Removing the front seats
sam(at)fr8dog.net
PostPosted: Thu Sep 20, 2007 8:03 am    Post subject: Removing the front seats Reply with quote
Just finished installing the interior, but now I need to crawl under the panel again. How do I remove the front seats without removing the rear carpet and flap drive cover? That's a lot of work! I think someone had a solution back a year or so ago, but I couldn't locate it in the archives.
Thanks!
Sam Marlow
jesse(at)saintaviation.co
PostPosted: Thu Sep 20, 2007 9:03 am    Post subject: Removing the front seats Reply with quote
I remember someone saying that they filed/ground down the back of the seat that rides on the rails so it would pass the flap cover. I haven’t done that. I always just remove the flap cover. The other option, depending on what you need to do, is slide the seat back and do your thing with it back. I can get up under the panel by just sliding the seat as far back as it can go, lean the seat back, and get up under there. I am 6’1”, 230 Lbs, so it is not comfortable, but it works.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Sent: Thursday, September 20, 2007 12:02 PM
Subject: Removing the front seats
Thanks!
Sam Marlow [quote] http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com [b]
Tim Olson
PostPosted: Thu Sep 20, 2007 9:12 am    Post subject: Removing the front seats Reply with quote
It takes a little work, but it's possible. What you do is to trim a
bevel into that nylon slide runner on the seat side of the rails.
You trim it on the front side of the rails, so that when you pull
the seat latch off and slide it all the way back, there's enough
slop that you can tip the back of the seat upwards. It's much
harder to explain than to see...but it's just loosening up the first
3/4" or so of that nylon glide.
Thanks!
Sam Marlow
sam(at)fr8dog.net
PostPosted: Thu Sep 20, 2007 4:59 pm    Post subject: Removing the front seats Reply with quote
Thanks Jesse, I'll try that first.
Jesse Saint wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
From: Sam Marlow [mailto:sam(at)fr8dog.net (sam(at)fr8dog.net)]
Subject: RV10-List: Removing the front seats
Thanks!
Sam Marlow
5 [b]
sam(at)fr8dog.net
PostPosted: Thu Sep 20, 2007 5:38 pm    Post subject: Removing the front seats Reply with quote
Thanks Tim, do you have a pic by chance on your website?
> it in the archives.
> Thanks!
> Sam Marlow
wvu(at)ameritel.net
PostPosted: Thu Sep 20, 2007 7:49 pm    Post subject: Removing the front seats Reply with quote
Nah, not that much work. A pointy exacto carves the nylon away nicely.
Just pull the seat back as far as it will go. Look at the front side of the
seat rails and carve away the nylon portion that's preventing the seat back
from coming up.
Anh
Tim Olson
PostPosted: Thu Sep 20, 2007 8:36 pm    Post subject: Removing the front seats Reply with quote
Yeah, I exaggerated a bit when I made it sound like work. The worst
part was pulling the seats in and out to test the cuts made with the
exacto. And, unless you want to end up like Stein, you have to
be careful with those Exacto knives! Wink
I believe Anh, for those who missed it long ago, was the originator
of the "fix" by trimming.
the seat rails and carve away the nylon portion that's preventing the
seat back from coming up.
Anh
PostPosted: Thu Sep 20, 2007 9:11 pm    Post subject: Removing the front seats Reply with quote
This was the fix I was referring to and just got the detail wrong. I think this fix is better than the one I erroneously described.
Do not archive.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
Do not archive.
Jesse Saint
Saint Aviation
C: 352-427-0285
F: 815-377-3694
Do not archive.
Jesse Saint
Saint Aviation
C: 352-427-0285
F: 815-377-3694
PostPosted: Thu Sep 20, 2007 9:13 pm    Post subject: Removing the front seats Reply with quote
Do not archive.
Jesse Saint
Saint Aviation
C: 352-427-0285
F: 815-377-3694
Do not archive.
Jesse Saint
Saint Aviation
C: 352-427-0285
F: 815-377-3694
sam(at)fr8dog.net
PostPosted: Fri Sep 21, 2007 3:19 am    Post subject: Removing the front seats Reply with quote
Thanks for the response!
Do not archive.
nicely. Just pull the seat back as far as it will go. Look at the
front side of the seat rails and carve away the nylon portion that's
preventing the seat back from coming up.
Anh
sam(at)fr8dog.net
PostPosted: Fri Sep 21, 2007 3:21 am    Post subject: Removing the front seats Reply with quote
Thanks!
Do not archive.
Do not archive.
Jesse Saint
Saint Aviation
C: 352-427-0285
F: 815-377-3694
PostPosted: Fri Sep 21, 2007 4:31 am    Post subject: Removing the front seats Reply with quote
OK, so last night when my phone was telling me that it couldn't send the
message, I guess it lied. Sorry for all of the e-mails.
Do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
