Gretz pitot and Tru-Trak
DAVELEIKAM(at)wi.rr.com
PostPosted: Fri Sep 21, 2007 6:13 pm    Post subject: Gretz pitot and Tru-Trak Reply with quote
Three questions for ya'll,
For those with a Gretz pitot, where did you mount the control circuit board? I have Safe Air static kit, did you use the green nylon tube all the way to the pitot or Van's aluminum tube?
(Tim I know you used AL tube from your site.)
On my Tru-Trak roll servo there is a "stop limit bracket." Did you install this?
Thanks!!!
Dave Leikam
40496
Wing guts
Deems Davis
PostPosted: Fri Sep 21, 2007 9:50 pm    Post subject: Gretz pitot and Tru-Trak Reply with quote
Check these pics re Gretz location
:http://deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02110.html
I used the green tube all the way to the pitot, im not sure this is the
best way, I tried contacting Gretz, but couldn't get an answer. My
reasoning was that the benefit of the Gretz is that it cycles the
current on & off as required so that the pitot head isn't always hot,
and therefore it shouldn't get as hot as the traditional installations ?????
Re stop limit bracket : Yes I did :
http://deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html
Deems Davis # 406
'Its all done....Its just not put together'
install this?
wayne.e(at)grandecom.net
PostPosted: Sat Sep 22, 2007 4:33 am    Post subject: Gretz pitot and Tru-Trak Reply with quote
Hi Dave,
I mounted the circuit board on the inside to the access panel right next to the pitot tube. I also have the Safe Air but ran the aluminum tubing.
Wayne Edgerton N602WT
in the paint shop hoping to make it to LOE this year ??
Tim Olson
PostPosted: Sun Sep 23, 2007 3:38 pm    Post subject: Gretz pitot and Tru-Trak Reply with quote
I just mounted the controller out on a rib right near the pitot
tube. With it mounted out in the further bays where I put it,
I could reach that area from the end of the wing.
install this?
Thanks!!!
Dave Leikam
40496
Wing guts
