Re: Electronics |
Thanks, that is good to know I don't have to worry much about backups? What about night flight? I am installing dual landing lights?
Also, the efis is about $6000 dyon10 with all the bells and whistles, But the jabiru site shows an instrument panel for around $2000. THoughts?
Don
amyvega2005(at)earthlink. Guest
Posted: Wed Sep 19, 2007 5:53 pm Post subject: Electronics |
if you have a battery Lypo back up like in the Dynon, no need for back ups.
Juan
zodierocket(at)hsfx.ca Guest
Posted: Thu Sep 20, 2007 3:26 am Post subject: Electronics |
www.sensornetics.com the cheapest and nicest panel we sell, cost for
value wise. I have two installed in my 701. For the 601 I had installed
a Dynon and I am very happy with that unit.
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com
GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Thu Sep 20, 2007 6:27 am Post subject: Electronics |
FOR GYRO INSTRUMENT CHECK OUT AIRCRAFT SPRUCE. I AM USING A DYNON ONLY FOR FLIGHT INSTRUMENTS, ENGINE USES STEAM GUAGES
GLENN
| Quote: | Subject: Electronics
Date: Wed, 19 Sep 2007 16:12:57 -0700
--> Zenith-List message posted by: "mosquito56" <mosquito-56(at)hotmail.com>
Don
N601NV (Reserved)
South Texas
http://forums.matronics.com/viewtopic.php?p=135372#135372
Kick back and relax with hot games and cool activities at the Messenger Café. Play now!
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
japhillipsga(at)aol.com Guest
Posted: Thu Sep 20, 2007 9:00 am Post subject: Electronics |
Glenn, which Dynon are you using ? I'm building an RV-8a and nearing the selection of instrument phase. Thanks, Bill of Georgia
Posted: Thu Sep 20, 2007 9:28 am Post subject: Electronics |
Don't forget MGL's Stratomaster line of glass panels:
http://www.mglavionics.co.za/
www.stratomaster.com
Enigma, Odyssey and Voyager (5 inch, 10 inch and 7 inch screens,
respectively) all support external back-up batteries.
-- Craig
Posted: Thu Sep 20, 2007 9:34 am Post subject: Electronics |
I will have the Sensornetics DVD to view at the Mid-Atlantic Zenith Gathering this weekend if you would like to see it.
Jeff Davidson
dredmoody(at)cox.net Guest
Posted: Thu Sep 20, 2007 10:13 am Post subject: Electronics |
While we're at it, builders should consider the AF-3400 and AF-3500 units from Advanced Flight Systems. The 3400 has a 6.5" diagonal screen, the 3500 has an 8.4 " diagonal screen. Both are available as an EFIS unit, an EIS unit or as a combo. When two units are installed, they are combine-able and swap-able via ethernet link. Both offer internal battery backup and they datalog to an SD card accessible in the panel face of the units.No need for a laptop in the right seat.
Dred
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Thu Sep 20, 2007 1:27 pm Post subject: Re: Electronics |
Your own words Don
"Also, the efis is about $6000 dyon10 with all the bells and whistles, But the jabiru site shows an instrument panel for around $2000. THoughts? "
If you price ANY basic dynon unit (except D180) it's ALSO about $2000. Bells and whistles will crank up anyone's price. I bought the D180 combined EFIS/enigine monitoring system plus a full Rotax accessory package, battery backup, pitot tube, remote compass,mounting gizmo's, the works, for $4180. Not trying to sell Dynon here. Most of the competition looks good. I almost bought the Inigma.....Geoff
japhillipsga(at)AOL.COM Guest
Posted: Fri Sep 21, 2007 9:22 am Post subject: Electronics |
Geoff, I am interested in the D180 for the RV-8a I'm building. My concerns are is it really big enough to see. I measured and the eyeball to panel distance is almost four feet. I don't want to be squinting trying to see some little light bar so far away they all run together. Also, a friend of mine said the 180 won't keep up with a plane doing anything other than "airliner type" flying. That it is too slow and is always trying to catch up ? I just have not had the opportunity to talk to anyone actually using the unit and before I pay Mr. Dynon a bunch of money I hope to know it'll fit me. Do you have any backup steam gages and such as back up? Thanks and best regards, Bill
engineerguy3737(at)yahoo. Guest
Posted: Fri Sep 21, 2007 10:20 am Post subject: Electronics |
Bill,
The D180 will handle changes of up to 150deg per second in pitch roll and yaw ( This is the same for ALL of the non certified EFIS units currently on the market since we all use the same gyros ). The unit your friend has to be talking about is the original D10 ( not to be confused with the modern D10a. ) If you really want to see the responsiveness I suggest coming to visit us at an airshow or finding someone who has a Dynon already installed. (Should be pretty easy to do) I believe you will find the D180 more than adequate for all but the most aggressive maneuvers. If you do manage to saturate the Gyros, it takes only a few seconds (3) of straight and level flight for them to auto erect. During this time, the EFIS will do its best to provide an accurate attitude display.
The D180 is very easy to read at 4ft. If you call our office I'm sure we could send you a panel mock up.
I hope this is helpful.
Dan Lykowski
Dynon Avionics
601xl Builder with Corvair
DO NOT ARCHIVE
Geoff Heap
Posted: Fri Sep 21, 2007 10:59 am Post subject: Re: Electronics |
Bill, I can't comment on performance as I have not hooked it up yet. I was shocked when I took it out of the box and pressed a button and it came to life. I had forgotten about the installed battery backup. I can say that I was impressed with the clarity and brightness. Also, it looks big enough for me. I am considering a few smaller than normal backups. Tach, oil pressure...Geoff
VideoFlyer(at)aol.com Guest
Posted: Fri Sep 21, 2007 11:07 am Post subject: Electronics |
<<, I am interested in the D180 for the RV-8a I'm building. My concerns are is it really big enough to see. I measured and the eyeball to panel distance is almost four feet. I>>>>
Four feet sounds like LOT! You could never reach it without getting out of your seat!
Dave
See what's new a_blank">Make AOL Your Homepage.
Posted: Fri Sep 21, 2007 11:17 am Post subject: Electronics |
Dan, thanks for the info. I'm sure the 180 would handle my "airline pilot" style of flying, but I might break lose and get weird again. I would be thrilled to have a mock up just to be sure I can see it while seated in the 8a. What number should I call to beg for one ? Also, how is your XL coming along ? I finished mine a couple years ago and fly most every weekend. If I can be of any help please don't hesitate to contact me. Best regards, Bill
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Fri Sep 21, 2007 2:35 pm Post subject: Electronics |
Bill--
I'm flying the 601xl with the D100 as my main flight instruments and the D180 mounted on the passenger side for my engine instrumentation and EFIS backup. No problem seeing any of the instrument reading of the D180 from the pilot seat, either with or without split screen.
George May
601XL 912s 150hrs
[quote] To: zenith-list(at)matronics.com
Subject: Re: Re: Electronics
Date: Fri, 21 Sep 2007 13:21:21 -0400
Posted: Sat Sep 22, 2007 8:07 am Post subject: Electronics |
no steamers on mine, just the dynons, with Back up batteries.
Juan
